(Cancelled)D1S+, CSLNM1.TG LED, 850lm, 320kcd
379 posts / 0 new
SKV89
Last seen: 29 min 2 sec ago
For sure will buy one. Also would like to buy centering ring and driver separately too.
What chromacity bin and flux bin is this emitter? Will you be selling these on your website?
As a suggestion, I would love to see a 21700 usb rechargeable version. Some of my less hardcore friends won’t buy unless it has built-in recharge.
bilakos10
bilakos10's picture
Last seen: 10 hours 42 min ago
I would be more than interested in a centering ring + driver kit.
My daily deals thread: ☢ [Gearbest.com Special Deals]
If you need any coupon code, just leave a reply on the thread.
g_damian
g_damian's picture
Last seen: 9 hours 52 min ago
interested
Vaxd
Last seen: 11 hours 44 min ago
Definitely interested
ZozzV6
ZozzV6's picture
Last seen: 3 hours 51 min ago
Tried this led with D1. It simply doesn’t have good enough reflector. It top half and bottom half has a little different focal point whith doesn’t matter with larger led like XP-L HI. I played with focusing for hours.
It can’t get any better than this.
Jerommel
Jerommel's picture
Eraursls1984 wrote:
Jerommel wrote:
This LED begs for a current regulated driver.
That’s what I was thinking, but for time and money I would expect just a firmware limit on the same driver.
Yeah, i get the same impression..
And then you still need a topped up cell at 4.2 Volts to get maximum output..
2Q19
Jerommel
Jerommel's picture
mrheosuper wrote:
Pavlo wrote:
fjass wrote:
A regulated D1S with the new osram emitter would be my ideal compact thrower. I don’t guess Emisar will ever do boost driver lights because it wants to be an inexpensive brand though.
How much more expensive would it be to use a buck/boost driver? I would pay 20$ more. My guess is the other hesitation is that it would probably not have a ramping UI. If it was stepped ramping with good spacing, that would be good enough for me.
Also curious what the throw would be like in a D1 using this emitter
maybe 20$ more when using buck driver and white flat led, but not anyone willing to spend more 20$ than stock one
my wild guess this light is 5-10 bucks more expensive than stock d1s
Linear FET CC driver shouldn’t be much more expensive though..
2Q19
zeroflow
Last seen: 3 days 2 hours ago
Interested Thumbs Up
chadvone
chadvone's picture
ZozzV6 wrote:
Tried this led with D1. It simply doesn’t have good enough reflector. It top half and bottom half has a little different focal point whith doesn’t matter with larger led like XP-L HI. I played with focusing for hours. It can’t get any better than this. !{width:70%}http://img2.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2611...!
Thank you for this, might of saved me some money and time.
808Hi
Last seen: 6 hours 12 min ago
Interested
ZozzV6
ZozzV6's picture
The D1S is good BTW. Much better reflector than GT mini.
alex64
alex64's picture
Last seen: 1 hour 46 min ago
Interested.
Jerommel
Jerommel's picture
Judging by the picture, it seems the LED sits too far forward relative to the reflector.
I can see the beam get narrow half way and then get wider again.
Looks like you should try some extra shim between reflector and LED board.
2Q19
tamaske
interested
Tony Cape
Tony Cape's picture
Last seen: 1 day 6 hours ago
Just when I am about to order a d1s now I see this. I will definitely wait for this version.
Rdubya18
Last seen: 16 hours 58 min ago
Yes , I have all the others , so I gotta have this one !
ZozzV6
ZozzV6's picture
Trust me I tried everything. Smile
If I move reflector up then the beam starting to get parallel-ish but the corona starting immediately getting huge amd brighter and the hot spot also getting bigger and dimmer. Like the reflector has two parabolic curve.
I can’t explain it better. Maybe with this image help. This is with XP-L HI. The edge of reflector and the area around close to the led is in focus. But If I go farther the white area getting yellow and the yellow area near led getting white. With white flat it is more noticable.
shirnask
shirnask's picture
Last seen: 3 min 50 sec ago
Interested
Jerommel
Jerommel's picture
Yeah, i believe you.
It just looked like that in the picture.
Hmmm… Doesn’t look like it should..
Any anomaly in the optics will become very noticeable with this Flat White 1mm².
I have the same problem with a narrow beam TIR optic i wanted to use for the White Flat 1mm².
Seemed to work well with dedomed XM-L2 but it’s a messy compromise at best with this little LED
I also wasted a lot of time on trying to get it right..
I would have expected a better reflector in your Emisar though.
2Q19
Harborseal
Last seen: 2 hours 10 min ago
Interested.
ZozzV6
ZozzV6's picture
I doesn’t blame them. It designed for XP-L HI and it is perfectly good tor that. Maybe the big corona what show something isn’t perfect But 48 kcd still very good for this size.
twisted raven
Last seen: 1 hour 39 min ago
Perhaps try the 2mm white flat in it.
bquinlan
Last seen: 2 hours 36 min ago
I’ll buy one.
ZozzV6
ZozzV6's picture
I will buy some so I will try them in some lights.
Aviationtech
Aviationtech's picture
Last seen: 4 hours 32 min ago
Interested
Shelf Queen
Shelf Queen's picture
Last seen: 11 months 2 weeks ago
I’m in for one D1S+ Thumbs Up
djmcconn
djmcconn's picture
Last seen: 9 hours 58 min ago
I’m in.. Take my money!
CJ Avlis
Last seen: 16 hours 53 min ago
Look…I’m waving money at you.
djmcconn
djmcconn's picture
Oh no, we don’t have a flashlight problem
giorgoskok
giorgoskok's picture
Last seen: 1 day 19 hours ago
Yes ! Totally interested in D1,D1s,D4,D4s with “white flat” Love
