(Cancelled)D1S+, CSLNM1.TG LED, 850lm, 320kcd
351 posts / 0 new
Hoop
Hoop's picture
Last seen: 11 hours 55 min ago
DavidEF wrote:
you should get a driver that uses AMC7135 chips for power
Have you tried this? I’ve only tried with two different generic nanjg drivers so far but the 2mm white flat didn’t light up at all with those.
djozz
djozz's picture
Last seen: 5 min 58 sec ago
My mini-GT driver seems to have lost the 7135 part of the ramping after I tried the 2mm2 White Flat (it is still gone with the new led, a dedomed XP-G2). It seems to make little sense if the White Flat with its low voltage was the cause of the damage, but after what you noticed with the NANJG driver I tought it’d be relevant to mention here.
Marc E
Last seen: 2 days 2 hours ago
Hoop, do your nanjg drivers still work?
ZozzV6
ZozzV6's picture
Last seen: 26 min 2 sec ago
I have a Convoy driver with 9×7135 and 1mm2 white flat in an S8. It works fine.
djozz
djozz's picture
Good to hear, I did not wish to cause panic, was just sharing my observation, the damaging of the mini-GT driver may not have anything to do with the 2mm white flat.
Hoop
Hoop's picture
Both seem dead. Neither work with XP-L HI. They were new/untested prior to this test. Not sure if either had E-switch firmware but I doubt it.
DavidEF
DavidEF's picture
Last seen: 21 hours 11 min ago
Ah! Yikes! Sorry. I haven’t tried it, and I wouldn’t think an LED could kill a driver like that. Shocked
- The YKK Philosophy
Marc E
I didn’t either, and have a 2mm on the way to use with a 7135 based driver.
Hoop. Djozz, given your unfortunate shared experience i thought it prudent to start a new topic:
http://budgetlightforum.com/node/64252
Hope you don’t mind?
nokoff
nokoff's picture
Last seen: 28 min 58 sec ago
He should just use one of these. Is it really $10 stopping it or is there an issue with driver size and the D1S. He is hopefully redesigingim it a bit for a 21700 anyway.
LD-4 drivers
Nokoff..still Made in China 山寨主義
noboneshotdog
Last seen: 46 min 9 sec ago
“LD-4 drivers”:https://led4power.com/download/4621/
Ya, just design a whole new light. At least he knows what the people want. A 21700 Oslon compact super thrower. Thumbs Up
Thier ain’t no bones in a hot dog. F. York
Agro
Last seen: 3 hours 32 min ago
Thank you Hank for an update. It’s sad to learn you can’t do it, but I like your openness.
I suggest that you look at Texas Commander driver. It’s in a beta state. And may not deliver the current that you need. But using Led4Power trick of putting the FET on MCPCB should solve the issue and make it easily handle 5A, probably 8A for 2mm² variant as well. You would still have to put the work of taking it out of beta and into production…but it seems you’re more than capable of doing so.
Jerommel
Jerommel's picture
Last seen: 2 months 4 days ago
DavidEF wrote:
polarweis wrote:
Jerommel wrote:
Hmm.. The D1S is begging for an LED like the White Flat 1mm², and it would definitely sell.
But the White Flat 1mm² is begging for a current regulated driver, which is not (yet) available for Emisar.
But the trend in LED land is low Vf, so it’s time for Emisar to get a current regulated driver available.
It shouldn’t be that much more expensive than the DD driver i.m.o.
And it will open the door to more choice in emitters, like Nichia 219B V1 for the quads, without risking their lives.
The electrical path can be optimized as far as you wish, and you can use the highest drain cells.
Longer run times in the highest modes without immediately losing output.
Come on Hank, get some proper drivers for your sweet little lights.
I might even buy one !
which driver should i use with this led? im thinking about putting is in a c8+ or maybe L2.
It depends on what you want from the driver. If you want the best, most efficient driver, get a L4P driver tuned to the proper current. If you just want it to be “regulated” and have a decent UI, you should get a driver that uses AMC7135 chips for power, PWM for lower modes, and Anduril firmware.
It has to be an e-switch driver for the Emisars.
I think Lexel may have something available.
