【convoy】L21A with KW CULPM1.TG available now
3636 posts / 0 new
Simon Mao
Simon Mao's picture
Last seen: 7 hours 45 min ago
Tater Tot wrote:
id30209 wrote:
Tater Tot wrote:
Would this 8A driver be good for driving low forward voltage LEDs like SST-20DR?
Quit opposite…
I was thinking of 3x SST-20DR or 3x XP-G3 Photo Red on Convoy S12 with this driver.
Since it is a buck driver, it should create less heat than linear FET or AMC7135s?
96% efficiency, little heat generation
Simon Mao
Simon Mao's picture
JonnyBorneo wrote:
Any update on Convoy STB 90.2? What amp driver will this be paired with?
I want to compete with Noctigon K1 which costs $139.99.
18A for SBT90.2
the host is in production
Simon Mao
Simon Mao's picture
adam7027 wrote:
Hello Simon,
Can you confirm battery tube diameter for L21A? Is it 22mm or just 21.5mm?
Some are 21.5mm ,some are 22mm
adam7027
Last seen: 25 min 42 sec ago
Simon Mao wrote:
adam7027 wrote:
Hello Simon,
Can I specifically ask for 22mm, if I make an order?
I would also ask another request:
Could you please make a new item in the store? Which is same to this: https://www.aliexpress.com/item/33024385404.html , but with these differences:
- emitter choices should be: Samsung LH351D 5700K, 5000K, 4000K
- driver max current: 5A (but other driver specifications are the same)
Funtastic
Funtastic's picture
Last seen: 2 days 8 hours ago
Simon Mao wrote:
Tater Tot wrote:
id30209 wrote:
Quit opposite…
Yes, but the SST-20 DR has a very low forward voltage which you need to use a special driver. If you use this driver it’ll burn through most of the battery voltage very quickly to run more efficiently at a lower voltage.
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
contactcr
Last seen: 2 hours 6 min ago
If it’s actually an 8A buck driver the excess voltage is not wasted. However, a true 8A buck driver will require a very large inductor and probably be quite expensive compared to most Convoy drivers so I wonder if something is lost in translation here..
Funtastic
Funtastic's picture
Okay, I’m not really familiar with a buck driver. There’s a thread all about the different types, I should go have a read up
contactcr
The short answer is:
buck driver turns excess voltage into current
boost driver turns excess current into voltage
Tater Tot
Last seen: 6 hours 14 min ago
The 8A driver does seem to have an inductor but is it big enough?
It is also around 2x more expensive compared to linear FET or 7135 drivers.
Edit: I just remembered that I asked him about this a month ago.
Simon Mao wrote:
Tater Tot wrote:
So it is a Buck driver?
Or is it buck-boost?
For more information, I need to consult the driver manufacturer.
Simon Mao wrote:
Tater Tot wrote:
Any updates on this driver?
It is a buck constant current drive,
MoreLumens
MoreLumens's picture
Last seen: 2 hours 42 min ago
I have always wondered about that red stuff or other color on top of those components on drivers. What function does it have?
raccoon city
raccoon city's picture
Last seen: 1 min 7 sec ago
Looks like spaghetti or pizza sauce.  :-)
Good question.
I'd like to know as well.
Tater Tot
I think it’s conformal coating.
contactcr
Didn’t realize it was already available. Yes it does look like a buck driver.
Considering it’s only on and around the inductor I would guess it’s to reduce high pitched noise they can sometimes have. “Coil whine”
id30209
id30209's picture
Last seen: 28 min 8 sec ago
contactcr wrote:
Didn't realize it was already available. Yes it does look like a buck driver. Considering it's only on and around the inductor I would guess it's to reduce high pitched noise they can sometimes have. "Coil whine"
In convoy XHP35 12V boost driver is really quiet unlike the switch...
That red goo is actually glue that holds components while soldering .
WTB Titanium 4sevens 2xAA tube
lazerEagle
lazerEagle's picture
Last seen: 7 hours 21 min ago
A few things landed and tested from Convoy, all really excellent thanks Simon!
L21A XHP35 HI 4000k : Really nice quality. Light is strong and pleasant.
