Dorcy FLASHLIGHT WITH 9V ALKALINE BATTERY
22 posts / 0 new
jerm03
Last seen: 3 weeks 1 day ago
I notices that Dorcy is making 9V 6 LED light. I looks as if it might be good for a long (week +) hike. I did not see it mentionned here. Has anyone tried it? For $3.00 and free shipping it is a true budget light.
https://www.dorcy.com/shop-now/dorcy-deals/flashlight-with-9v-alkaline-b...
Thanks, Jerry
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 9 min ago
IMO, something like a Sofirn C01 would be better.
Better beam, better color, uses a way better cell choice(AAA), and doesn’t start on high.
Also more durable.
madsnake
madsnake's picture
The 9V battery is not really budget battery. The $ per miliampere is awful. The AA/AAA options are better. If a cheap host is needed, i have seen many 5/7 led options with 3xAAA for like a dollar.
Jerommel
Jerommel's picture
It’s not just abut mAh.
It’s actually about Wh.
2Q19
CRX
CRX's picture
Last seen: 1 hour 41 min ago
I modded one of those with an MT-G2 Big Smile
http://budgetlightforum.com/node/52692
Virisenox_
Virisenox_'s picture
Last seen: 3 days 14 hours ago
Jerommel wrote:
It’s not just abut mAh. It’s actually about Wh.
9V batteries usually have a capacity of about 550mAh.
Amazonbasics 9V batteries are $1.25 each
0.55 * 9 = 4.95Wh
4.95/1.25 = 3.96Wh/$
An AAA will have a capacity of about 1200mAh.
Amazonbasics AAAs are $0.20 each
1.2 * 1.5 = 1.8Wh
1.8/.2 = 9Wh/$
Reviewer for ThorFire, Olight, Sofirn, and others.
More active on Reddit: /u/Virisenox_
"I go hard."
- Zeroair
"Don't quote me on that."
- Zeroair
jerm03
Thanks for the replies. Not as good a light as I thought. I was thinkingof a 9v battery light that is not produced anymore. I remember someone had claimed they went on a month long hike and did not deplete the battery. ?? Of course it put out a moonn mode light.
Jerry
Virisenox_
jerm03 wrote:
Thanks for the replies. Not as good a light as I thought. I was thinkingof a 9v battery light that is not produced anymore. I remember someone had claimed they went on a month long hike and did not deplete the battery. ?? Of course it put out a moonn mode light. Jerry
Paklite?
"I go hard."
- Zeroair
- Zeroair
chadvone
chadvone's picture
Much cheaper then the Paklite. I just went through there lights and its the most interesting one to me.
hIKARInoob
hIKARInoob's picture
Last seen: 4 hours 43 min ago
Mini Nitecore TM10K. Silly
Nev
0.55 * 9 = 4.95Wh
1.2 * 1.5 = 1.8Wh
1.8/.2 = 9Wh/$
Are you sure about that ,9 v battery’s are usually around 200 mah , lithium iron Rechargables are around 500-600mah.
Streamer
Streamer's picture
Last seen: 6 hours 22 min ago
I have several of these 9v “block lights” as they are sometimes called.
The 9 volt format is (edit) 3 6xAAA in series. That said, I have even used old 9 volt batteries laying around to power these little “block lights”.
I use them indoors late at nite bath trips etc. Seem to last forever on a 9 volt battery used or new. They have their place. I mean, if all you had access to was a single 9volt battery, you’d be glad you had the “block light” head to attach it to. Grad
jerm03
I have one running on low, 2 leds, and will see if it runs 100 hours. I am very sceptical. The amount of lights appears to be about what my Fenix E01 puts out. The E01 runs slightly less than 9 hrs on alkys. Smile
Jerry
jerm03
It would not run on NiMh Tenergy 9 V batteries. I am a little surprised.
Gebe
Last seen: 4 hours 6 min ago
Thanks for the “heads up” Jerry. Ordered two.
jerm03
I am wondering how long it would run on a lithium? Hate to spend the money to find out. Cash Question
Jerry
Jerommel
Jerommel's picture
Streamer wrote:
I have several of these 9v “block lights” as they are sometimes called. The 9 volt format is 3xAAA in series. That said, I have even used old 9 volt batteries laying around to power these little “block lights”.
6 × 1.5 = 9
2Q19
nottawhackjob
Last seen: 3 months 4 weeks ago
Are you sure? I’ve charged Tenergy 9V’s to 9.4V’s and used them at only around 8.95V’s or so after they sat around for awhile and they still powered up alky designed 9V devices.
Unless this is an mAh issue. I use Tenergy Low Self-Discharge Centura’s @200mAh.
I hope you’re wrong cuz I just bought 7 of these. LOL
Freshly Edited: Just received 14 of these today. Bought 7 for $21 and received 7 more free as part of the BOGO. At $1.50 each x 14 + 14 alkalines, so including shipping = one HELLUVA bargain in my book.
Butt more importantly THESE DO WORK WITH NiMh. Tested with 3 Tenergy’s as described above. One 8.92V, another 8.93V and one @ 9.04V. All work as well as the alkaline batts they came with. Decent output too.
I would double check your NiMh cell(s). My guess you do read adequate voltage but their mAh’s are kaput.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
jerm03
I’ll check, but I think it was a Tenergy Centura.
I’ll try agaain with another NiMh.
One of the heads is faulty. I’ll work with it tomorrow, but the Tenergy does work with one of the heads
Jerry
nottawhackjob
Likely will work. Ya might wanna change yer title now maybe by adding below it…..(Works with NiMh too) or sumthing to that effect.
This was a great find, Jerry. Thanks. Great for giving to Muggles especially.
I was surprised how well these focus their beam. Decent hot spot and spill. You wouldn’t think it could come otta that rectangular array either butt it does. Switch works without a glitch and isn’t scratchy.
Dorcy did a dam good design job on these. In fact I’m buying 7/14 more if still available. Cash
This is the kind of BLF super bargain we used to see a lot of back in the good old days of LED mania. BLF’ers might consider at least a few for glove boxes, etc.
The NiMh capability is extra icing and kinda puts getting sum 9V rechargeable Tenergy’s for emergencies now more practically prudent IMO.
Streamer
Streamer's picture
6 × 1.5 = 9
LOL..ooooppppssss… that’s right Blushing
Gebe
I totally agree!
Just to bring this up again, I received mine about a week ago and these are great! Like others stated, they’re like the Paklites of old, (that I bought a few in the old days), but much much, better and much, much cheaper!
Boy, some here will always complain about tints, or whatever and recommend more expensive lights and be a tint “snob”. Not that that’s bad but come on with these.
For $3.00 each with free shipping and that includes a decent 9V cell, these truly are a bargain. Heck, a good 9V cell costs about what these do especially when you include free shipping and these include the snap on light!
After all, this is BLF, (BUDGET LIGHT FORUM!), and this is as budget as it gets! Harkens back why this site was first started. Good stuff and again, thanks for the alert Jerry!
