Second Generation Silver Plated High Current Beryllium Copper Springs and 95+CRI SST20!
683 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 10 min ago
Wait, you meant 30 additional springs of each size too?
HONDARIDER
HONDARIDER's picture
Last seen: 3 days 13 hours ago
BlueSwordM, Have you concidered looking into the 4500K or 5000K SST-40’S. Those are so hard to come by. Maybe you could start an intrest list to see if it goes anywhere.
shirnask
shirnask's picture
Last seen: 2 hours 24 min ago
Facepalm Facepalm Facepalm
I give some away and there is some waste Tired
skinny_tie
skinny_tie's picture
Last seen: 9 hours 29 min ago
Please put me down for 10 SST-20 4000k FD2s.
trakcon
trakcon's picture
Last seen: 1 hour 27 min ago
I’m listed twice on the interest list (lines 3 & 15). Please update my totals to:
20x FD2
10x GA3
Please confirm that the 3500k you have are still GA3.
Thanks!
BlueSwordM
They’re still the same LEDs as before, as I haven’t ordered any more, so yeah, still GA3.
shirnask
shirnask's picture
Ok, now you are just messing with me. You have me on the list for the original 20 leds and the on the list again for an additional 40 leds plus the springs. Shocked
If you delete line 4 and keep line 11 it will be right Wink
BlueSwordM
iamlucky13
Last seen: 1 hour 56 min ago
BlueSwordM wrote:
And yes, I still have some 3000k and 3500k LEDs left.
So yeah, can ship the Rev 2 springs and LEDs together.
Thanks! If it’s ok then, I’d like to update my entry to include 3 x SST-20 3500K.
oweban
oweban's picture
Last seen: 5 hours 13 min ago
Got my springs today! Yay!
Question – does it make sense to “nest” them in something high-drain?
BlueSwordM
Yes. Smile
oweban
oweban's picture
Niiiice. Should I bend in the top bit like you have there?
Hoping to get the MF01 finished tonight….. FINALLY
DavidEF
DavidEF's picture
Last seen: 2 days 16 hours ago
oweban, those are either Gen 1 or Gen 3 springs. BlueSwordM seems to have indicated they are Gen 3, which are the same five coil design like Gen 1 springs, with also the top edge bent in as you see. Your Gen 2 springs were a different design, with only four coils and not bent in at the top. It has already been said that the top edge not being bent in can cause trouble by grabbing the cell and causing a gouge. So, if you feel like you can pull it off, go ahead and bend them in (and a little bit down). As far as I know, nobody has attempted that with Gen 2 springs. So if you try it, let us know how it works out!
- The YKK Philosophy
oweban
oweban's picture
Ah, I missed that – thanks for the advice! I’ll give it a shot – bought 10 of each and only neeeeeed 4.
BlueSwordM
The 1st gen and 3rd gen are the same basic design, except for a few tweaks.
The 2nd gen are different in the fact that I removed a coil from the large spring.
Not my best idea, since that made the mechanical properties worse.
oweban
oweban's picture
All good – as suggested, I’ve bent the top coil in and pressed the end down a bit, so it’s smooth.
tm07
tm07's picture
Last seen: 2 days 19 hours ago
Got my springs today thank you! Thumbs Up
KevinZA1988
KevinZA1988's picture
Last seen: 49 min 38 sec ago
So I put 3× 3000K SST-20’s under a 10507 optic in my FW3A, and wow… I’m reliving the golden age! LOVE these emitters…
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Ryzbor
Ryzbor's picture
Last seen: 8 hours 18 min ago
I wish I bought 18 of those rosy 3000K SST-20’s back then if I only know Emisar would release the D18…
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K R9080 (needs more 219B), super rosy 3000K E21A mix Skilhunt H04 on it's way
SKV89
Last seen: 8 min 28 sec ago
You can still buy those rosy 3000K SST-20 through Kaidomain. I bought several dozen of those and used them in many different lights already. I believe there is only 1 tint bin of SST-20 3000K on the market if I’m correct so they should all be the same. It gets rosy at high output but still slightly yellow at low output but better than most 3000K emitters. Has anyone measured the tint in the GB batch?
contactcr
Last seen: 2 min 9 sec ago
The group buy said J2 flux bin, Mouser has J3 flux bin now, and Kaidomain claims J4 flux bin. So I would not count on just any 3000K being the same.
BlueSwordM
Yep. The reason I chose such a low flux bin on the 3000k is that because it was guaranteed TM to be under the BBL in all cases by the Mouser rep.
