LED light bar mod
8 posts / 0 new
Bimmber
Last seen: 1 year 4 months ago
LED light bar mod
Gentlemen,
As my first ever led DIY project I would like to upgrade cheap and crap 24v (for a truck) Chinese light bar with better chips like Cree XHP70.2. But I`m stuck on few questions.
They quote following on their listing: Power: 360w (90 chips * 4W)
How are they wired?
If in series (voltage gets added, current stays same), then, if 4w chip has forward voltage of 3.5v for example, that would be 315v. So, they are not wired in series, but in parallel.
If in parallel (voltage stays same, current gets added), then 3.5v and for example 700mA would be 63 amps, which is massive. Truck has about 120 amps available. For 60 amps, cable would be as thick as broom stick! Shocked
Voltage is limited to 24v, so must be wired in parallel? But 24v would blow chips with 3.5 fv when wired in parallel.
But what about thermal runaway risks when wired in parallel?
They also state this:
Operating Voltage: DC 9-32V (Fit 12V/24V vehicle).
They cannot predict it will be used in 12 or 24v system, so how do they know how to wire them in factory? If they pre wire them for max 32v combined forward voltage, then using it in 12v system would mean it would not be that bright? 12v is nearly 3 times less than 32v.
If I`m looking to replace them with xhp 70.2 (unless there is better option?), how do I calculate max I can drive them at, so that light bars case is able to handle the temps?
I noticed, the harder you drive chips, less efficient they get. But I can imagine for light bar which has sole purpose to throw light as far as it can to illuminate road and roadsides ahead, there is no option to have efficiency, because driven at something like 700ma, they would be super efficient, but quite dim? From my understanding – to have max long throw of light, chip needs to be driven as hard as possible (which xhp70.2 can be).
Why do led bars have 90 × 4w chips, but not 3 x CXB3590 driven at high current? So that they can spread heat across whole length of the bar?
Sorry for noob questions, I`m learning.
Thank you
Edited by: Bimmber on 12/21/2018 - 09:58
DavidEF
DavidEF's picture
Last seen: 1 week 1 day ago
Is that the picture of the actual light you bought? If so, it looks like the “lens” in front is mainly just for decoration and to keep dust/mud out. In really nice light bars, each emitter gets a reflector. In the picture above, there are no reflectors, so it would be assumed that they used “lenses” to collimate the light. That isn’t exactly the case, though. There are only 24 “lenses” in that lens, but you say there are 90 LEDs. So, there is really no collimation. So, you can make the light much more impressive and useful just by fixing that.
The voltage range means that they used a driver that changes the voltage somehow. I would expect a simple boost driver with 9V – 32V input. Alternatively, a cheap buck driver. Buck drivers with input from a few volts up to 32 or 35 volts input are common and cheap. The input has to be a little bit higher than the output. So, if it is one of those, it would indicate the output to the emitter bank is less than 9V. The emitter bank doesn’t have to be wired in series only or in parallel only. It is probably wired in some combination, perhaps 3x series by 30x parallel.
If you really want to maximize the potential of this light bar, you should remove all the emitters from the large PCB they’re soldered to, but leave the PCB itself as a back plate. Install new emitters, on MCPCB’s, on top of the back plate. You could use individual emitter MCPCB’s or triples or quads. Add new optics for the LEDs so that each emitter has an optic associated with it. Change the front lens to smooth glass or Plexiglas or Acrylic.
The driver can probably be adjusted to output the right voltage for your new arrangement. Show a picture of the driver here, along with a confirmation of how the emitters are wired, and how your new emitters are to be powered, and someone will be able to tell you what needs to be changed to make it work.
- The YKK Philosophy
Bimmber
Thank you. Picture I posted is random one, just as sample what I meant with “light bar”.
I was thinking to use these:
DavidEF
DavidEF's picture
Okay, if you want really useful help, it will be better if you post relevant information. Every build will be different, and the recommended changes will be based on what you’re starting with. Do you have a picture of the actual light bar you bought? Also, some pictures of the internal workings would help. The more accurate information we have, the more helpful the advice can be. Wink
Bimmber
Haven`t bought one yet as I want to be sure 100% my idea is even possible. My brother and wife`s dad have bought them for their trucks, but they won`t let me crack them open as they are sealed for waterproofing reasons.
If you are saying my mod idea is 100% possible, then I`ll go ahead and buy one.
DavidEF
DavidEF's picture
Here are some old threads you can look at to see where you want to go with the mod.
http://budgetlightforum.com/node/55515
http://budgetlightforum.com/node/45076
Also, look at MTN LITEbar for what is truly possible. The owner of that site is a long time respected member here, and also owner of Mountain Electronics, where we can buy flashlights and components in the USA.
Bimmber
Will check those threads. Thanks.
Omg!!! That MTN light bar! I did check it out few days ago and nearly got led-orgasm from it Love Just amazing, I take my hat off for that guy.
DavidEF
DavidEF's picture
Well, let us know when you do buy a light bar, and take pictures of:
  1. The emitters (and PCB layout if possible)
  2. The optic(s) and/or reflectors if any exist
  3. The driver circuit
  4. The internal wiring
…and we can go from there! Cool Thumbs Up