S2+ with W2 Green : This is so much fun, it gets hot on high Wink Great power to weight ratio. Decent throw and spill.
Upgrades for C8: LH351D 5000k and OP Reflector. Such an awesome upgrade for my C8. Sliced the dome and it has decent throw, really nice color, noticeably warmer than 5000k, really awesome all rounder now!
- the best way to predict the future is to create it -
Simon Mao
Simon Mao's picture
adam7027 wrote:
Simon Mao wrote:
adam7027 wrote:
Hello Simon,
only 22mm 6A driver for L21A ,the current is too large for LH351D
adam7027
Bad news for me Crying
Apart from this, you mentioned, that a few of your latest driver are now buck-boost (very efficient, i saw you mention 96%, and no PWM at all). What are your current drivers, which work like these?
Simon Mao
Simon Mao's picture
Currently only this driver has such a high efficiency,
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 22 min 46 sec ago
Simon, any new info about lh351d 2700k and 3500k both cri90? Can you get them?
Also have you thought about making a 2.5A driver (like for CSLNM1.23) but with 12 groups and/or 4 modes?
This would be a good option for those who don’t want s2+ hotrods with 5A drivers.
I know you have 2.8A drivers with AMCs, but consider this suggestion too.
Simon Mao
Simon Mao's picture
I have ordered LH351D 2700K,but not reach to me ,yet.
2.5A driver with 5 groups for KR CSLNM1.23 is in production , i didnt plan to produce it with 12 groups or 4modes.sorry
Blggg
Last seen: 4 hours 42 min ago
What are the mode spaces of the 2.5A driver and what sizes of the driver will be produced?
Barkuti
Barkuti's picture
Last seen: 22 min 8 sec ago
contactcr wrote:
If it's actually an 8A buck driver the excess voltage is not wasted. However, a true 8A buck driver will require a very large inductor …
Very large inductor? Not necessarily. Inductor size increases both with conductor width and with inductance value. This specific driver isn't meant to handle 2 cells in series, it is meant to efficiently drive low Vf emitters at high currents with just single cell input. Thus, no large inductance value is required which saves inductor size:
The above inductor is just of 470nH value (very very small), and pretty sure it is a high current handling inductor. It is the exact recipe for a single cell high current buck driver, which on the other hand is a smart choice as it offloads a lot of heat from the driver which otherwise would be burnt in the MOSFETs like it happens in all of the newer Convoy 5A and 6A linear drivers. Given the requirements (low emitter Vf and pretty high current) the above design is a completely logical and smart choice. Kudos for this.
P.S.: 8A? Wow! I think that is a bit “on the edge”, but well…
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
contactcr
Brilliant analysis after seeing driver. Kudos for this.
id30209
id30209's picture
Hopefully, Simon will "pimp" all models to this standard (or better) in his store...
Barkuti
Barkuti's picture
Question for Simon:
Base diameter:
Aditionally, total reflector height is ≈50.5mm.
Is that the Convoy L2/L21A reflector? If so, I'll have to order a spare part.
stephenk
stephenk's picture
Last seen: 19 hours 51 min ago
Looking forward to that in the S2+ and S12.
Please Simon can we have constant frequency strobes in your lights (e.g. 10Hz) instead of the alternating/two frequency strobes. You are losing lots of sales to light painting photographers by not having a constant frequency strobe in Biscotti and 12 Mode UI.
m47mu74nt
Last seen: 4 hours 34 min ago
Hello Simon,
I want to swap emitter and driver on the just arrived Z1, but can’t figure out how to disassemble the driver section?
Can you give me the right direction please?
Thx
Artiet59
Last seen: 2 hours 26 sec ago
Simon Mao wrote:
18A for SBT90.2
Oh boy Oh boy Oh boy Party
Simon Mao
Simon Mao's picture
uh ,sorry ,what’s mode spaces?
it’s 17mm diameter
Simon Mao
Simon Mao's picture
Barkuti wrote:
Question for Simon:
Base diameter:
Is that the Convoy L2/L21A reflector? If so, I’ll have to order a spare part.
reflectors in L2 and L21A are the same
