Second Generation Silver Plated High Current Beryllium Copper Springs and 95+CRI SST20!
695 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 13 hours 5 min ago
Mild coil binding does have its advantage with medium compression. It allows for very low resistance using flat top cells, but not bigger cells.
I saw this problem pop up when contactcr tried to put in a 21700, and he said not only did he have a lot of difficulty putting it in, my 6,5mm bottom small spring caused a short, melting it in the process.
So, I decided to modify the spring to be more usable, which was easy.
The large spring on the other hand… well that was a lot of work yesterday to see if the spring could handle the plastic deformation, and that is still risky. 13mm is out of the question, but 12mm height could be possible.
Just waiting an answer for the manufacturer now. They have access to simulation programs that I don’t have money to pay for Smile
BlueSwordM
So I’m just now waiting for the manufacturer’s response in regards to the springs.
Also, about the LH351Ds, some slight bad news.
My contact at Future Electronics found some good very tight binned LH351Ds in the tint bins we want… but the minimum order quantity is 5000pcs, which is a bit much Wink
So, the LH351D part of the GB is currently in limbo.
DavidEF
DavidEF's picture
Last seen: 2 days 12 hours ago
“Failure has to be an option. No important endeavor that required innovation was done without risk.” – James Cameron
“Anything worth doing is worth over-doing. Moderation is for cowards.” – Marcus Luttrell
“The best lesson I learned was to just do it. It doesn’t matter what it is, or how hard it might seem, as the ancient Greek, Plato, said, ‘The beginning is the most important part of any work.” – Richard Branson
Innocent
- The YKK Philosophy
RSlothMan
Last seen: 7 months 2 weeks ago
I am in for:
8 big springs,
8 small springs,
12 4000k SST-20
5 3500k SST-20 (if it is still possible)
BlueSwordM
Added to the list.
hodor
hodor's picture
Last seen: 41 min 5 sec ago
@BlueSwordM
Have I been added to the list? I don’t see my name. Originally requested in post 87 .
Also are there any more non-early bird 3500Ks still free? I’d like 2 more if possible.
BlueSwordM
Oh boy. This is not too good.
No more SST-20s 3500k available now.
@Hodor, you have only been added 6 of the SST-20s 3500k, as there is no more space. Sorry Sad Sad
@RSlothMan, added, except for the SST-20 3500k part. Sad
AEDe
AEDe's picture
Last seen: 18 min 4 sec ago
Why are 3500 not available? Cant find any information in OP.
g_damian
g_damian's picture
Last seen: 4 hours 53 min ago
hodor
hodor's picture
No worries. Thanks for adding the other 6.
I think it was mentioned earlier that Blue can only really buy in batches of 300 to get a good price. Unless we have enough interest for a full reel!
zcbtjwj
Last seen: 2 months 3 days ago
Can you do a waiting list in case people don’t buy what they have reserved (and if that waiting list reaches 300, there is the option to buy another batch)?
BlueSwordM
@AEDe, no more available to reserve.
People, do not worry.
Those who are on the list for the 3500k LEDs will receive them.
@g_Damian, it’s already been updated, but the update has not been posted, because the screenshot would not actually fit while being readable.
I will make the updated spreadsheet publicly available.
AEDe
AEDe's picture
I see , thanks!
Inkidu
Last seen: 7 months 1 week ago
10 big springs
10 small springs
Thanks
BlueSwordM
Added to the list.
Added a Google Drive link to the OP, and here:
https://docs.google.com/spreadsheets/d/18SyWGP08EpK5OOcv1vZbLokQGv1KojNW...
Bob_McBob
Last seen: 10 hours 39 min ago
I received the early bird SST-20s a couple days ago and stuck them in a few lights. In a D1S I get 670 lumens and 550m throw compared to 1000 lumens and 670m stock. There seems to be a tendency towards a ring around the corona with smooth reflectors, though it’s a lot more prominent in the Convoy C8. The tint isn’t horrible but it’s not spectacular either. This is an sw35 219B beside the 3500K SST-20 in the D1S.
BlueSwordM
Yeah the ring is a problem.
It makes the beam so throwy in some reflectors that it makes a ring around it.
Also, at what level were you running the test?
I’ve found that at 1A, unlike the LH351D T6, the GA3 SST-20 sits just below the BBL. Above it, it becomes rosy.
It’s way better than the LH351D, and a bit better than the PL47 without taking into account the shift of CCT.
BlueSwordM
On that note, I know that SKV89 and Bob_McBob have received their LEDs.
Knowing this, that means most people will be receiving their LEDs by Friday, and next week.
Tom E
Tom E's picture
Last seen: 53 min 44 sec ago
Got mine today! Just opened them a min ago, well taped up. I should first put one in a D1 because my attempt at a sliced SST-40 in there didn't work out so well. Also got couple C8F hosts, so these will go in one for sure, then  something smaller, not sure yet.
hodor
hodor's picture
Will the SST-20 be ok in a D1? I thought they couldn’t/shouldn’t be used in single emitter fet lights?
BlueSwordM
It should be okay, as its forward voltage is still high enough to limit current to a low enough level to not burn up.
Bob_McBob
My stock 5000K D1 draws about 6A at the tail with a fresh VTC6. The SST-20 D1S is about 5.5A with a fresh GA (trying not to push my luck).
BlueSwordM
How is the 219B not dead in an Emisar D1S though?
Its forward voltage is quite a bit lower than even the SST-20, so even someone like Tom E/DB Custom wouldn’t dare put this emitter in a FET light.
Bob_McBob
That’s an SC64c on the left Big Smile
BlueSwordM
Oh god I was worried Tired
BlueSwordM
Also, guys, because of the Chinese Holiday, the manufacturer will not be able to make the springs until February 19th.
However, I’ve prepared all of the LED orders and the envelopes to ship when I receive the springs pretty much instantly after I receive them.
contactcr
Last seen: 45 min 34 sec ago
What were the final specs? Did removing a coil make it too small?
BlueSwordM
Final specs have not been finalized for the large spring yet.
I’ve already tried this for the small spring last time, but did not work theoretically, and the manufacturer advised against doing this too for the small spring.
It should work with a 12mm height, but I’m waiting for a response from the manufacturer.
hodor
hodor's picture
!{width:100%}https://i.imgur.com/vhC8FX5.jpg!
Do you find the tint green IRL?
@BlueSwordM Any luck sourcing rosy 4000K? I didn’t realise the 3500Ks would be sent out before/separately to the 4000K.
HONDARIDER
HONDARIDER's picture
Last seen: 18 hours 43 min ago
Got my SST-20’s yesterday, Just wanted to give thanks. Very appreciative BlueSwordM. Thank you!!!!!!!!
