【convoy】17mm SST40 driver with biscotti firmware and temperature protection will be available
2126 posts / 0 new
d_t_a
Last seen: 19 min 38 sec ago
Simon Mao wrote:
Yokiamy wrote:
Simon Mao wrote:
Yokiamy wrote:
Yokiamy wrote:
Simon, is there an easy method to change or disable the temperature regulation of the L21a SST40 driver (i have the version with 4 modes only) ?
Maybe by disassembling the temperature controller, or soldering a bypass resistor, or just bypassing it with a wire?
Simon, any ideas about this ?
i didnt get reply from manufacturer,yet.
i will reply you later
Thank you, looking forward to it !
!https://live.staticflickr.com/65535/48533628787_a386933ef6_b.jpg!
Sorry I don’t fully understand the picture. The circled spot is I suppose the thermal sensor controller, but what should we do to disable it if we don’t want the temperature control on the SST40 4-mode driver? The circled part has to be unsoldered? Pardon my ignorance..
d_t_a
Nicolicous][quote=Simon Mao wrote:
hodor wrote:
Any update on this beauty yet?
available soon,about in 10 days
Party Party Party
This is a triple SST40 right? (I saw some mention of triple SST20…) Any approximate lumens numbers for this Convoy S12?
Agro
Agro's picture
Last seen: 2 min 32 sec ago
Simon…any news about the titanium AAA lights?
oweban
oweban's picture
Last seen: 6 hours 11 min ago
Triple SST20, IIRC.
Yokiamy
Yokiamy's picture
Last seen: 14 hours 1 min ago
Simon Mao wrote:
2019/8/20 new headband for H1 is available now
That is one good looking headband Simon!
Yokiamy
Yokiamy's picture
Yes.
Have a look over HERE how i did it
Mocarny
Mocarny's picture
Last seen: 35 min 5 sec ago
Mocarny wrote:
Simon Mao wrote:
adam7027 wrote:
Hello Simon,
Does the XHP35 HI 4000K B4-40E have 90 CRI?
not high CRI
Uch why can’t I find it? It is so annoying…
Can someone help with finding this LED? Facepalm
jasontheguitarist
Last seen: 1 month 1 week ago
Do some LED bins only exist on paper? Seems that way.
KevinZA1988
KevinZA1988's picture
Last seen: 1 hour 39 min ago
I also tried finding that LED the day he launched it… Nothing!
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
gchart
gchart's picture
Last seen: 36 min 15 sec ago
Yes, I think some only exist in spec sheets. Kind of like “if we were to produce some, this would be the item number for it”.
For endeavors such as this, Octopart is a great resource… just search for the Cree order code. Pretty much anything I’ve found has a 1000pc MOQ though. Sad AVNET supposedly has it in stock (with the 1000pc MOQ). Other places such as Mouser and Digikey also list it, “non-stocked” with 1000pc MOQ meaning that you should be able to place an order (for 1000pcs) and they’d procure it for you.
Now if you don’t mind going for the ANSI versions instead of the EasyWhite versions, you can get the XHP35-HI 4000K 90-CRI in B4 flux bin (XHP35A-H0-0000-0D0UB40E5) from Mouser in 1pc increments for USD $6.50
Mocarny
Mocarny's picture
Maybe it is just SuperSecretSimon-CustomMade LED. SSS-CM LED
RelakS
Last seen: 1 day 11 hours ago
I was able to get 2 minutes runtime from the M3 on turbo … on a bicycle, while I was in motion.
I had to switch it off, because someone appeared in the road, and I did not want to blind him/her Big Smile
Actually, id I don’t want to see very much ahead, but just avoid from overhead trees, etc, the High mode is just enough. I even put a lens in front of it to have a wider beam, which of course make the hotspot less bright.
matik42
Last seen: 5 days 16 hours ago
On Simon ali store stated that “CREE XHP35 HI LED 4000K B4-40E” and 9998 available for bare
Are anybody have done measurment?
Simon Mao
Simon Mao's picture
Last seen: 1 week 5 days ago
oweban wrote:
Looks good!
I saw a report on reddit that the current H1 batch has the new UI (similar to Thrunite), is that right?
some are updated
Simon Mao
Simon Mao's picture
remove it
Simon Mao
Simon Mao's picture
d_t_a][quote=Nicolicous wrote:
Party Party Party
3 * LED in parallel
driver 22mm output 6A with tempareture management
Simon Mao
Simon Mao's picture
seems not welcome,
i’m ready to design titanium AA flashlight with better driver
Simon Mao
Simon Mao's picture
oweban wrote:
Triple SST20, IIRC.
not only sst20
any 3535 LED can be installed
KevinZA1988
Simon Mao wrote:
oweban wrote:
Triple SST20, IIRC.
not only sst20
Simon, what’s the size of the MCPCB? Can similar sized MCPCB’s be found elsewhere??
Simon Mao
Simon Mao's picture
uh,it’s just virtural number Facepalm Silly
Ryzbor
Ryzbor's picture
Last seen: 45 min 9 sec ago
Anyone knows if this light will have a clean beam pattern with the 219B based on their experience?
Will the carclo triple/quad compatible model follow soon after the release of the reflector model?
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K R9080 (needs more 219B), super rosy 3000K E21A mix Skilhunt H04 on it's way
oweban
oweban's picture
Noice, so yep, can drop some sw45ks into that. 2A each is fine.
Thanks Simon Smile
Di_Joker
Di_Joker's picture
Last seen: 43 min 17 sec ago
Maybe someone managed to find a suitable TIR optics for Convoy S11?
Sorry for my poor english.
KevinZA1988
Can you perhaps measure the reflector? I have a S11 on the way, might want to make a quad mule out of it.
Di_Joker
Di_Joker's picture
https://ru.aliexpress.com/item/33002116288.html?spm=a2g0v.12010612.81483...
I don’t have one either.
oweban
oweban's picture
diameter 28.5mm
height 20.7mm
diameter of bottom hole 7mm
weight 10g
suitable for XML2 XHP50 XHP50.2
I measured it up ages ago when looking for options – I think I found a ledil and a carclo that would be close, but still not 100%.
Edit: from memory, the opening at the head is 25mm, in case you find a TIR with the “shelf” bit.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 45 min 50 sec ago
A mule with TIR optic? A mule is a flashlight without any optic.
KevinZA1988
I didn’t say I want to install an optic. I want to install a quad MCPCB and a spacer, together with a lens and some film to diffuse the light a bit.
oweban
oweban's picture
Would love if there was a spacer made to buy…
https://www.reddit.com/r/flashlight/comments/bei7cv/comment/el6xenm
texas shooter
Last seen: 5 hours 46 min ago
Simon would you consider manufacturing a P60 style host in 21700 format? The design in 18650 was flooded on the market. But now good host have nearly dried up and no one every built it in 21700 format. If a host was built to your quality standards I’d replace every P60 host I own now. SF compatible except tail cap, as body diameter is increased to 28-29mm’s.
