Short Review of Sofirn SP33 v2 with XHP50.2
309 posts / 0 new
Tally-ho
Tally-ho's picture
Last seen: 2 months 6 days ago
JasonWW wrote:
This is also what I think. They are just for anti rotation.
They could have used screws with a bit larger head to press down the MCPCB against the shelf and use thermal paste in between instead of using thermal glue. Facepalm
They abandonned the driver retaining ring, it is now glued.
Someone at sofirn has a fetish with the glue.
JasonWW
JasonWW's picture
Last seen: 1 hour 10 min ago
klrman wrote:
Do you think the chemistry is any safer with the 6000 mAh?
The older chemistry has to do with performance, not safety.
I’ll try to explain why I think the protected KP 5200 mah is not a good choice for this light.
A boost driver tries to put out a set amount of voltage and amperage to the emitter on Turbo.
On the other side of the driver, it is pulling in roughly half the voltage and roughly double the amperage. I say “roughly” because driver efficiency and some other things come in to play.
As battery voltage drops, the driver has to pull more amperage out of it to compensate. This is Ohms law.
Now the driver has its limitation on how much amperage it can draw to keep from burning itself up. The driver engineers will decide on a safe limit. Once this amperage limit is reached, the light will either step down the the next lowest level or maybe do a half step down. This reduces the amperage being drawn by the driver, keeping it safe.
I don’t have the batteries to test it, but I’m sure that a fully charged protected KP 5200 mah will show a larger amp draw compared to an unprotected blue Liitokala 5000 mah, for instance, due to its voltage sagging a lot under load.
What this means is that you can test these two batteries by running the light on Turbo for 2 minutes, let it cool, run Turbo again for 2 minutes, repeat over and over.
The Liitokala may be able to run full Turbo for a combined 30 minutes (just an example as I haven’t ran this test). While the protected KP 5200 mah may only get 15 minutes.
So the KP 5200 is a perfectly safe battery to use, but you won’t get as much run time on turbo.
I would love to see Maukka or other more professional reviewers graph the output of this light with some different batteries to see how they compare. Other boost driven lights have shown to give more Turbo run time when used with unprotected high drain cells.
EDIT: For more on this boost driver design, see post #49 below.
JasonWW
JasonWW's picture
Tally-ho wrote:
Someone at Sofirn has a fetish with the glue.
Sofirns engineers have said straight up that they like to use glue because they believe it makes the lights more reliable.
I’ve make it clear to them (through Tracy) that no one on BLF likes glue. We hate it.
klrman
klrman's picture
Last seen: 6 days 11 hours ago
JasonWW wrote:
I'll try to explain. A boost driver tries to put out a set amount of voltage and amperage to the emitter on Turbo. On the other side of the driver, it is pulling in roughly half the voltage and roughly double the amperage. I say "roughly" because driver efficiency and some other things come in to play. As battery voltage drops, the driver has to pull more amperage out of it to compensate. Ohms law. Now the driver has its limitation on how much amperage it can draw to keep from burning itself up. The driver engineers will decide on a safe limit. Once this amperage limit is reached, the light will either step down the the next lowest level or maybe do a half step down. This reduces the amperage being drawn by the driver, keeping it safe. I don't have the batteries to test it, but I'm sure that a fully charged protected KP 5200 mah will show a larger amp draw compared to an unprotected blue Liitokala 5000 mah, for instance. What this means is that you can test these two batteries by running the light on Turbo for 2 minutes, let it cool, run Turbo again for 2 minutes, repeat over and over. The Liitokala may be able to run full Turbo for a combined 30 minutes (just an example as I haven't ran this test). While the protected KP 5200 mah may only get 15 minutes of full turbo. So the KP 5200 is a perfectly safe battery to use, but you won't get as much run time on turbo. I would love to see Lexel or other more professional reviewers graph the output of this light with some different batteries to see how they compare. Other boost driven lights have shown to give more Turbo run time when used with unprotected high drain cells.
That was a great read, thanks Jason.  It's probably the same scenario with the 18650's then as I tested my protected KP 18650 vs the 30Q and the 30Q was substantially better.
