(Cancelled)D1S+, CSLNM1.TG LED, 850lm, 320kcd
378 posts / 0 new
ZozzV6
ZozzV6's picture
Last seen: 1 hour 12 min ago
That os just 4.2A. Far from the led peak performance.
Geuzzz
Geuzzz's picture
Last seen: 12 min 34 sec ago
To bad. Thnx for trying Hank. Keep up the good work.
Satan@103TFS
Last seen: 43 min 42 sec ago
Hank what about 21700/26650 version of D1s with XPL Hi ?
ZozzV6
ZozzV6's picture
Or a single led tube light with reflector.
luminarium iaculator
luminarium iaculator's picture
Last seen: 20 hours 5 min ago
Hank Wang wrote:
After some more test, we decide not to provide the D1S+ due to the issues below:
1. With the D1S original driver, when you use the 3.6V cell, you can get 320kcd without a doubt.
2. But when to limit the driver current, the driver simply can not give desired 5A current
to the LED, thus the LED is either over-driven more than 5A, or under-driven below 5A.
That is why we are not able to offer D1S+, sorry for the problem and initial hype.
But we will still offer this LED on the Noctigon MCPCB.
Regards,
Hank
Where is the link? You don’t have that updated on your web site.
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
Niko
Last seen: 5 days 21 hours ago
Hank, can you offer emitter on pcb with center ring.
this is good for modding
akoposilester
akoposilester's picture
Last seen: 15 hours 6 min ago
I will get one
FL Newbie
Rdubya18
Last seen: 20 hours 54 min ago
Now I’ll have to buy more lights to cope with my emotional distress.
nokoff
nokoff's picture
Last seen: 5 hours 36 min ago
Now I know what Ralphie must’ve felt like in “A Christmas Story” when the neighbor’s dogs ruined their Christmas turkey dinner.
“The heavenly aroma still hung in the house. But it was gone, all gone! No turkey! No turkey sandwiches! No turkey salad! No turkey gravy! Turkey Hash! Turkey a la King! Or gallons of turkey soup! Gone, ALL GONE!”
Nokoff..still Made in China 山寨主義
SKY69
Last seen: 7 hours 20 min ago
Too bad it sounded like the perfect thrower. Thanks Hank. I know you will come up with something that I will be interested in.
optosolis
optosolis's picture
Last seen: 15 hours 32 min ago
maybe someone else can come In and still make something like this for us all.
Okluma DC2 Ti, Virence AT Wizard Pro E21A Quadtrix 6500/5000k Mixed 9080, Jetusolis 6500k 9080, JetE21A 4000k 9080, JetE21A ‘Red’ HCRI Led.
zak.wilson
Last seen: 6 hours 54 min ago
Output for the White Flat seems to be about equal between 4.5A and 5A in the test results from djozz. Above 5A, it starts falling. A 4.2A driver wouldn’t be giving up anything you could see with the naked eye.
I’d love to see a buck driver for the D1S to better support emitters like the White Flat, SST-20, and 219D. I am perhaps less interested than some in hitting the absolute peaks, as I spend more time using my lights with my eyes than with a luxmeter.
Ceilingbounce – flashlight testing and runtime graphs for Android
Pavlo
Last seen: 15 hours 18 min ago
Ditto, a Buck driver for all the Emisar models would make them all winners in my book.
Jerommel
Jerommel's picture
Last seen: 2 weeks 6 days ago
No, not far from the peak performance at all actually.
The difference between 4 and 5 Amperes in output numbers is hardly worth overdriving this LED so hard.
You could make it 13 × 7135 though, and get 4.55 Amperes, which is a good compromise.
But i doubt there’s enough room on a single sided driver board for so many 7135’s.
But then again, why not design a dual sided driver board?
This little White Flat has a nice low Vf so it’s suitable for 7135 drivers.
2Q19
Jerommel
Jerommel's picture
Buck drivers always eat up a little Voltage, they have a minimum voltage drop.
Maybe the same as the old tech 7135 though, which have a minimum voltage drop of 0.15 Volts.
But more expensive and you need more space (hight) for the inductor, especially with high currents.
