Convoy L2 XHP50.2 K2-1C outdoor performance
151 posts / 0 new
Simon Mao
Simon Mao's picture
Last seen: 14 hours 8 min ago
mhds wrote:
Hi Simon, Any estimated date for releasing L2 XHP35 ?
Driver is in production ,i’m not sure the date
mhds
Last seen: 7 months 4 weeks ago
Hi Simon,
I saw l21a on xhp35hi already available ! This is running on single 18650/26650 cell, how about luminosity and distance of the flashlight ? I’m right now ordering it Smile
QMT93
I thought the L21A runs on 2×21700, while the L2 runs on 26650, or 18650. The M21A runs on 1×21700, and is the 21700 version of the C8+.
Is there a new L21A running 26650?
Yokiamy
Yokiamy's picture
Last seen: 4 hours 2 min ago
The L21a runs on 1 single 21700 (i bought one recently)
It does NOT come with an extension tube. (It doesn’t come with any accessories actually, not even a lanyard…)
Unloco
Last seen: 10 hours 56 min ago
L21A runs only 1*21700 or 1*18650 w/adapter.
26650 only on L2.
QMT93
You’re right. I just read the group-buy description again. I don’t understand why, because the SST40 can take 2×26650, which is higher in voltage than 1×21700.
Yokiamy
Yokiamy's picture
Simon, do you have any indication/comparison numbers of throw and Lumen of the L21a in SST40 vs XHP35 ?
Yokiamy
Yokiamy's picture
The sst40 is a 3V LED, also the driver is only suited for 4,2V
https://nl.aliexpress.com/item/32989372464.html
QMT93
Sky Lumen has a modded version of the L2 with SST-40 on 2×26650 for 280kcd. If I understand this correctly, it’s a buck driver (DriverVN4), based on the spec of the SST-40 you provided?
Yokiamy
Yokiamy's picture
I’m not familiar with Vinh his drivers, Simon (Convoys owner) does not support 2× 26650 for the SST40 (at least not the L21a)
ecotack
ecotack's picture
Last seen: 6 days 17 hours ago
@Simon. Looking at the XHP35 driver, can I just confirm that its 2.3A at the output and single cell only (i.e., won’t work on 2 cells)?
Would it file down enough to fit an L2 (~21mm)?
Two of my lights (L2 and S11) have XHP35 HI and are using the H2-C 22mm 1.5A from KD, so your driver is very interesting.
Yokiamy
Yokiamy's picture
Yes, that should work, the driver is just released, single cell driver for XHP35.
It should fit, since the L21a (21700 version of the L2) is the first to be introduced with this driver.
https://nl.aliexpress.com/item/4000056253432.html?spm=a2g0z.12010612.814...
Simon Mao
Simon Mao's picture
mhds wrote:
Hi Simon, I saw l21a on xhp35hi already available ! This is running on single 18650/26650 cell, how about luminosity and distance of the flashlight ? I’m right now ordering it Smile
it runs on 18650/21700 battery ,
170KCD, 824meters
Simon Mao
Simon Mao's picture
it runs on 1pcs 21700
Simon Mao
Simon Mao's picture
L21A XHP35 820meters
L21A SST40 720meters
Simon Mao
Simon Mao's picture
22mm ,it only can be installed in L21A
DB Custom
DB Custom's picture
Last seen: 2 days 12 hours ago
Boy does THAT sound like a challenge… Big Smile
ecotack
ecotack's picture
Just ordered 2. I love a challenge Wink
abgx1
Last seen: 5 days 3 hours ago
Can l2 throw 2000lm all the time?
Can it work on 21700 battery?
Or is there any other convoy flashlight under 50€ which can do this?
Yokiamy
Yokiamy's picture
Can it work on 21700 batteri?
For 21700 , there is the L21A version with XHP35
I don’t know if it has temperature stepdown, otherwise removing the NTC on the driver will disable it.
abgx1
Removing temperature stepdown wont solve the problem, cos then you cant hold it in your hand Smile
So tldr:
2×21700 big flashlight with good cooling and over 2000lumens
Size and weight isnt problem
Simon Mao
Simon Mao's picture
2400LM,
no adpater for 21700 battery
abgx1
So 2× 26650 version can also work on 2× 21700 without adapters?
Is it able to be cold enought to hold even on full 2400lm mode?
If yes I am going to order one right now Smile
DB Custom
DB Custom's picture
abgx1, why 21700? The Golisi 26650 almost matches a 30T and has 50% more capacity.
DB Custom
DB Custom's picture
You will need to make a tube to prevent battery rattle if you go with 21700’s, roll up thin cardboard or something…
abgx1
Its working with 21700 great, its not even rattling, as they are very long, so there is enought pressure from springs that they wont move
LessDark
LessDark's picture
Last seen: 2 weeks 22 hours ago
Any plans for releasing a xhp50.2 3v single cell version of this light?
Sari33
Last seen: 1 week 4 days ago
I would see also a New L2 with Larger driver bay
abgx1
temperature after running for 30mins on full in room temperature without moving
pennzy
pennzy's picture
Last seen: 1 hour 16 min ago
Just a shout out to Simon for good CS. I placed a small order for TIR lenses and asked for a C8 driver retaining ring. He threw in 2 free ones and got the order to me door to door in 2 weeks. Great service.
