The new Luxeon V2
40 posts / 0 new
gchart
gchart's picture
Last seen: 22 min 24 sec ago
The new Luxeon V2
I just got my first Luxeon’s in and I love them. Admittedly, I haven’t tried the 4040 footprint Luxeon V’s. But I just picked up some of the 4000K (tested) and 5000K (yet untested) V2’s (the 3535 footprint version) and I must say, I’m impressed.
I replaced a 4000K 70CRI V5? XP-L2 in a 3.08A Convoy S2 with a smooth reflector. Not sure where the battery is at voltage-wise, but I measured 1096 lumens for the XP-L2. I swapped in the Luxeon V2 and measured 1054 lumens, only a 42 lumen difference. But the beam and tint and tint consistency is spectacular. No green, no yellow, no tint shift. Just bright, beautiful, creamy white. Oh yeah, a new favorite. And they were < $2 each. And fit on a standard 3535 board. Heck yeah.
Edit: beamshot in post 6
Edited by: gchart on 12/10/2018 - 23:50
chadvone
chadvone's picture
Last seen: 5 min 32 sec ago
Must see.
Where did you get them?
Jtm94
Last seen: 1 hour 52 min ago
Hmm. What is the V2 vs the V??
chadvone
chadvone's picture
Think it’s smaller
KawiBoy1428
KawiBoy1428's picture
Last seen: 54 sec ago
chadvone wrote:
Must see.
https://www.mouser.com/search/refine.aspx?Ntk=P_MarCom&Ntt=181654621
KB1428 “Live Life WOT”
gchart
gchart's picture
Beamshot, though I don’t feel that it does justice to the Luxeon V2
Left to right: Convoy M1 with 70CRI XP-L 5000K, UltraTac A1 with 90CRI 219B (I thought 4000K but maybe not), Convoy S2 smo with Luxeon V2 70CRI 4000K, Wuben E05 with 90CRI XP-L2 80CRI.
gchart
gchart's picture
Here’s another between the Luxeon V2 and the XP-L2 4000K 90CRI:
Jerommel
Jerommel's picture
Last seen: 1 month 5 days ago
So is it a different LED than the V or is it the same but with a 3535 footprint?
2Q19
gchart
gchart's picture
It seems to be quite similar, but perhaps not the same. I’m anxiously awaiting proper tests. Anyone care to volunteer? Djozz? Texas Ace? Koef3? Maukka? I’d probably donate some if there’s interest.
http://budgetlightforum.com/node/62683
chadvone
chadvone's picture
Thanks, I like it also. Not sure about this “Wuben E05 with 90CRI XP-L2 80CRI”
I would be interested in seeing someone test this too.
Jerommel
Jerommel's picture
XP-L2 can work well with a frosted or pebbled TIR though.
2Q19
Jerommel
Jerommel's picture
Thanks.
So it has a smaller die: V2 = 2mm² and V = 4mm²
2Q19
led4power
led4power's picture
Last seen: 8 hours 3 min ago
Luxeon V has 4mm2 die, V2 has 2mm2 die.
contactcr
Last seen: 2 hours 49 min ago
Agree, not sure I was able to explain it well but glad you had similar results.
This LED should compete with any 70 CRI LED out there and has a good balance of output, tint and uniformity with a good price.
Agro
Last seen: 9 hours 6 min ago
Quite a few 2 mm² LEDs in 3535 factor showed up recently…
  • Luminus SST-20
  • Osram PM1
  • Luxeon V2
  • (not sure) Nichia 119D / 219D
Nice!
It’s flip chip, right? Does it have any throw?
gchart
gchart's picture
Yeah, I think its a flip chip:
Comparing two Convoy S2’s side by side; one with LH351D and one with Luxeon V2, the throw of the Luxeon V2 kills the LH351D. But that doesn’t take much, the LH351D is a very floody LED.