2Q19
DB Custom
DB Custom's picture
Last seen: 1 hour 23 min ago
Looks like it’s time to go back to QLites and stacking chips…
scr79423
Last seen: 5 days 15 hours ago
Hank please use this led in the D4S, it should work with the stock driver and get super results
polarweis
polarweis's picture
Last seen: 7 hours 18 min ago
That would be my first d4s then Smile
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
Tom E
Tom E's picture
Last seen: 1 day 16 hours ago
13 chips would be the hot setup, or 12 380's. I think somewhere there's an 7+1 or 8+1 OSHPark driver, but probably not to accommodate the Attiny85, or have DEL's tweaks to get the 25/45/85 working more reliably. The most important issue is having the 4.7R before all uses of Batt+ -- this was the biggest issue. Of course the FET gate stuff isn't needed with no FET. Pretty sure I've done 2 channel ramping with a 7+1 or 8+1 style driver, as long as you use the Eagle claw 7135's, least for the single.
zeroflow
Tom E wrote:
13 chips would be the hot setup, or 12 380’s. I think somewhere there’s an 7+1 or 8+1 OSHPark driver, but probably not to accommodate the Attiny85, or have DEL’s tweaks to get the 25/45/85 working more reliably. The most important issue is having the 4.7R before all uses of Batt+ — this was the biggest issue. Of course the FET gate stuff isn’t needed with no FET. Pretty sure I’ve done 2 channel ramping with a 7+1 or 8+1 style driver, as long as you use the Eagle claw 7135’s, least for the single.
If the size is the same as the D4, I’ve made a 1+2+5+moon driver with the 85. If you want to upgrade, you could stack the inner 3 7135 chips and get a total of 11 in a 2+4+8 config to get up to 3.8A
ZozzV6
ZozzV6's picture
Exactly!
I have a Convoy S8 with this led but sure I will make a 13 or 14×7135 C8
Jerommel
Jerommel's picture
Waiting for sub ohm sense resistors here, to stack on LD25 drivers.
Aiming for 4 – 4.5 Amperes.
2Q19
Nev
Last seen: 5 hours 53 min ago
Hey Hank , stop teasing us, first you get us exited by saying you’ll be making a D7 & then tell us it’s a no go , then this D1s+ which is also not gonna happen. Crying
Please don’t tease us anymore ,in future please keep new developments to yerself until it’s up & ready & gonna be for sale.
This isn’t a negative whine because I highly rate your lights & consider them at the top of the pile & I can’t wait for more new ones but I get so disappointed when I think the next best thing is coming & find out it’s not.
chinooker
chinooker's picture
Last seen: 2 hours 13 min ago
Yeah, I was so bummed when I found out Santa uses drones rather than reindeer. Sad
tm07
tm07's picture
Last seen: 1 hour 30 min ago
+ Thumbs Up
nokoff
nokoff's picture
that’s the point of a feeler, it wasn’t a promise. They want to gauge interest and most of us like to get prepared. I don’t mind feelers
I still think he can do it; there are options others have given. Maybe we will see something even better come out of this.
Hank can do it better and way less expensive than a custom modder so I’ll wait to see what happens. I’d also like a D4S with these emitters Smile
Nev wrote:
Hey Hank , stop teasing us, first you get us exited by saying you’ll be making a D7 & then tell us it’s a no go , then this D1s+ which is also not gonna happen. Crying Please don’t tease us anymore ,in future please keep new developments to yerself until it’s up & ready & gonna be for sale. This isn’t a negative whine because I highly rate your lights & consider them at the top of the pile & I can’t wait for more new ones but I get so disappointed when I think the next best thing is coming & find out it’s not.
Jerommel
Jerommel's picture
Hmm.. The D1S is begging for an LED like the White Flat 1mm², and it would definitely sell.
But the White Flat 1mm² is begging for a current regulated driver, which is not (yet) available for Emisar.
But the trend in LED land is low Vf, so it’s time for Emisar to get a current regulated driver available.
It shouldn’t be that much more expensive than the DD driver i.m.o.
And it will open the door to more choice in emitters, like Nichia 219B V1 for the quads, without risking their lives.
The electrical path can be optimized as far as you wish, and you can use the highest drain cells.
Longer run times in the highest modes without immediately losing output.
Come on Hank, get some proper drivers for your sweet little lights.
I might even buy one !
2Q19
hIKARInoob
hIKARInoob's picture
Last seen: 5 hours 3 min ago
D7 cancelled. D1S+ cancelled. I conclude Hank Wang only produces quality lights without consumers being guinea pigs. Excellent. Thumbs Up Cool
polarweis
polarweis's picture
which driver should i use with this led? im thinking about putting is in a c8+ or maybe L2.
DavidEF
DavidEF's picture
Last seen: 3 hours 45 min ago
It depends on what you want from the driver. If you want the best, most efficient driver, get a L4P driver tuned to the proper current. If you just want it to be “regulated” and have a decent UI, you should get a driver that uses AMC7135 chips for power, PWM for lower modes, and Anduril firmware.
- The YKK Philosophy
