Is there an individual triple LED Driver with 2 modes per LED?
14 posts / 0 new
mili111
Last seen: 2 weeks 2 days ago
I found this one on KD:
http://kaidomain.com/S026866-KZ-3016-Individual-Triple-LED-20mm-1_5A-2_7...
Is there an equivalent on the market which delivers 2 modes per LED?
I want t omod a S2+ with 3 different colors and want a low and a high mode for each color.
Cheers
Virisenox_
Virisenox_'s picture
Last seen: 3 days 5 hours ago
http://kaidomain.com/S026866-KZ-3016-Individual-Triple-LED-20mm-1_5A-2_7…
That one can have each LED either on or off. Sounds like two modes to me. Big Smile
You might not be able to use that driver without some mods anyway. Different colored LEDs take different voltages.
Reviewer for ThorFire, Olight, Sofirn, and others.
More active on Reddit: /u/Virisenox_
"I go hard."
- Zeroair
"Don't quote me on that."
- Zeroair
mili111
Haha, got me Big Smile
Umm, im not that modding pro… hope i mustnt change the driver =(
In the german TLF a guy modded his Convoy with that driver and took a red, a blue and a nichia LED. He didnt mention that he has to change the driver.
Virisenox_
¯\_(ツ)_/¯
If it worked for them, it worked for them.
Either way, it doesn’t have the UI you want.
"I go hard."
- Zeroair
- Zeroair
mili111
Thats correct… but if there is nothing on the market i have to take this one.
Thanks for your help!
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 18 min ago
@milli111, ask Kaidomain to put different modes on the driver of the light.
They accept customization options.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
ggf31416
Last seen: 25 min 38 sec ago
http://kaidomain.com/I3N-20mm-3V-9V-1_5A-1-cell-or-2-cells-6-Mode-3-Indi...
That’s the driver they use for their triple color XP-E2 dropin, but it’s the wrong size for a Convoy S2+. The S2+ uses a 17mm driver.
TBone
Last seen: 30 min 51 sec ago
The inner diameter of the S2+ tube is almost 20.8 mm. If you find a way to attach the driver to the pill it is doable.
hank
hank's picture
Last seen: 3 hours 34 sec ago
Quote:
Mode:
LED 1 (On) > LED 2 (On)> LED 3 (On) > Off
So this will illuminate all three emitters? Not just #1 or #2 or #3?
mili111
@ggf31416 this one sounds interesting! Thanks for the link.
And this one controls every single LED after the other? So i would have red high, red low, green high, green low, blue high, blue low for example? That would be nice.
Like TBone said, i think the 20 mm should fit.
hank
hank's picture
The ““Sharp Eagle” aka nut light
http://budgetlightforum.com/node/40832 zoomie reviewed here a few years ago acted like that.
Cycled through high/low using individual cool, warm, and blue emitters.
I’d hoped for a 1, 2, or 3-emitter driver but no.
ggf31416
I found the review of the drop-in that uses that driver.
FYI beyond of the driver only and P60 drop-in format they also offer the PCB with the leds and optics as well as the drop-in bundled with their E6 P60 host.
mili111
I checked this one out, but i would like the Convoy S2+ host because of its smaller size and the possibility to use the short tube.
Thanks a lot anyway!
TBone
This PCB is used for S2+ triples.
The optics included is compatible to Carclo 105xx. 20 mm diameter but shorter than the original reflector. You will need a (D20*6 mm) spacer on the pill that will give you the D20 mm surface for the PCB. (Example)
