Test/review of Vapcell INR18650 2000mAh (Green) 2018
Official specifications:
  • Model: INR18650 2000mah 28A
  • Size: 18.4*65.0mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 2000mAh (0.2C discharge)
  • Min capacity: 1900mAh (0.2C discharge)
  • Weight: Max:50g
  • Internal resistance: Max: 10mOhm (AC 1kHz)
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Charging Time: 1.5hours(standard charge)
  • Quick Charge Current: 3000mA
  • Max Continuous Discharge Current: 28000mA
This battery is fairly low capacity, but very high current.
The discharge curves tracks very well and the cell can deliver the rated 2000mAh at any current up to rated maximum.
Conclusion
This is a good battery for high current applications, but capacity is on the low side.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
Who knows who made this cell? It looks like the positive poles used by YongdeLixin in their 18650 cells, I have a pair of Golisi S30 (2nd generation, because the first version were Sony / Murata US18650VTC6 rewraps) which have exactly the same positive poles but they are cells which make 3000mAh see more…
HydrAxx
I think you are right.
Similar to the YDL positive ….
