[Review] Manker T02
6 posts / 0 new
Thetasigma
[Review] Manker T02
As a fan of SxS format lights I was intrigued when I saw Manker was producing one in a 2xAA size and with 14500 capability. I purchased this for myself and thought I would share my thoughts on it for anyone else interested.
First Glance
As previously stated, this is a 2xAA SxS format life with 2×14500 capability for higher turbo and high modes. The light has a smooth matte black finish with a stainless steel bezel ring, battery position indicator markings and a split construction with the battery tube screwed to the head. The light is comfortable in the hand in overhand, flat, and sideways handholds. The e-switch has a fairly positive click and indicator lights under the switch boot. The light has a fairly stiff screwed-on clip but it results in a fairly shallow carry with over an inch of the head exposed above the pocket line.
Beam Profile
The LED used in this light is an XHP-35 available in “cool”, and “neutral” at what appears to be 5000K. My sample is relatively clean tinted with a slight greenish tint hotspot and very slight purple spill when white walled, but is overall clean in actual use, especially for a Cree emitter. The LED is well centered behind what appears to be a nice SMO reflector. The only real problem I have here is the beam from further than 5 feet has a brown or darker spot in the center, reminiscent of an eye floater, it is most notable when moving the light. Relative to the AA format this light is throwier than most with a larger reflector and higher output.
The dark spot in the center of the beam, a bit more distinct in person.
Battery Cap
This is a bit of a tricky point on side by side lights and there are various solutions with the Spy 005/007 solution being my favorite. In this case it is the same functionally as the Nitecore EC4S series with a threaded male component exposed in the sides of the center of the cap that mates into partial female threads in the battery tube. Given the smaller diameter of the threads I would like to see an extra thread or two of engagement if Manker ever upgrades this design, for better long-term reliability. An alternate solution would be a cam-lock system similar to the Sunwayman D20A’s implementation with two steel hooks in the battery pack and a cammed latch in the cap. The plus side of using this threaded style is the cap is snuggly seated against the body. The stiff springs on the cap and driver make installing the cap a bit tricky since they engage before the cap is in-place, so two fingers help to align and pull the cap in position to be threaded.
User-Interface
The light is controlled via the side mounted e-switch and is overall straight forward. 1 click turns the light on in moonlight, further single clicks advance the modes to high, and then back down to moon. Turbo and flashy modes are hidden behind a double click with Turbo being the first in that mode grouping and double clicking after brings the light back into the main sequence. What I suspect will be the main problem one might have with the UI is that to turn the light off it requires a “long press” of about a second which may be unintuitive, in my experience so far with this light it is an acceptable trade off for simple clicks controlling the modes while on. For those who like mode memory, the last used mode can be accessed from off with a long-press.
Conclusion
On the whole I like the light since I’m an avid fan of the SxS format, though it would be nice to see a revised design with a stronger battery cap. The UI is a bit different but nothing that can’t be quickly adjusted to, and loads simpler than some e-switched setups. The dark spot in the center is my biggest complaint with the light, I’m not sure if it is a common situation with this model or just my sample.
Edited by: Thetasigma on 12/07/2018 - 19:47
Streamer
Streamer's picture
Last seen: 1 month 1 day ago
Nice review of a very interesting light. That dark spot doesn’t appear to be so prominent in the first beam shot. But in the second beam shot it really shows up for sure. Thoughts on that?
I’m sure the tailcap secures adequately enough to remain water tight?
Thetasigma
It is the distance, further than 5 feet it shows up. Using it outdoors it doesn’t bother me though. I’ve got some 4000K XHP35 HI on route to try and see how they work. The battery cap has a o-ring seal so it doesn’t need to be overtightened.
rost333
rost333's picture
Last seen: 6 hours 45 min ago
Hi, could you post some pictures with the result? Thank you Wink
vit55
Last seen: 2 weeks 4 days ago
any coupon for this flashlight?
mikekoz
Last seen: 5 days 21 hours ago
Have not posted on this forum in a long time! I really like the looks of this light. Does anybody know a US source for it?
Cranston B. Snord
