I’m so cheap…after fixing the displays on my Folomov A4’s…
I dremeled the housing on one slot so the 21700 I have fits in without tearing the wrapper
Not too bad, but it fits awesome now
buthered?
c missing…
Nice
What do you mean you “dremeled the housing on one slot” of your Folomov A4? In what way does a 21700 not normally fit? I was thinking of buying the A4 charger because it supports LiFePO4. If anybody knows, please tell me what other decently priced 4-cell charger could I get that supports Ni-Cd, NiMh, LiFePO4, and Li-Ion cells and has 2A charge rate or better? If there isn’t one, I guess I’ll still buy the A4 and apply the Dremel treatment to it as well.
I had a sofirn battery…a.bit tight. Also just got a …48e? 5000mah
Also quite tight.
The sofrin wrapper got torn popping in and out…
So I cut away the plastic where the negative end would ‘sit’.
Now there is a hole and the slide can go back enough for the cell to pop in and out .
Thanks!
https://drive.google.com/open?id=1YD28PuuS2MFSYtv1pLASZxA3_GggJgpm
Not the best pics, but you get the idea…the two of the charger…I have a drum sander bit, I’ll probably use that to make it look better, tomorrow
Thanks again. I see what you mean now.
I guess your charger doesn’t fit 26650’s
Me? Don’t have any, by I don’t see why not.
650 is the length.
The 700 part was the problem
Just for fun facts. The XTAR Ant MC1 Plus will charge up to 72mm batteries and cost less than $5.00.
@DavidEF the SkyRC MC3000 should do what you want but it's somewhat expensive
That’s awesome ! But since I already HAVE a charger ………
HeHe… “somewhat expensive” he says… HeHe… good one!
For bigger cells, I just throw a Folomov A1 at it (magnetic-stickies) so I don’t have to buther any chargers at all. :smiling_imp:
Again, more cost, more things laying around
Naw. I got a few A1s, and keep one in my bag for “emergency” charging (even though my MH20 has a usb port).
Fits everything, small, handy. What’s not to love?
What he’s saying is that he already had the charger that he buthered, so no need to buy anything at all. True “budget” option.
See…budget
