14500 Non- Rechargeable Battery?
30 posts / 0 new
Cabral954
Hello – I’m new to this forum & recently started acquiring LED Flashlights. I am impressed with the expert knowledge of the members & I’m sure many of you can help me.
I’m looking to buy Non-Rechargeable 14500 batteries as back up if my house power goes out for a long time during one of our New England snowstorms & my rechargeable 14500’s are getting depleted. I found some 14505 types on eBay rated at 3.6VDC/2000 mah but the vendor stated that these batteries are NOT compatible with LED Flashlights since the CDR is is low – he used the term “transitory” to describe the current capacity. I’m not sure of the Chemistry of these batteries but I believe they are LiThionylChloride such as the SAFT Brand which are rated at 50ma continuous.
I went to Battery Junction & found Titanium LiMnO2 14505’s which are rated at 3VDC/1500 mah@3amps. Can I use these in my 14500 Flashlights for an extended period? I have a ThorFire TK-05 & a Sofirn SP10 V2. I know CR123’s can replace 16340’s so is there an “equivalent” CR123 type in a 14500 form factor?
Thank you
Nev
Last seen: 6 months 3 weeks ago
AA?
robk
Last seen: 2 weeks 5 days ago
Why not just use AA alkalines if your lights use them. Home Depot has their house brand for $10 for 60 cells. Works out at less than 17 cents a battery.
https://www.homedepot.com/p/HDX-HDX-Alkaline-Battery-AA-60-Pack-715160/305232311
toddcshoe
toddcshoe's picture
Last seen: 50 min 50 sec ago
I suppose you could use those batteries from Battery Junction. I guess one problem you may encounter is Low Voltage Protection on the flashlight. I don’t know if any of the lights you have actually have that built in. I know most LVP on the lights kick in at about 2.9 or 2.8 volts or so. Your runtimes on the light would be significantly shortened if that is the case. If LVP isn’t present on your lights then you can run them batteries down to nothing and would work excellent as a alternative. I don’t have a TK05 or a SP10 but if those lights can work with NiMh I would choose those. They keep their charge for super long periods just sitting on the shelf, they are fairly affordable, and readily available. The only downside is reduced output.
"Everywhere I go, there I am"
robo819
robo819's picture
Last seen: 1 week 2 days ago
You may be talking about something like the Lithium Primary cells as far as NON rechargeable?……….
https://www.amazon.com/dp/B004EFT2BU/ref=twister_B01I5TZ0L6?_encoding=UT...
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Thetasigma
Are you looking for AAs (1.5V cells), or 14500s (3.7V cells)?
For 1.5V applications the Energizer Ultimate Lithiums are the way to go.
If you specifically need 3.7V and want a primary cell Saft AA 3.6V Lithium Thionyl Chloride are available, but they would only be useable on lower modes as they are not cells meant for high drain, and they ARE single use primaries
Edit: double checked on the Safts, they are 50mA max continuous current.
Geuzzz
Geuzzz's picture
There are some non rechargeable 3,6 v 14505 batteries. Don’t know how long your light will run on them though.
https://www.nkon.nl/disposable-batteries/aa-14500.html
Kame Sennin
Kame Sennin's picture
Last seen: 1 week 21 hours ago
Non rechargeable 3.6V 14500 seem to be all LiThionylChloride and meant for (very) low current load.
If you want something for emergency and don't want to bother verifying/recharging/whatever your best bet imho is to go for AA flashlights and stock some primary 1.5V lithium and/or LSD Nimh.
If you have Ikea where you live they have the 2450mAh LSD  AA (name : Ladda) that are known to be rebranded Eneloop Pro for less than 2€/piece here (just verified they are 7$ for 4 pieces for you)
PJ
3v non rechargeable cells
Battery Junction has these 3 volt cells.
Eschew obfuscation.
Kame Sennin
PJ wrote:
"3v non rechargeable cells":https://www.batteryjunction.com/titanium-cr14505-craa--3v.html Battery Junction has these 3 volt cells.
