EFAN Lux S4: Touch Screen Smart Charger/Analyzer gb: NOW ACTIVE @ $119 - Post here to get code!
40 posts / 0 new
tatasal
Last seen: 16 min 40 sec ago
Edit Jan. 16:
This gb is active. ( $119, shipped)
Code sent to members in the list.
If you want to receive the code, please post in this thread.
HKJ review: Here
*Touch Sreen Intelligent Charger
*Battery Charging & Discharge testing & Capacity Grading & Battery Internal Resistance Testing
*Built in cooling fan with two temperature sensors
*Compatible with
IMR/3.7V Li-ion/3.8V Li-ion/LiFePO4/1.2V Ni-MH/Ni-Cd
32670 26670 26650 22650 21700 20700 18650, 18490, 17500, 18350, 14500, 10440, 16340(RCR123)
Ni-MH / Ni-Cd
AA AAA AAAA SC C D etc
Adjustable 4 (0.5A*4/1A*4/1.5A*4/2A*4) optional charging modes for different capacity battery.
Features:
1. Micro-programmed control unit, intelligent implementation of touch control, four slots operate independently and support the hybrid charging mode.
2. Using constant current, constant voltage charging mode.
3. Using DV control technology to reach higher charging efficiency.
4. Color LCD display screen instantly shows charging progress, battery voltage,current, time,capacity,charge-discharge curve and display diagram of internal resistance testing.
5. Compatible with Ni-MH /Ni-Cd/ LiFePO4/ Li-ion 3.7v/Li-ion 3.8v battery for any capacity.
6. Fit in rechargeable cylindrical battery which diameter below 32mm, length: 34-73mm.
7. AC 100V – 240V DC, or 12V input mode (or DC 12V 5A vehicle-mounted input)
8 .Functionality includes charging, discharging, capacity grading & battery resistance testing
9. All the discharge current is set to 0.5A.
10. Protection of opposite connection: corresponding battery slot showing “Battery Error” if battery reversed.
11. Protection of short circuit: corresponding battery slot showing “Battery Error” if battery short circuit.
12. Automatic activation function: automatically activate the “zero voltage” lithium battery.
13. Intelligent temperature control: built-in cooling fan will be according to the two temperature sensors, to detect machine internal temperature which rise to 60 degrees Celsius automatically open, drop to 40 degrees Celsius automatically stop, ensure the charger has good working condition. Avoid spontaneous combustion or ignition in high-capacity batteries during high temperature on the charge and discharge process.
The group buy of the S4 details:
1-15 committed members: $ 129, shipped world-wide (this is a 1.5kg box)
16 up — $ 119
Please post in this thread for your interest.
If ever this activity starts, I will send via private message the code and the purchase link.
1. KawiBoy1428
2. Lexel
3. MichielSanders
4. Adhara
5. mmalive
6. northbeard
Edited by: tatasal on 01/16/2019 - 02:33
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 3 min ago
Yep….Interested
KB1428 “Live Life WOT
Lexel
Lexel's picture
Last seen: 8 hours 2 min ago
definately interesting, but the price is a bit high
or I am just getting too cheap chargers from Miboxer with their coupons
tatasal
Lexel wrote:
definately interesting, but the price is a bit high or I am just getting too cheap chargers from Miboxer with their coupons
Oh well, I paid more than $100 for the SkyRC mc3000 when it came out, only to read horror stories from broken retaining spring pins, shut-down from 4×1a discharge mode, wrong fan orientation and arguably the worst (for me) UI ever (someone even made a ‘cheat sheet’ just to properly operate it) that until now this charger of mine is just in its box sleeping soundly.
Looking at the video looks like this is the analyzer for me.
MichielSanders
MichielSanders's picture
Interested
Olight: M3XS-UT, S Mini CU, R50 CU, R50 Pro LE, M2R, I3T Cu, S30R III, Marauder X6, X7R, X9R - BLF: Q8, A6, GT, GT mini - Emisar: D1s, D4Ti - Reylight: Tripple Dawn, Ti Lan
Nitecore: TM26GT, SRT9, EC11, T5s, P05Pink, LA10, HC33, HC70 - Fenix: TK75Vn FiatLux, TK76, CL05, CL09 -  Lumintop: Tool Ti, IYP365Ti - Astrolux: MF01 Lexel driver - FourSevens: Maelstrom MMU-X3
Nev
Last seen: 6 months 3 weeks ago
Can you calibrate it like the mc3000 or is it the usuall lucky dip, if I spend that much on a charger then I want it to be as accurate as a fluke DMM & it needs to be consistent on all slots.
tatasal
Oh how I wish Fluke make a touch screen charger/analyzer, cost be damned!