I’ve had a lux meter (UNI-T UT383BT) for about a year, but had never taken it out of it’s package until today. I tested just a couple lights before running out the door this morning, and unfortunately I didn’t have quick access to the Convoy S2 with LH351D in order to get numbers on that; hopefully I can tonight. Here’s the 3 I was able to test (so you have something to compare against in case my numbers are skewed):
  • Convoy C8 with 3.08A Qlite and XP-L HI V2 5000K: 2818 lux at 5m → 70,450 lux
  • Convoy M1 with 3.08A Qlite and XP-L V6 5000K: 755 lux at 5m → 18,875 lux
  • Convoy S2 (smooth reflector) with 3.08A Qlite and Luxeon V2 4000K: 549 lux at 5m → 13,725 lux
Do those numbers sound right? Since these aren’t real throwers (perhaps with the exception of the C8), should I measure at 3m (or even 1m) instead of 5m?
contactcr
Without being scientific it does appear to have more throw than a LH351D but with the dome on I don’t think anyone would consider this a thrower. Not sure how it performs dedomed and I think thus far only gchart and I have even tried them in a flashlight.
I have a C8F with 3x Luxeon V and when I compare it next to a LH351D of the same type there isn’t a huge difference in the overall beam. It’s a more intense hotspot but not by a huge amount.
gchart
gchart's picture
If I’ve got time tonight I’ll try getting side-by-side numbers with the same flashlight setup using Luxeon V2, LH351D, XP-L, and XP-L2. I’ll see what else I can scare up, maybe a XP-G2, XP-G3, SST-20, XP-L HI. I’m pretty sure I’ve got all of those on hand, it’s just how much time I’ve got to swap in and out a bunch of different LEDs.
contactcr
Here’s a mechanical comparison of the domes of the SST-20 and Luxeon V2. SST-20 is quite a bit smaller in all dimensions and LH351D is slightly larger in all dimensions.
contactcr
I suspect this wont be too helpful but I measured two C8F’s at 380mAh (1×7135)
LH351D 4000K 90CRI
131 lux
Luxeon V2 4000K 70CRI
268 lux
Measured at maybe ~15ft
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 25 min ago
Wow. Having 1/2 the die size REALLY helps with throws.
Then again, the LH351D is a 90CRI emitter, so the results aren’t TOO accurate, but are representative of real life.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
gchart
gchart's picture
Ok… here’s some data points. I can’t say that these will be consistent with what others may gather, but they should provide a fair comparison against each other since they all came from the same flashlight, same battery, same physical measuring setup, etc.
All tests were done with a Convoy S2 (not S2+) with a smooth reflector, 3.08A Qlite driver, and a freshly charged Samsung 30Q:
  • Luxeon V2 4000K: 11,898 lux at 1059 lumens
  • XP-L V6 5000K: 8,604 lux at 1202 lumens
  • SST-20 Cool White: 17,919 lux at 933 lumens
  • XP-L HI V3 5000K: 14,670 lux at 1007 lumens
  • LH351D W6 5000K: 6930 lux at 1161 lumens
These tests done at ~10 seconds and 3 meters.
chadvone
chadvone's picture
Do you have 5 lights or you swapping led’s?
gchart
gchart's picture
That was from swapping LEDs into the same light, driver, battery, etc.
chadvone
chadvone's picture
Wow, thanks for the effort. I am interested in these but just don’t know where I would use one.
Agro
Thanks!
The comparison to SST-20 is especially telling. V2 gets 11.2 lx/lm while SST-20 gets 19.2. So….in my book it counts as a pure flooder LED.
djozz
djozz's picture
Last seen: 7 hours 16 min ago
Nice direct comparison gchart! Cool
gchart
gchart's picture
I was pretty shocked by that, I bought 10 of the SST-20 a while back when they were first announced and all that was available was cool white. But I strongly dislike cool white, so I never ended up putting them in anything. I’ve heard the chatter and knew they could throw, but I just didn’t expect the lux to be that much higher, even over the XP-L HI (with the SST-20 still having it’s dome on).
KawiBoy1428
What if you put it up against a XP-L HI V3 1A 6500k? Seeing how light meters supposedly read/register CW higher?
ImA4Wheelr
Last seen: 1 day 11 hours ago
Maybe this emitter is better suited for aspheric and recoil lights.  I think I read somewhere in djozz's thread that something like 90% of the output is goes forward.  Wouldn't that mean less light hitting the reflector (in a reflector light) which would result in less throw?
Agro
ImA4Wheelr wrote:
Maybe this emitter is better suited for aspheric and recoil lights.  I think I read somewhere in djozz’s thread that something like 90% of the output is goes forward.  Wouldn’t that mean less light hitting the reflector (in a reflector light) which would result in less throw?
The radiant power chart doesn’t seem much different from SST-20-W.
