Great light but std their a bit too white , I know their tough to pull apart , so thinking just to get the bezel off and swap the led only
Now does anyone Know what the std LED supply current is on them and is it best suited to the Osram white Flat 1mm2 or the trusty XPG@ S4 2b dedomed or even the Osram Black flat
Target is NW 5500 –5700 max and bit more throw ( tighter spot )
I almost purchased a p30 just so I can have a black flat or a white flat installed in it. So now I’m very curious to see what you do and results are.
Dale can probably be of some help here. I know he modded his. He even polished his reflector. But that caused a loss of some throw.
Thanks but were after someone who has tested current at the LED on highest mode to see whether the new White flat has more lumens than the XPG2 at that current
