How low can it go? Akoray K-106 3-mode programmable
6 posts / 0 new
sb56637
sb56637's picture
Last seen: 7 hours 10 min ago
Hi guys,
It is possible that our custom 1xAA BLF flashlight could have a programmable driver. As I mentioned in another post, Eastward YJ is going to look at the Akoray K-106 3-mode programmable light to see what they can do. So, since many of us are interested in a moonlight mode for the BLF custom flashlight, the question naturally comes up: How low can an Akoray K-106 go?
I have been experimenting with mine, and it doesn't really go very low. Even when I set the lowest mode by half-clicking before the ramping cycle even starts, the lowest brightness I can achieve is almost identical to that of the Trustfire F20 on low. I read somewhere that this is approximately 6 lumens. Any other experiences or tips or hard numbers?
Thanks!
Don
Don's picture
Last seen: 3 years 5 months ago
Apparently it can go very low, I remember reading on CPF that the way to do it was to use multimeter probes as they could be moved  more rapidly and could get it down to the 1-2 lumen area. Not tried it myself though.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
sb56637
sb56637's picture
Hmm, 1 - 2 lumens would be nice. Unless I am doing something wrong, I don't think mine goes that low.
Don
Don's picture
I'll give it a try tonight and see how low I can get it.
Don
Don's picture
The trick is to remove the switch and use a multimeter set to current.
Get it into programming mode then as soon as the meter shows a current, break the circuit with the probes. I managed 2 lumens with a 14500 but I've not been able to replicate this. Got the lowest down to about 6 lumens with an NiMH, 8 with a 14500 though a bit more fiddling ought to be able to drop it a little lower than that.
It is a pain to line up the clip when it comes time to reinstall the switch.
old4570
Last seen: 4 days 15 hours ago
If you time it just right , you can get it low ... Mine is1-2Lumen , but it was tricky to get it there ... Id sure hate to set the modes again ...
Id be happy with 5 lumen for moon mode ...   5-20-40-100%  would work for me just fine ...
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
