Received the second component of my future project
74 posts / 0 new
raccoon city
raccoon city's picture
Last seen: 5 hours 26 min ago
Enderman wrote:
Jerommel wrote:
.1 mm² ?? Shocked
0.1 × 0.1 mm
SmileSmileSmile
Wouldn't that be 0.01 mm²?
Enderman
Enderman's picture
Last seen: 1 hour 18 min ago
raccoon city wrote:
Wouldn’t that be 0.01 mm²?
yeah, a square with side length .1mm.
Jerommel
Jerommel's picture
Last seen: 2 hours 54 min ago
0.01 mm² ??
Wowzers..
Well, you can burn quite a few 0.1 mm² holes in a 9 mm² Phosphor..
2Q19
Enderman
Enderman's picture
Haha true Silly
Agro
Agro's picture
Last seen: 3 min 44 sec ago
Hmm…2000 lm from 0.01 mm²?
That’s over 60 000 cd/mm², nearly 160 times brighter than the current LEPs used in flashlights.
Agro
Agro's picture
Enderman wrote:
EasyB wrote:
You could put a hemispherical reflecting collar on the bottom too to recycle the light going down.
Possible, but I need to have cooling on that side so I can’t fit a second collar.
Have you considered some transparent cooling, f.e. liquid loop? I would be scared of bubbles but if you can sort it out – maybe that wouldn’t be bad…
Jerommel
Jerommel's picture
^ Yeah, i suggested that too, earlier.
Water.
Flowing on both sides of the Phosphor, sandwiched between thin glass or PMMA.
AR coated if that’s worth it.
The Phosphor will have a really hard time getting hot with direct water cooling.
Water is great stuff. It’s also as clear as water ! Silly
2Q19
Enderman
Enderman's picture
I don’t think it will be close to 2000lm, maybe 500 or a bit more, apparently about half of the laser light doesn’t enter the collimation lens.
Using some special combinations of lenses I could make 100% of it go to the 0.1mm spot on the phosphor but first I need to check that it won’t get damaged as it currently is.
Also, I already said this before, but water has a very low thermal conductivity.
Less than 1w/mk.
Just because it has a high heat capacity doesn’t mean it will cool the object well, because the area is so small that the heat transfer to the water will be miniscule.
You need a material will high thermal conductivity to move the heat away, then have high surface area to transfer that heat to the water or air efficiently.
This is why CPU heatsinks and waterblocks use copper to move the heat to large areas of fins, which THEN are cooled by water or air.
You can’t cool a computer by running water or air directly on the CPU.
Jerommel
Jerommel's picture
Less than 1w/mk.
You would get electrical issues when you do that.. Silly
But i see your point.
But water is of course much better than air.
I don’t know. Maybe you’re right.
It’s a ‘gut feeling’ i guess, that convinces / persuades me to believe a thin wafer of Phosphor, basically sitting in rushing water has a really hard time to get hot.
But since you’re planning on hitting only a 0.01mm² spot, i’m not so sure…
Tell me if i’m boring you, but i had another thought:
Maybe place the Phosphor wafer in a ball bearing and spin it so that the laser point never hits a single spot for a long time.
You could add motion to the whole bearing so that it doesn’t only hit the same circle on the Phosphor.
Yeah, a lot of hassle, i guess…
2Q19
PolarLi
PolarLi's picture
Last seen: 9 months 2 weeks ago
Looking forward to this one! Fresh tech and new implementation, is always exciting.
I also need to correct The Driver, the BFF is definitely not 250Mcd. There is a reason I have said it start with a 1.
Enderman
Enderman's picture
If you want you can calculate what equilibrium temperature the crystal would reach if it was in water.
I can tell you right now that 18mm^2 of area will reach a very high temperature before 3W of heat are carried away by the water…
Also rotating phosphor is what many projectors use:
Doing this with a single crystal phosphor would cost tens of thousands of dollars, assuming you can get a piece that large.
Thanks Silly
I’m still waiting for more updates on yours!
Tom Tom
Suggestion, wear an eyepatch over your best eye whilst working on this. And please don’t shine it in my direction.
PolarLi
PolarLi's picture
No worries, update is coming, just been busy with some other stuff.
