Hi all,
I’m sorry as I know that this has been done to death, but I’m pulling my hair out with a couple of drivers. I’m having alot of different problems, but the biggest issue at the moment is that I can’t reliably connect to an ATtiny13.
I was able to connect to and flash a driver yesterday just fine (even though the driver doesn’t work, that’s another story). As part of troubleshooting that driver I tried to flash a standard AK47 with the same firmware, to check if the firmware or flashing was the issue. Couldn’t connect. This is with a Pomona SOIC8 clip and USBASP. Tried a couple of other drivers (AK47, NANJG105A, the one I made that didn’t work), none would connect.
Resoldered all the connections from the USBASP cable to the clip, no connection.
Soldered wires directly to the ATtiny13 and clipped them to the pins from the clip. Got one connection:
*PS E:\Documents\Lights\STARmommtm\STARmommtm\Debug> avrdude -p t13 -c usbasp -n
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude.exe: Device signature = 0xffffff
avrdude.exe: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude.exe done. Thank you.*
But when I went to write the firmware, got the standard can’t connect message:
*PS E:\Documents\Lights\STARmommtm\STARmommtm\Debug> avrdude -p t13 -c usbasp -u -Uflash:w:STARmommtm.hex:a -Ueeprom:w:STARmommtm.eep:a -Ulfuse:w:0x75:m -Uhfuse:w:0xff:m
avrdude.exe: error: programm enable: target doesn’t answer. 1
avrdude.exe: initialization failed, rc=–1
this check.
Now I soldered jumper wires directly to the pins on the USBASP and crocodile clipped those to the pins soldered to the ATtiny13. Same deal as above - initially connected, wouldn’t write the firmware then wouldn’t connect again.
Tried moving the jumper from 5V to 3.3V and vice versa. Different USB ports. Restarting the laptop (Windows 10) and double checking the USBASP drivers again. Nothing works.
I’m stumped. Clearly the USBASP works and clearly I’m able to write to a chip (the one I flashed was off the sister AK47 to the one I’m currently struggling with), but the whole process has stopped working. I’ve ruled out any possible shorts/ intermittent contacts that I can think of. I’ve triple checked that the wires on the USBASP are connected to the correct legs of the ATtiny13. I’m going to go out to the garage and pull an ATtiny13 off a driver and flash it on it’s own using soldered on wires.
Any other ideas? I’m can’t finish the light I’m making until I can get a driver working and it’s either solve this mystery or pony up $30 for an lflex from Taskled (not a bad option at all, but it’s $$ I don’t have and would feel like I’m surrendering!).
thanks for the help!
