(Cancelled)D1S+, CSLNM1.TG LED, 850lm, 320kcd
378 posts / 0 new
Nicolicous
Nicolicous's picture
Last seen: 7 min 32 sec ago
Dale
How much for Seanna optic and where to get them?
I’m tempting
Nico -.-
DavidEF
DavidEF's picture
Last seen: 4 hours 38 min ago
DB Custom wrote:
Ok, yeah, this one has a separate negative contact pad for the leads from the driver so it’s not the pita the Black is. Wink
Will probably build a PZL driver for it… reversing e-switch 7 modes sounds good to me.
I didn’t get the centering ring but will use his old ones. The FR G10 1/2” thick board my Seanna mounts to is threaded onto the light engine part of the Courui, as such it can be threaded up/down to dial in proper focal length to the Seanna optic. Should work. (with this set up there’s really no need for a centering ring, actually)
If I’m not mistaken, the Seanna optic is capable of focusing a die this size to 1º… should prove interesting. There is a pre-focus TIR in the base with a 6” Fresnel lens up top. Ledil claims a peak candela value of up to 800Kcd, I’m getting 666Kcd from the HI if I remember correctly.
Ledil says it will do 1196 cd/lm from a Black Flat. At 94% efficiency. 1º beam, no estimate on Kcd on the Black Flat. No listing on the White Flat. By contrast, they say the XP-L HI makes 492 cd/lm at 2º.
PZL driver? People still use those? Refresh my memory please. What does the PZL driver have that more recent drivers lack? I don’t remember it being really special when it came out, but then again, I could have ended the sentence with “I don’t remember…” and the effect would be the same. Facepalm
- The YKK Philosophy
DB Custom
DB Custom's picture
Last seen: 15 hours 9 min ago
Nico, I think the Seanna is a bit difficult to come by… seems they were over $60 even a few years ago.
David, the PZL is a 2 channel driver built with all 7135 chips, so it’s easy to set the regulation value within the scope of the White Flat. The reason it’s called puzzle is that the text indicating the components sits inside the ATTiny pad, so if you put the ATTiny on first the rest of it is a puzzle. Wink
People still use em? Well, with the resurgence of these Osram emitters the need to keep current controlled brings back even the Qlite’s. Wink Besides, I’m not people…. Silly
Wight’s PZL board…
DavidEF
DavidEF's picture
Just looked at the thread again for the PZL driver. It just reminded me that not only was wight always coming up with the latest and greatest drivers back then, he always stubbornly insisted on his drivers being aesthetically designed as well. Things had to line up, have symmetrical spacing, etc. Every driver was a work of art!
DB Custom
DB Custom's picture
Yeah, “back then” it seemed like I was the guinea pig, I built everything he and MattAus came up with, including a go at the Knucklehead driver. lol
With my memory, “back then” was yesterday, I still use those drivers all the time, even still have some of the huge 07N02 MOSFET’s…
If I recall correctly, Comfychair started all that. I even learned to flip the big 07N02 upside down on a Qlite in those days…
Tom E
Tom E's picture
Last seen: 16 hours 6 min ago
Yep, comfy set the stage, wight wrote it down in traces. The old HD2010 drivers were the inspiration as I recall - pure spring melting, LED desoldering power!
DB Custom
DB Custom's picture
Indeed, and the HD2010’s reflector would exploit that welding class in a hurry…
DB Custom
DB Custom's picture
I really don’t want to know exactly how much I’ve spent on driver components, boards, li-ion cells and flashlights. I don’t. But I know it’s in excess of (Edit: lets just say it’s excessive). Blushing Facepalm
DB Custom
DB Custom's picture
Speaking of the hateful HD2010, I once took this outside of the box approach to bring the emitter into the reflector for proper focus. That was the light that started me modding, it didn’t work right out of the box and the extended process to get it working and working well taught me a lot… lol
DB Custom
DB Custom's picture
For you David… I don’t think we ever got the Knucklehead working… not for long anyway…
oh, not trying to call you a knucklehead just reminiscing about the drivers those guys came up with… this one was one of Matt’s I think (MattAus)
DavidEF
DavidEF's picture
Yeah, back then I couldn’t understand anything you guys were talking about with those drivers, so no surprise I don’t retain any knowledge from those times. I “remember” the knucklehead driver, but I don’t know anything about it unless I go back and read about it again.