Descriptio says :
  • Continuous Standard Load: 20mA
  • Maximum Continuous Discharge Current: 1000mA
Not sure what to believe
hank
hank's picture
Last seen: 3 hours 46 min ago
Remember the li-ions are low capacity cells. In a long power failure you want a good box full of primary cells with more capacity.
And probably a 12V-powered charger you can run off your car battery or solar cell. HKJ has started checking solar power for chargers.
Kame Sennin
hank wrote:
Remember the li-ions are low capacity cells. .
You mean Lithium primary ? The good point with these ones is the long shelf life opposed to alkaline.
But as long as we don't know exactly what the OP was looking for with non rechargeable 14500 we don't know what is best for him
hank
hank's picture
No, I mean that rechargeable li-ions are low capacity compared to lithium primary (Energizer) or alkaline cells.
Li-ion powered flashlights will be good for an hour or two after a power failure, longer at moonlight, but that’s not very long.
Then it’s time to pull out the other flashlights that use 1.5v AA or D cells.
AA Eneloops are a good thing to have (along with a charger you can run off 12v car battery or solar)
I rely on Dorcy for my emergency kit, e.g. https://www.dorcy.com/shop-now/flashlights/led-rubber-combo
And every year or so go through the alkaline battery stockpile and give away the ones that are getting old to neighborhood kids for toy use.
Geuzzz
Geuzzz's picture
Watch out. Evil neighbor trying to kill your toys with old alkaleaks Wink
hank
hank's picture
Yep. Explaining leak precautions is part of the work. As is getting the kids to bring back dead cells for the recycling bin. Fortunately the Albany CA end of our block has curbside collection for bagged-up dead batteries along with trash collection.
Paul_in_Maryland
Paul_in_Maryland's picture
I have about six of those 3-volt AA-size cells from Battery Junction. I bought them at least 5 years ago and never used them. Correction: I tried one in a 1x14500 light and got, at most, a nightlight. But hang in there: A couple days ago, I ordered an EagleTac D25A (which I've already listed in my signature block), which can use anything from 0.9 volt to 4.2 volts. An Amazon reviewer reported that he had used such a cell in this light and it worked: It shined brighter than a AA and, I'm guessing, gave him decent service life. When my D25A arrives, I'll try it with a 3V cell and report back in this thread.
1xAA: EagleTac D25A (Nichia 219C)
2xAA: five EagleTac D25A2 Clicky (Nichia 219C); EagleTac D25A2 Tactical (XM-L2 T6); Jaxman M2 (XM-L2 T6)
EasyB
Last seen: 3 hours 49 min ago
Kame Sennin wrote:
But as long as we don’t know exactly what the OP was looking for with non rechargeable 14500 we don’t know what is best for him
From OP:
“I know CR123’s can replace 16340’s so is there an “equivalent” CR123 type in a 14500 form factor?”
That pretty much sums up what he’s looking for. Unfortunately it doesn’t seem like they exist.
Kame Sennin
Sorry i might have worded it wrong  ... it's more the why than the what so knowing that what he wanted doesn't seem to exist we could  help trying to find something that could fit at least some of its expectations (care free ? long shelf life ? cheap ? high power density ? whatever ?)
Cabral954
Thanks to everyone for the replies. Maybe I wasn’t clear – I just want to know if I can buy a Non-Rechargeable Lithium 14500 (Primary) form factor (size) battery that outputs 3-3.7 (approximately) VDC. I understand I can use AA 1.5 or 1.2 VDC Batteries – I want the higher Voltage output & mah of a Lithium.
A CR123 is a primary Lithium (3VDC) battery & can be used in place of a rechargeable 16340/RCR123.
What options do I have if I want a Lithium Primary (Non Rechargeable) 14500 form factor battery?
Again thanks to everyone for their technical assistance.
hank
hank's picture
I think you’ll be happier in the end if you look for the answer to the problem you want to address:
Personally, I figure the li-ion powered flashlights are going to be useful for a little while after the shaking stops (earthquake territory) but unless I have recharging set up, I’m going to fall back onto passing out lights from the cache of flashlights with LEDs that run on 2×1.5vAA cells for the following days. And probably be messing around setting up a neighborhood charging station for Eneloops during that time.