The_Driver
The_Driver's picture
Last seen: 1 hour 29 min ago
You need to use two ar-coated (specifically for 450nm) cylinder optics together with a G7 focussing optic to get the best possible hotspot, highest efficiency and least amount of stray light. The cylinder lenses correct for the differently expanding axes of the rectangular laser beam. This can easily cost 100$, but it’s worth it.
The optical assembly and the cooling will probably give you the most grief.
Did you get a suitable, adjustable laser driver? I know a very compact one if you need it.
Enderman
Enderman's picture
The engraving lasers they sell are doing .1mm^2 without any cylindrical optics, so I’m going to try that first.
There’s no point in spending $450 on an acylindrical lens if I’m already burning through the crystals without it.
The driver I bought can be regulated by 5v in addition to a current trim pot to adjust the maximum.
https://optlasers.com/medium-power-drivers/lpldd-5a-12v-tp
Also comes with a temp sensor for protection of the laser diode Smile
Enderman
Enderman's picture
More expensive stuff.
Hopefully I don’t blind myself.
DavidEF
DavidEF's picture
Last seen: 1 week 3 days ago
Lovely eyewear… LOL I hope it does the job it was created for. Cool
Be Safe! …but have fun. Thumbs Up
- The YKK Philosophy
Enderman
Enderman's picture
It was like $50 and apparently much better quality than the cheap ones you can get form china, so it better be Silly
nottawhackjob
Last seen: 1 month 5 days ago
Be gracious and don’t be surprised if someone mistakens you for Elton John and asks for an autograph. Shocked
“In many things in order to truly understand the small picture you have to understand the big picture first.”
Enderman
Enderman's picture
hahaha
MRsDNF
MRsDNF's picture
Last seen: 4 hours 59 min ago
I’m already dazzled. Beer
ImA4Wheelr
Last seen: 3 weeks 18 hours ago
Enderman wrote:
. . . More expensive stuff. Hopefully I don't blind myself.
Nice.  Looking forward to watching this build.  No g-ball lens built into the can.  7 watt 450nm diode from a  NUBM44/47 bank?
Enderman
Enderman's picture
Thanks, yeah its a nubm44 Smile
Lexel
Lexel's picture
Last seen: 9 hours 12 min ago
I hope that mount has the right tolerances to press fit the diode, otherwise you get thermal issues
also a TEC cooling is needed to keep the diode cool if you want to drive it hard
Enderman
Enderman's picture
I’ll heatsink the diode with thermal paste or liquid metal.
I’ll be making my own mount for the diode so I can probably do pressfit too.
With a large heatsink you can do 6-7W without a tec, see some of the videos on youtube.
A tec is more necessary for 8-10W which is pretty extreme.
I’m trying to keep the amount or parts minimized for highest reliability and lowest price, so that means no liquid cooling or fans or tecs.
Enderman
Enderman's picture
Just tested the laser tonight, incredibly powerful, was at minimum power and it started burning a hole in some cardboard.
Unfortunately I seem to have some issue with my laser driver, so just using my DPS5020 power supply to drive the laser at constant voltage and it works great.
Planning to machine a custom copper heatsink for testing purposes, as I need to hold both the collimation lens and crystal at fixed distances.
My idea is to make a simple rectangle block that I can screw onto a CPU heatsink like the NH-D15 for some extreme cooling:
Then I can also make a second attachment for LED MCPCBs and I can easily switch my heatsink to whatever needs to be tested.
I also just purchased a special M9×0.5 thread tap (for the lens) to make the copper laser block.
https://www.ebay.com/itm/Metric-Fine-Mf-M-9-x-0-5-9-mm-Hand-Taps-Serial-...
Xandre
Xandre's picture
Last seen: 1 hour 56 min ago
Please take care of you
and the outside world!
Regards Xandre
nottawhackjob
!{width:25%}https://optlasers.com/7857-thickbox_default/collimator-400-700-nm.jpg!
It looks like you’re finally starting to get sumwatt more serious about this little project.
LOL Shocked
MRsDNF
MRsDNF's picture
M9 is an unusual size. Never heard of it before now. Good to see more components rolling in. Hopefully the driver can be sorted out.
Enderman
Enderman's picture
Regards Xandre
Smile Yup, closed room, goggles, fire extinguisher at the ready.
M9×0.5 is odd but found on almost all security camera/fpv camera lenses and laser lenses, it seems to be the standard for those things that need fine adjustability of optics.
