【convoy】KW CULPM1,KW CSLPM1,KP CSLPM1,LH351D 4000K,3030 DTP,3030 7mm gasket
2877 posts / 0 new
Mocarny
Mocarny's picture
Last seen: 11 hours 26 min ago
Standard DC Fix is about 3%, but you can get thicker, it will of course block more light, but I don’t think it will be more than 7%
Simon Mao
Simon Mao's picture
Last seen: 5 hours 37 min ago
2020/7/11
osram KW CSLNM1.1TG bin 6N-ebxD46-15 (6000-6500K)
3030 DTP copper board
samsung LH351D 90CRI SPHWHTL3DA0TV4QTS6 bin V2Q2S1 5700K
samsung LH351D 90CRI SPHWHTL3DA0GF4RTS6 bin F2R2S2 5000K
LD351D 90CRI 4000K will be available after half month
i will add these in my store at next week
oweban
oweban's picture
Last seen: 17 hours 25 min ago
Finally, another place to get these Big Smile
hodor
hodor's picture
Last seen: 7 hours 1 min ago
Noice!
ZozzV6
ZozzV6's picture
Last seen: 6 days 5 hours ago
That is really good news Simon. Now I don’t need to solder osram leds on 3535 MCPCB’s aní more. I think I will buy 10-20 of those MCPCB’s Big Smile
id30209
id30209's picture
Last seen: 5 min 23 sec ago
At last. Convoy is beating KD. Slowly though...
WTB Titanium 4sevens 2xAA tube
Ryzbor
Ryzbor's picture
Last seen: 1 week 1 day ago
No White Flat 2mm^2? Tired
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm Photo Red ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 (for sale)
Blggg
Last seen: 9 hours 52 min ago
Which models can use the LH351D?
ZozzV6
ZozzV6's picture
All 3V led models so you can replace XP-L, XP- L HI, SST20, SST40, XM-L2, XP-G2…… leds with them.
Blggg
Thank you, ZozzV6. I think I might get either S12 or S21A with 5k LH351Ds. Hope both are good hosts for the emittter and the tint bin is good.
Yokiamy
Yokiamy's picture
Last seen: 2 min 55 sec ago
Simon, any updates about the 4×18 with SBT90?
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 13 hours 3 min ago
I have a 4000K & 5000K LH351D in my S21A hosts and they are great! You'll want a driver that senses temperature for step down.
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, LH351D 4000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | SK Zoomie Nichia 5000k, C2 driver | EagleTac clip | Ultrafire C2 w/5A 17mm & XM-L2 | Nichia 219C 2700K with gray S6 |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3)
Blggg
Nachtfeuerzeug wrote:
I have a 4000K & 5000K LH351D in my S21A hosts and they are great! You’ll want a driver that senses temperature for step down.
I see. Do you think the current 6A driver would be fine with the emitter? Will it overdrive a single LH351D? I see that in Sofirn lights, the max current drawn by this Led is about 3-4A, which is about 1,300 lumens. Wonder if Simon has to make some new drivers just for this.
Nachtfeuerzeug
6 amps is not a problem. Check this out:
http://budgetlightforum.com/node/57784
EDC
Reviews:
Lightbringer
Lightbringer's picture
Last seen: 1 hour 6 min ago
Except for:
Quote:
The dome started to burn around 5A but after scraping off the burnt area it completed the test just fine and a retest after it was over showed only a few lumen loss at 1A even after all that abuse.
LOL
contactcr
Last seen: 8 min 42 sec ago
Can we hear more about the Z1?
oweban
oweban's picture
Yeah WF1 5A max. Got one in a C8+ with the 5A convoy driver and it’s punchy as hell.
Blggg
For a good combination of flood and throw, I think the S12 with the stock 6A driver should be good. Will ask Simon if it is plausible.
Nooner
Last seen: 6 hours 22 min ago
Have throw numbers been revealed for the new Z1?
Ryzbor
Ryzbor's picture
Angry blue?
oweban
oweban's picture
Nope, it’s happy at 5A. I think anything above that gets a bit iffy though.
Nachtfeuerzeug
Ryzbor wrote:
Angry blue?
I had the same host, with bypassed springs, and LH351D with a Mtn FET.  I went on walks and otherwise used it for a few months with high drain cells. No angry blue.
But, I did switch the LED out of the C8+ for a 6500K SST40. From what's being highlighted here, I'll be fine with running the LH351D at a safer amperage.
EDC
Reviews:
sochi111
sochi111's picture
Last seen: 17 hours 32 min ago
Is the M21A only available in Black color? Are other colors not available or not genuine?
like this
and only SST40?
Is it not suitable for a XHP emiter?
Nachtfeuerzeug
I noticed that Gearbest has some sand colored product but anything other than the two colors, I'd ask Simon about their authenticity.
For a XHP 50.2, It'll handle the heat for a little while at turbo but this having a throwy beam, you don't have to run it at turbo to light up the target really well. Go with a 3 volt emitter.
EDC
Reviews:
contactcr
Simon please do a batch of all copper heatsinks for Z1. If performance is good users will buy so they can further tune the light. If in the future you put white flat or XHP50 in it you will want this as well.
caramba
caramba's picture
Last seen: 2 days 19 hours ago
Simon Mao wrote:
The epacket logistics to the US has indeed had problems recently.
I started to switch to dedicated line logistics in the past two days
here are some “tracking numbers”
The logistics transportation time is 8-13 days, and the speed is very fast.
I got my package in 12 days !!, Thank you Simon, better service than Amazon Smile
On another note, I started learning about SEO and noticed some misspelling on your Aliexpress store like this one:
title>Convoy flashlight Store – Amazing prodcuts with exclusive discounts on AliExpress </title
Hope this helps and brings you lots of business Thumbs Up
Eneen
Last seen: 1 week 21 hours ago
Just ordered S12 with 5k 351D, hope to get them fast!
will34
will34's picture
Does anyone know if the lighted tailcap works with 17mm SST40 5000mA driver?
Blggg
I have also ordered the same. I have asked him for the beamshots of any models using LH351D, but he’s been a bit busy.
flightless22
flightless22's picture
Last seen: 39 sec ago
Yes it does Thumbs Up