PS, besides a cache of Energizer lithium primaries and Eneloop AAs, I’ve got some NiMH C and D cells (Tenergy Centura) kept on a trickle charger. And a solar panel I have yet to hook up to run that.
And a few PR2 dropin LED bulbs to swap out the incandescent bulbs in the cheap flashlights, too.
robo819
robo819's picture
Unless I am mistaken there is not a “NON Rechargeable” AA / 14500 sized cell that has a chemistry like the CR123A , that will give you the 3 to 3.7 volts you are asking about.
The Enigizer lithium primaries as mentioned several times in the thread , are probably going to be your best option as far as the NON rechargeable cells. They claim a 20 year shelf life also with these cells.
The Eneloop Pro are supposed to hold 85% of their charge for at least 12 months and may be the second best option for the particular lights you mentioned.
I am not sure if any of this information will help you or not but……….
The run time is good from the Eneloop pro in the SP10 A / B as I have had mine sitting here running for the last 180 minutes from a start on Turbo and left running , so the run time is good from the Eneloops. The light started at 251 lumens on a rested Eneloop pro at 1.37 Volts. From around 100 minutes the output remained virtually the same with 75 lumens at the 100 minute mark until I terminated the test with the light still making 73 lumens at 180 minutes. The cell was at 1.05 volts when I terminated the test.
Also here are the charts from my testing back when I reviewed the TK05………..
Cabral954
Thank you Robo819 for your very well written response. Your statement “Unless I am mistaken there is not a “NON Rechargeable” AA / 14500 sized cell that has a chemistry like the CR123A , that will give you the 3 to 3.7 volts you are asking about.” answers my question perfectly.
Your data/test results are very impressive & you are obviously an expert in understanding this new & exciting technology.
Lightbringer
Lightbringer's picture
Last seen: 41 min 21 sec ago
Yeah, was gonna ax what about those Li Energizers that were all the rage for digital cameras and the like.
Plotthound
Last seen: 13 hours 51 min ago
I’m not sure about chemistry, but Saft and others make non-rechargeable lithium 14500 and 14250 3.6v batteries. We used to use them in our radio telemetry dog collars They’re kind of expensive.
Jerommel
Jerommel's picture
Last seen: 1 week 1 day ago
Maybe switch to CR123A lights for this purpose, since those cells are widely available and not that expensive.
robo819
robo819's picture
The Energizer Ultimate LI is supposed to run 5 to 7 times longer in cameras and such , but I have never Tested that theory.
They are really too expensive to just use all the time in like an EDC light for me , but for backup purposes and the long shelf life they have , would be well worth it to get a couple of 20 packs that would stay charged for emergency use over long periods for sure.
robo819
robo819's picture
Glad to help when I can…… “expert” I am not……..
Just another one of the many flashaholics on here that has picked up a lot of information from other forum members over time and I am still learning.
vit55
Last seen: 3 weeks 4 days ago
Saft LS, non rechargeable cells 3.6, volt very good but expensive.
Paul_in_Maryland
Paul_in_Maryland wrote:
I have about six of those 3-volt AA-size cells from Battery Junction. I bought them at least 5 years ago and never used them. … When my D25A arrives, I’ll try it with a 3V cell and report back in this thread.
I tried all six 3V cells in my new keyring EagleTac D25A Clicky with a Nichia 219C emitter. None was much brighter than a fresh Eneloop; in fact, two looked slightly dimmer. But a 3.7V IMR 14500 cell was noticeably brighter than either. I’ve decided to keep the 3.7V cell in the D25A and keep a 3V cell in my coin purse as a spare.
keltex78
keltex78's picture
I’ve never used any in a light, but I use The Ultimate Lithium AA cells in my game camera and have been very happy with them. A set of 8 cells lasts for about 8-9 months in my camera, while taking several thousand photos, some daytime, and some nighttime, with the LED flash.
No leaks, not sensitive to cold weather, and maintain high output current until fully depleted. My admittedly untested thought is that they would make a good option to stock in an emergency/bug-out kit.
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