Nev
They don’t & you don’t need them to, just get a skyrc mc3000 and you know it’s gonna do what it says on the box.
I wasted a lot of money on the latest greatest chargers in the past ,most are not accurate & if you win the lucky dip & find an accurate one the next problem is getting one that’s constant on all slots.
A few weeks ago I bought an all88 charger because I wanted to be able to charge 8 battery’s for my BLF.GT all to 4.2volts ,yes it will charge 8 battery’s to 4.2volts ( according to the display) but in reality some will be 4.17 some will be 4.15 some will be 4.whatever.
So I just spent £60 on another mc3000 so I could have 8 cells come off the charger at 4.2volts & they all settle to around 4.18 after a while.
The chargers I own are
Opus 3100
Xtar vc4
Skyrc mc3000
Soshine whatever it’s number is
Falcon ? All88
A couple others I can’t be bothered to get out any more ,I can’t be bothered to remember thier names
None are accurate or constant .
As far as I know skyrc is the only one yo can calibrate ,I’ve lost all faith in standard chargers to be accurate & constant .
Maybe this new overpriced charger will eventually come down in price & will be upgraded later to be able to be calibrated , I may be interested then but for for now I’ll swerv it.
But thanks anyway:BEER:
Adhara
Last seen: 1 hour 29 min ago
I’d consider one.
tatasal
After a massive spam attack, bump to a charger gb for members with relatively deep pockets!
contactcr
Last seen: 3 hours 17 min ago
I second this. They have a charger which can support firmware updates according to HKJ but unless they commit to actually providing them this purchase seems a bit risky.
tatasal
Today’s bump!
mmalive
Last seen: 11 months 4 days ago
I am in. Thanks.
virencelights
virencelights's picture
Last seen: 5 min 38 sec ago
game needs to be changed for way better chargers and this looks good.
I have a Dragon Xtar and LiitoKala.
Virence ArmyTek Viking Pro Quadtrix 9080 E21A 6500k, Virence Skilhunt H04 RC Quadtrix 9080 E21A 5700k, Virence Jetbeam AAA 9080 E21A 5700k, Virence Jetbeam AAA Nichia HCRI Red Led.
https://www.instagram.com/p/B5szQO9jM2z/?fbclid=IwAR2iVysO9q_niBevQv35pH...
tatasal
mmalive wrote:
I am in. Thanks.
You’re added to the list. Beer
Kajman
Last seen: 3 months 4 weeks ago
Does it support NiZn?
northbeard
Last seen: 7 hours 17 min ago
I would like to be in on this too. I do have a couple of chargers, but – you know how it happens – there’s always another flashlight to keep fed…
deathless
Last seen: 1 month 2 days ago
Is there a US plug version?
MichielSanders
The power suply has a c7 plug so if the voltage rating is 110/240vac 50/60hz you could use your own cord.
https://www.amazon.com/Standard-Polarized-Replacement-Charger-Adapter/dp...
tatasal
Me too! Precisely why we keep on buying more flashlights than we can practically use! … and batteries, and….
tatasal
I will check.
tatasal
we have EU, US, AU, UK plug for option
tatasal
It’s not supported. Blushing
tatasal
Bump for latecomers!
tatasal
Regular price: $ 149.
This gb is active. ( $119, shipped).
If you want to receive the code, please post here.
Thanks!!
Adhara
Ordered.
tatasal
Adhara wrote:
Ordered.
Whooaaaa… you are the fastest to order ever in my long experience in group buys! Cool
Adhara
tatasal wrote:
Adhara wrote:
Ordered.
This is an automated reply from AdharaSnipe™ – the automated web monitoring and automated buying AI system.
The user you quoted will be forwarded your post, and will reply at their earliest convenience.
And thank you for the compliment on the speed!
tatasal
Adhara wrote:
tatasal wrote:
Adhara wrote:
Ordered.
Automated Web Monitoring and Automated Buying AI system, hmmmm……AI as in ‘Artificial Intelligence’ ?
Dahibe29
Last seen: 12 months 3 days ago
Hola quisiera el codigo para compra uno para España gracias
Dahibe
tatasal
Codigo enviado