DB Custom
DB Custom's picture
I kinda got pushed into thinking about these emitters a little while ago, and the idea came to me to use the White Flat’s in a reflectored triple. I like small well made lights, anyone know where I can get a good price on a Brass MecArmy PT16? Big Smile
joechina
Last seen: 11 hours 45 min ago
DB Custom wrote:
… The reason it’s called puzzle is …
Wight’s PZL board…
Thank you for the information about the drivers.
I thought: Hm, PLZ that is “Postleitzahl” (= German for postal code), maybe its something else. Smile
Lexel
Lexel's picture
Last seen: 5 min 39 sec ago
I put something together
testing out the right values for the CC part will need some testing
the 2 blank copper areas are to solder a piece of copper wire likely hammered flat to spread heat better
DavidEF
DavidEF's picture
So, this driver needs a heat spreader? Wow! Shocked
Thanks Lexel! Are you planning to build/sell these? If so, when do you think it will be done testing and ready to buy? Big Smile
SKV89
Last seen: 3 hours 41 min ago
You should sell these to Hank so he can make D1S with White Flat.
Lexel
Lexel's picture
Hank is right now not interested in white flat D1S, I tried to offer him driver but he said
Quote:
Currently, we have no plan to do the D1S+ project.
it may happen later we will see
SKV89
hmmm I wonder why. Seems like there should be enough demand. Maybe he’s having a hard time centering/focusing it?
scr79423
Last seen: 1 week 20 hours ago
!{width:100%}http://www.metronixlaser.de/bilder/flashlight/D1S_white_flat.png!
when will this be ready for order? also will it be a 5A buck driver?
Geuzzz
Geuzzz's picture
Last seen: 4 min 28 sec ago
Any news on a CC driver I can fit in flat white D1s?
gchart
gchart's picture
Last seen: 5 hours 46 min ago
Any updates on your driver, Lexel?
I put one together, albeit much more rudimentary than yours. 5x CN5710 (dual channel: 1+4) for 5 amps linear. Working good so far. Without any reflector height tuning, got 958 lumens & 273k lux with a Flat White 1mm² (vs 1540 lm & 127k lux stock driver with XP-L HI)
scr79423
how much for this driver? and do you ship to Thailand?
!{width:300px}http://www.ghart.com/blf/drivers/5a_d1s_driver.jpg!
gchart
gchart's picture
scr79423 wrote:
how much for this driver? and do you shop to Thailand?
gchart wrote:
I need to do more testing before I’d consider selling them. I sometimes ship internationally. But international package shipping from the US is quite expensive too, ~ USD $13.54 just for shipping.
scr79423
13usd is fine as long as it works
gchart wrote:
justanotherguy
Last seen: 21 min 50 sec ago
while the driver is being discussed, how does my recent purchase compare performance wise to what’s being tossed about here…?
Click
anyone in NE ILLinois into get togethers?
BlueSwordM
BlueSwordM's picture
Last seen: 7 hours 9 min ago
About the same.
justanotherguy
BlueSwordM wrote:
About the same.
Thanks BlueSword.. I hate to miss out on something… This thing is pretty dam impressive for such a small light… !
Th558
Last seen: 1 day 2 hours ago
What does 8 amp pulsed mean. Even if I use an ncr18650b or equivalent cell it’s still not safe for the osram 1mm??
Lexel
Lexel's picture
I can sell a few prototypes
Price as usual is 12€
Anduril or NarsilM as firmware
shipping is 1.4$ from here untracked
5$ tracked with 25€ loss insurance
v2.0 I made some minor improvements from the original prototype
any recommondation what to change?
justanotherguy
This allows the D1 to run the black flat LED, as proposed in this canceled project …correct?
IS this a difficult LED to pop in to the D1?
I am running a 300kcd GT mini right now………but…….
