Short Review of Sofirn SP33 v2 with XHP50.2
309 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 9 hours 20 min ago
The amp limit Sofirn has chosen to use is 5.8A.
I don’t think anyone has seen this new SP33 driver design so we are all guessing about how it works.
Jerommel
Jerommel's picture
Last seen: 1 week 5 days ago
A stupid choice i.m.h.o.
I’ll post pics when i get the driver.
Not sure if it’s the V1.0 or V2.0 version though.
BlueSwordM
BlueSwordM's picture
Last seen: 15 min 15 sec ago
I think there may be another limiting factor.
The springs are the same found in the original SP33. While steel springs are fine at 3A for the XP-L version, they aren’t at 4A+, as they start to heat up a lot faster than at 3A, and at 5A+, this becomes even worse, resulting in an even high Vdroop.
Dual springs would have helped in this case like in the Q8 and a brass button on the driver.
So Sofirn chose to limit the current not based on the driver design, but on the spring design.
I’ve actually tried that trick with my Haikelite MT01. Trying to run on 1 cell is fine, but the spring gets stupid hot, and the problem becomes worse at lower voltage levels.
Jerommel
Jerommel's picture
Yep, the springs are wide so it’s a long thin wire, made of iron… Facepalm
pennzy
pennzy's picture
Last seen: 33 min 41 sec ago
So is it ok to do spring bypass or too much current?
BlueSwordM
YES. It’s always much better to do spring bypasses with buck/boost drivers. Power is regulated, so less voltage loss in the springs means more runtime at high brightneses.
In fact, unless you are running 2+ cells, good springs/spring bypasses are needed for optimal power/runtime.
pennzy
pennzy's picture
Thanks, wasn’t sure if they were using the low quality springs to limit current.
JasonWW
JasonWW's picture
It is okay to do, but it may not change anything in this particular driver design.
It seems the driver looks at resting battery voltage to determine whether to have Turbo or not. Voltage sag seems to not effect it. Quite strange.
Maybe a bypass will squeeze out a little more Turbo run time? I’m not sure. On other boost drivers, where the current goes up as voltage goes down, I always recommend bypasses. They make a bigger difference there. With this light, I’m not so sure.
DB Custom
DB Custom's picture
Last seen: 2 days 20 hours ago
Nice write up Jason, have you thought about slicing and dicing the 50.2 to get rid of the weird aura and tighten the beam?
Jerommel
Jerommel's picture
With ANY current regulated driver it is better.
You lose less voltage when your electrical path is optimized.
JasonWW
JasonWW's picture
No, I prefer the beam as is. The hotspot is already pretty small for my needs (walking around at night). I don’t want to go smaller. I’m not bothered by the corona. I think I’ve gotten used to it.
Jerommel
Jerommel's picture
Well, it’s not as bad as the smaller Cree flip chip LEDs like the XP-G3 and the XP-L2, but i still don’t like it.
I’m gonna try a Nichia 144A in it, which is probably just as bad, but i found a suitable frosted TIR that will blend everything to perfection, or so i hope..
Gonna have to shorten the head though, because TIRs are short..
First i have to tidy the huge mess that has grown in the shed, though..
eas
eas's picture
Last seen: 4 months 6 days ago
JasonWW wrote:
TexasToasted wrote:
Mountain Electronics has 26mm boards for XHP emitters and they will reflow the new LED on the board, if they have the LED you want in stock.
He’s in Finland, so MTN is not a good choice. He can probably go through Kaidomain, etc… much cheaper.
https://www.aliexpress.com/store/product/MAXTOCH-Copper-MCPCB-Cree-XM-L2-XM-L-XML2-XML-26mm-x-1-6mm-Direct-Thermal/314381_32601411604.html?spm=2114.12010612.8148356.10.5e067dfbFwZeBC
eas
eas's picture
My v2 has a different tailspring than my original SP33. The old one was the full diameter of the tube. The new one is ~1/2 that. The length of the current path is shorter, as a result.
