【convoy】17mm SST40 driver with biscotti firmware and temperature protection will be available
2126 posts / 0 new
d_t_a
Last seen: 2 hours 46 min ago
KevinZA1988 wrote:
RelakS wrote:
Chatika vas Paus wrote:
Simon. I received your driver for “M3” today and put it in the JKK70 with the xhp70.2. Thermal protection works very fast. Too fast. The flashlight is not even warm and after about 50 seconds the brightness decreases. It seems to me that you should increase the temperature protection.
Yes, something is definitely weird. The M3 itself also not even warm when the temperature protection kicks in, but it almost burnt my hand when I took it apart and touched the driver retainer ring Shocked At least it was very hot to touch.
The temp sensor obviously gets triggered by the hot driver. If you can add a copper or aluminum spacer with silicone sheets it should perform a lot better. Try and conduct as much heat as possible away from the driver into the host.
That seems to mean that the heatsinking or heat dissipation of the M3 driver/LED board to the flashlight body/host isn’t that good, and hopefully can be improved next time?
The M3 body is quite big so it should ideally be able to absorb a good amount of heat compared to other smaller XHP70.2-based flashlights.
KevinZA1988
KevinZA1988's picture
Last seen: 21 min 3 sec ago
It’s possible. But from my experience with boost drivers they all need some form of an extra thermal path to run at high currents for long periods. I’ve stripped a few boost driver lights and usually they have some thermally conductive paste that they put on the driver components.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Pwsmith
Simon Mao wrote:
Noctiluco wrote:
Nice those AAA titanium! What kind of led? Number of modes? Neutral/warm led options? Does it support 10440?
I have a SS Convoy AAA and it eats 3.7V very well…
this is just host ,
I can design the corresponding driver
Any idea of the price or timeframe for release on these hosts? I can’t wait to get my hands on a few and get building!
Alen
Last seen: 4 days 4 hours ago
There are chance to see flat pill for s2+ for 20mm led board?
(like s21a)
jasontheguitarist
Last seen: 1 month 3 days ago
Alen wrote:
There are chance to see flat pill for s2+ for 20mm led board? (like s21a)
With as popular as triple mods are, I’m surprised Simon doesn’t sell the parts to make a triple. A spacer, or the whole triple compatible pill like the kiriba one.
hodor
hodor's picture
Last seen: 21 min 41 sec ago
Any plans for other colours of the M21A with reverse clicky?
Simon Mao
Simon Mao's picture
Last seen: 3 days 14 hours ago
what color? for example?
Alen
Clear for all flashlights
hodor
hodor's picture
I was thinking desert tan but actually I like the standard matt black just as much Thumbs Up
I’m very tempted by the M21A but I would prefer a reverse clicky and a warmer emitter. Are there any plans for these?
Capital
Last seen: 2 weeks 2 days ago
Extremely interested in the AAA/10440 host. Any details on a possible release date, MCPCB and driver sizes?
MascaratumB
MascaratumB's picture
Last seen: 3 hours 5 min ago
How hard would it be doing a driver swap on the M3?
Any clues from those who have the flashlight already?
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
KevinZA1988
And what about desert tan?
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 hours 38 min ago
MascaratumB wrote:
How hard would it be doing a driver swap on the M3? Any clues from those who have the flashlight already?
The problem is the driver diameter with 26mm. Unfortunately, it cannot use 30mm drivers. So, there’s little to no choice for alternative drivers. The host has so much potential but the driver’s regulation at 50°C is a real downside. The host will not get very warm as soon as the driver already steps down.
gchart
gchart's picture
Last seen: 5 min 54 sec ago
I can’t quite tell from the product listing what MCU it’s using, but at least it’s a SOIC8 footprint. So it’s either (1) an AVR which our attiny13/25/etc will swap in, or (2) it’s a PIC and an attiny412 would swap in.
I imagine I could get something cooked up, but I don’t have one of these drivers.
RelakS
Last seen: 2 days 1 hour ago
Also it has no physical on/off switch, only an “electronic” button. I mean that the driver is always powered, and it is controlled with the button. If one don’t want to add a switch, it must be taken into consideration.
If someone would build a driver even with this temperature limit, but it would do a dynamic power regulation to hold the limit instead just simply turn down the brightness, I would be interested in it Smile On a bike clamp I don’t care if it is 50 or 60°C provided that the components can handle it, but if I start pedalling, and the moving air cools it down, I want to get back some of the brightness.
Geuzzz
Geuzzz's picture
Quite a long tease. Simon when can we order that ti AAA?
MascaratumB
Thanks for the reply LP! It just seems that all my modding are being flushed down due to the inexistence of propper drivers…It’s getting frustrating Oops
That host seems really incredible and the reflector puts out a lot of light! Too bad the UI (more than the driver itself) is not the best one…
Today I say a review from the Wowtac A5 and it has the UI that I would like to see on this light. Wish that Simon could change it a bit. Even the thermal regulation even if it is not what bugs me the most…
Thanks again for the reply! Danke sehr!
OL Contest 2019
GIVEAWAY: 1 / 2
oweban
oweban's picture
Last seen: 11 hours 43 min ago
Anyone got one of the original S11s and one of the new ones? Would love to see the difference in the tailswitch board and switch itself.
Failing that, I’m trying to find a 22mm e-switch driver with a non-garbage UI that will fit inside the S11 and get it machined to fit – the new Wowtac A5 fits the bill but I want to replicate it with what I have Wink (I know, the problem is boost driver – maybe 3v 50.2 with a D4 driver? Silly )
Simon Mao
Simon Mao's picture
2019/7/19
SST40 5000K available
SST40 5000K LED
I also added a 5000K option for the related SST40 flashlights
KevinZA1988
Hi Simon, what bin is the 5000K SST-40?
KevinZA1988
Never mind, I see it’s N5-DA-VJ!
BlueSwordM
BlueSwordM's picture
Last seen: 14 hours 25 min ago
Oh yes.
Finally a 5000k high binned SST-40.
Now to wait for Luminus to make a 95CRI SST-40 4000k. Smile
hasddie293
hasddie293's picture
Last seen: 3 days 9 hours ago
BlueSwordM wrote:
Oh yes.
I’ll follow you, hope for 3000k to came along…. Davie
Heeeeyyy 5000k is not bad, pretty better than 6500k…
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Yokiamy
Yokiamy's picture
Last seen: 29 min 58 sec ago
Drat!
i just bought the L21a in 6500K …
and the new cells i bought did’dn’t fit …
Now i have to buy a new LED AND new cells …
  BLF
Diomedes
Diomedes's picture
Last seen: 6 months 3 days ago
Good to see the 5000K SST-40 now becoming more available. Placed an order for a few. One will replace the 6500K emitter in my L21A. Excellent light and will be even better with a slightly warmer tint Thumbs Up .
SKV89
Last seen: 10 min 25 sec ago
5000k D2 is a good tint bin too.
djozz
djozz's picture
Last seen: 1 hour 19 min ago
And a good price! Smile
hodor
hodor's picture
Happy days! Smile
Lux-Perpetua
Simon, do you see any chance to ship the LG M50T via e-packet for a more attractive price to Germany?
https://www.aliexpress.com/item/33044646891.html
I am going to place my next order (mostly LEDs) soon. Unfortunately, $ 7,36 is a bit expensive for shipping 2-4 batteries.
Thank you!
Lux-Perpetua
Has anyone tested the SST-20 2.700K 95CRI yet?
https://www.aliexpress.com/item/32975568763.html