JasonWW
JasonWW's picture
Here is a comparison at 10A. You can see the big voltage sag. This is the unprotected KP 5200. If you add the protection circuitry, the voltage sag will probably be even more.
Oh yeah, I edited that explanation post above to make it a bit clearer.
klrman
klrman's picture
That's quite the drop and not even protected cells    Looks like I've been missing out on the all the fun with my 26650 lights.  Luckily I don't have many 26650's so I'm going to look around to start getting better ones this week.  In the beginning I was so paranoid about unprotected batteries, but now nearly all my 18650's are unprotected.
JasonWW
JasonWW's picture
klrman wrote:
That was a great read, thanks Jason.  It’s probably the same scenario with the 18650’s then as I tested my protected KP 18650 vs the 30Q and the 30Q was substantially better.
KeepPower uses a lot of different 18650 models to rewrap with their protection circuitry, so you have to know what cell is under the wrapper.
Concerning older and newer chemistries, the same thing does apply to 18650’s as well. The Panasonic NCR18650B 3400 mah (aka Panny B) came out in 2012. It can not compare to a newer cell like the Samsung 35E. The test below is a protected Panny B (not a KeepPower version). This is only at 3A! Huge voltage sag.
klrman
klrman's picture
The voltage sag is almost depressing in those graphs.  I use my protected NCR18650B's only in my C8, SP32 v2.0 and my sofirn diving light and they seem ok in those ones.  I'm pretty sure all the protected KP18650's I have are all using the NCR18650GA cells.
JasonWW
JasonWW's picture
klrman wrote:
The voltage sag is almost depressing in those graphs.  I use my protected NCR18650B’s only in my C8, SP32 v2.0 and my sofirn diving light and they seem ok in those ones.  I’m pretty sure all the protected KP18650’s I have are all using the NCR18650GA cells.
For linear drivers they seem fine. A Panny B in a Buck, Boost or FET driver tends to reduce performance, though.
Panny B in a Buck driver can make it fall out of regulation really quick. In a boost driver light, you lose Turbo quicker. In a FET driver light your max output is reduced. Overall, they are not so bad. Newer cells are definitely better, though.
Xikex
Last seen: 3 days 7 hours ago
thanks for the review jason. i ordered a couple as xmas gifts for the co-workers and 1 for myself. cant wait to get it.
JasonWW
JasonWW's picture
Whenever you turn on the light there is a battery indicator feature in the switch which will light up green for about 5 Seconds when the battery is above 3.4 volts. Below 3.4 volts, it will light up red.
At 3.7 volts High mode (920 lumen) is only accessible with a double click. Another way to put it is to say that Turbo mode becomes the High mode. You have Eco, Low, Med and a 920 lumen Turbo mode.
At 3.4 volt, Med is only accessible with a double click.
I testing this with a low capacity junk 18650 which has a lot of voltage sag.
Candela is 18.6 kcd or 272 meters of throw.
Parasitic drain is 121 microamps/0.12 milliamps. Very nice!
pennzy
pennzy's picture
Last seen: 1 hour 17 min ago
Thanks for the new info.
Truck
Last seen: 8 months 1 week ago
Thanks for the review, great shots.
eas
eas's picture
Last seen: 4 months 6 days ago
Why do you think the MCPCB is glued? It isn’t not in my light. As for why they didn’t use screws with a larger head, clamping the MCPCB down keeps things from sliding into alignment when the bezel is tightened down.
The driver is glued. I prefer a retaining ring with some non-permenant threadlock, but that’s going to push the price up. People returning their lights because they don’t work due to a loose retaining ring also pushes up prices.
Jerommel
Jerommel's picture
Last seen: 1 week 5 days ago
Yeah, from a manufacturer’s point of view i can understand they want to use glue or thread lock.
Often it can be overcome with a little heat though, which is good enough for me.
…but sometimes it takes a lot of heat plus a lot of force…
JasonWW
JasonWW's picture
I wanted to add an addendum to post #34 where I talked about how boost drivers work.