I’m still waiting for led4power’s e-switch version of his FET CC driver…
But iirc Emisar uses 20mm drivers?
Either way, i’m guessing there are a few people on BLF who would be more than happy to come up with a suitable driver and PCB layout, if Hank can’t find a solution.
2Q19
Tom E
Tom E's picture
Last seen: 1 hour 14 min ago
Yep, the e-switch is the issue for those drivers. If the driver designers didn't take into account parasitic drain, an e-switch may never work on that driver design.
Again, our ramping UI's should work fine with a 7135 bank + 1, or even without the +1. I got NarsilM working on a FET only driver because the 7135's were constantly getting blown - yes, lots of amps for 16 XHP50's...
Frumious
Last seen: 2 weeks 5 days ago
Interested. Any idea of the #K? I like NW in the 4000K to 5000K range.
Gerrh
Last seen: 53 min 31 sec ago
I'll take one!
10fp
Last seen: 3 weeks 18 hours ago
i`ll take one !
BLF A6
a few C8`s,
HS 802, dd SST40 @4.6 amps,
P30,
Emisar D1s xp-g2 dd S4 2b
S70s,
UT02 - 5 amps and luv it ! with E2 3C
Klarus G35
Maxtoch New Sniper M24 dd U3
MF02 ,
i think iv got it covered !
10fp
Hank Wang wrote:
After some more test, we decide not to provide the D1S+ due to the issues below:
But we will still offer this LED on the Noctigon MCPCB.
Regards,
Hank
Hank , whats the link to this LED / mcpcb please
BLF A6
a few C8`s,
P30,
S70s,
Klarus G35
MF02 ,
HONDARIDER
HONDARIDER's picture
Last seen: 12 hours 55 min ago
Type in LED4POWER. Think they are on their home page.
Hank Wang
Last seen: 3 hours 24 min ago
Regards,
Hank
Here is the code, we have also made some gasket for this particular LED
www.Intl-Outdoor.com, Noctigon, Emisar, flashlight components.
scr79423
Last seen: 23 hours 41 min ago
Hank Wang wrote:
Regards,
Hank
Here is the code, we have also made some gasket for this particular LED !https://intl-outdoor.com/images/20181226103113.jpg!
How to order? it’s not on intl-outdoor.com
10fp
Hank where is the CODE ?? i want to order one can`t see it on your site
BLF A6
a few C8`s,
P30,
S70s,
Klarus G35
MF02 ,
Hank Wang
I do not mean the discount code, but the
label code on the package, CSLNM1.TG LED in stock now.
djozz
djozz's picture
Nice, I think people will be very interested in the gasket when buying this led. Will they be sold separately as well?
komeko
komeko's picture
Last seen: 16 min 48 sec ago
Hank Wang wrote:
I do not mean the discount code, but the label code on the package, CSLNM1.TG LED in stock now.
Are you planning to sell a version with a warmer color, some 5000K?
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, GTmini, SDmini, Mini AAA, TIP CRI, M43, H1, H03, TC20, TN40S, TN42, V6, UT01, H600Fw, SC600W
ZozzV6
ZozzV6's picture
Hank can you make gasket for 7mm and 9mm hole reflector also? This is the two most common hole size.
scr79423
Hank please put oslon white in the Meteor and D4S!
scr79423
Does anybody know if i use a Sanyo GA in the D1S with oslon white, will it work?
djozz
djozz's picture
With a flashlight that uses a direct driver like the D1S you need to add resistance, by using a high resistance battery (the GA is still too low resistance/high current perhaps a NCR18650B works) and using long thin led wires if you can get the driver out. If you are handy and smart enough to find a spot for it, you may be able to add an actual resistor somewhere in the current path. Unfortunately Hank’s springs are very low resitance, maybe swap the copper-alloy tail spring for a steel spring. Experiment, keep measuring current and see if you can get to 5A or lower.
SKV89
Last seen: 5 min 21 sec ago
I asked him refarding the d4s already. He said the beam doesnt look right. Would be awesome if he can get them in the meteor though. Love the focused beam.
Also Hank, please sell the oslon white centralizers on your store.
Jerommel
Jerommel's picture
Like that you eliminate all the benefits of the low Vf of the White Flat 1mm².
2Q19