The point still stands about voltage drop, though.
Goodfellafin
Thank you all for answers. This is what i like about this forum, you ask something and you get a decent answer in no time! Thanks guys! That 26mm mcpcb would be great but i have never reflowed a led. Maybe i will try with 20mm XHP50.2.
SKV89
Last seen: 4 hours 24 min ago
Jerommel wrote:
Bwrf.. My DQG 26650 never steps down and has a similar output. I mean, what’s the fuss when we’re talking about 20+ Watts / 2500 Lumen lights on a fat battery? Still under 10 Amperes even when only 3 Volts. Strange decision.
The DQG 7x emitter 26650 definitely steps down. It’s actually very noticeable. Just try it. I wish Sofirn will get rid of the timed step downs on their newer lights that already have advance temperature regulation. I don’t want timed step downs especially when used in outdoor cold temperatures.
JasonWW
JasonWW's picture
Driver pics are added to post 1.
eas
eas's picture
Thanks for the driver photos!
It looks like it is using the TI TPS61088 boost converter.
Edit: And it looks like this is how an switch current limit is set.
There are other ways to do current limiting though, using an op-amp and the voltage feedback pin.
Anthon
Last seen: 23 hours 55 min ago
I have this light and for $20 it’s a bargain, 2400 real lumens and 1000 sustainable lumens, with great UI (click on click off)
The things I don’t like:
-Tint: it’s cool, a 5000k would be better
-Can’t go from moonlight to regular modes, you have to turn off the light and then turn on with a single click
-Can’t turn off from turbo, you need two clicks, first click gets you to previous mode and second click to turn off
Jerommel
Jerommel's picture
Oh, i never noticed. I guess i only use turbo for short periods.
Trying it now.
Aha, yes it does step down after a minute or so.
Ooh, it’s hot !
But it doesn’t step down based on battery voltage or current or does it?
At least not as early as the SP33.
Jerommel
Jerommel's picture
When you go to turbo from OFF it’s just one click to turn it off.
Jerommel
Jerommel's picture
Awesome!
Thanks, Jason. Thumbs Up
Jerommel
Jerommel's picture
That’s very good to know !
Hopefully we can identify the resistor and replace it.
polarweis
polarweis's picture
Last seen: 6 days 3 hours ago
so who will slice the led? just ordered mine. usually shipping is pretty fast.
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
JasonWW
JasonWW's picture
TexasToasted
TexasToasted's picture
Last seen: 3 weeks 5 days ago
Placed my order from their Aliexpress store Nov 14.
Tracking shows light was shipped Nov 26.
No updates since then. 30 days later and it hasn’t left China yet.
polarweis
polarweis's picture
TexasToasted wrote:
Placed my order from their Aliexpress store Nov 14. Tracking shows light was shipped Nov 26. No updates since then. 30 days later and it hasn’t left China yet.
it is a busy time for the chinese and sometimes just bad luck i guess. my most recent sofirn took 11 days after they shipped it
JasonWW
JasonWW's picture
If you don’t have updates, how do you know it’s still in China? My light took 27 days, but I ordered it a month before Thanksgiving. All deliveries are going to take longer during the holiday season (from about mid October to mid January). I had a 20 day gap of no updates. It seems yours got shipped 10 days after ordering, mine was 4 days after. I would guess you’ll probably see some updates in the next week or so. Once it hits the US, it can be delivered pretty quick. I wouldn’t stress too much about it.
pennzy
pennzy's picture
Mine will be here today. 32 days.
TexasToasted
When a package leaves China, the EPacket tracking shows it was sent to the USA.
When it arrives in the USA, USPS tracking shows it arrived.
Neither of those 2 things have happened, so I have no reason to believe the package has left China yet.
I have had packages arrive without ever getting any tracking info. That’s usually from dishonest Aliexpress vendors giving me a bogus tracking number to extend their shipping deadline.