Not all of them work like that where the amperage goes up as the battery voltage goes down in order to maintain the constant lumen output. Some will run a lower amperage limit and reduce output as battery voltage drops.
When testing this SP33 on turbo at 3.75 volts I noticed the amperage is still at 5.80A. I checked the lumen output and it was down by roughly 200 lumen. Interesting.
I’ve been asking around, but not too many people are familiar with this style of boost driver. I’ve heard the Thrunite TC20 and Catapult V6 boost drivers may be similar to the SP33 design. I’m still learning about it myself.
I need to pull the driver out and look it over, but that is easier said than done. I can certainly add hot air to the driver cavity and slowly heat up the glue. Pushing it out from the top is a good plan, but you have to push at least one of the led wires all the way down into the driver cavity to get room for a pushing rod. If the driver is really stuck, you won’t be able to get the wire back through and the light will be non functional.
I might be able to tie some thread or dental floss to the wire so I can pull it back through. Maybe.
I’d have to also feel around in the dark with a flat tip punch to make sure I tap against the flat edge of the driver and not an important component. This is why I haven’t got it open yet. I like this light! Lol
I believe what I said earlier about using an unprotected high drain battery still holds true. Once this light gets to 3.7 volts you loose Turbo. So the less voltage sag, the better.
Goodfellafin
Great review! What size is the MCPCB, 20mm? I just got mine, and i am planning to change led, it is too cold for my taste.
JasonWW
JasonWW's picture
It’s 26mm and 6v.
A 20mm might work, you just have to be careful the mcpcb doesn’t rotate and cut into the led wires. If the reflector is gripping the plastic centering ring tightly, just open the reflector hole a tiny bit so it spins freely. That should minimize the chances of the mcpcb spinning with any strong force.
Jerommel
Jerommel's picture
So you’re saying it’s not really a constant current driver?
Hmmm… I suppose i can live with that, unless the difference between 4.2 and 3.0 Volts is noticeably large..
I ordered the SP33 driver too, recently.
But i wonder if that’s the previous XP-L driver or this one..
We’ll see..
TexasToasted
TexasToasted's picture
Last seen: 3 weeks 5 days ago
Mountain Electronics has 26mm boards for XHP emitters and they will reflow the new LED on the board, if they have the LED you want in stock.
JasonWW
JasonWW's picture
I have not measured the output current. I measured the battery currents and the lumens in turbo mode with a fully charged battery. I also measured Turbo lumens and current at 3.75v. I think it’s safe to say the output current does drop a little bit.
I’ll measure the lower levels on a 3.75v battery to see if they are different as well.
JasonWW
JasonWW's picture
He’s in Finland, so MTN is not a good choice. He can probably go through Kaidomain, etc… much cheaper.
BlueSwordM
BlueSwordM's picture
Last seen: 14 hours 5 min ago
I think Sofirn is limiting turbo power levels when below 3,8V/3,75V for their cell to keep on running happily.
JasonWW
JasonWW's picture
The cutoff is 3.70v.
The regular Turbo still works at 3.71+v
JasonWW
JasonWW's picture
We’ll see..
If you get the original driver out please let is know how. So far I’ve tried heat and pulling on it and it has no effect on the glue. The glue does not even soften.
I’m hesitate to try pushing on it from above.
Wildcat
Last seen: 21 hours 9 min ago
From comments on Aliexpress.
Jerommel
Jerommel's picture
We’ll see..
I wasn’t planning on taking out the driver, but i liked the idea of having a spare one, either the XHP50 version or the XP-L version.
It was only €4 + change so i though i’d order one.
I will report on it here though.
Jerommel
Jerommel's picture
Hmmm… That’s a bit early, isn’t it? Why??
JasonWW
JasonWW's picture
Due to the precise nature of the step down voltage points, it’s clear Sofirn chose these in the software. 3.70v and 3.40v. They probably based their decision on what works best.
Jerommel
Jerommel's picture
Bwrf.. My DQG 26650 never steps down and has a similar output.
I mean, what’s the fuss when we’re talking about 20+ Watts / 2500 Lumen lights on a fat battery?
Still under 10 Amperes even when only 3 Volts.
Strange decision.
