L2 XHP50.2 / Driver for XHP50.2 / M1 M2 SMO reflector
22 posts / 0 new
Simon Mao
Simon Mao's picture
Last seen: 2 days 12 hours ago
If you want to DIY your L2 you have bought ,following driver is available
M1 M2 SMO reflector available now
L2 XHP50.2 is on sale now
BLF 15%off
Edited by: Simon Mao on 01/03/2019 - 03:01
Anthon
Last seen: 1 day 21 hours ago
Do you have OP reflector for the L2?
Are you going to release a driver for single cell instead of 2S?
Yokiamy
Yokiamy's picture
Last seen: 1 min 37 sec ago
If single cell, i will definitely buy one
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 hour 42 min ago
Input voltage is 6-8.4v so its 2 cells in series. The driver space is big on the L2 so you have heaps of option. Should be able to fit a 22mm driver in one.
Chatika vas Paus
It’s nice that there are SMO reflectors, but I would prefer a AR glass for these flashlights. They have an unusual size and I have not yet found a matching one.
Petr J.
Petr J.'s picture
Last seen: 24 min 58 sec ago
On two cells, the flashlight is too big. For 2400 lumens, one cell is enough.
Jaded
Jaded's picture
Last seen: 11 months 1 week ago
On two cells, your flashlight gets more runtime and better efficiency. Also, you avoid noise issues prevalent in most boost drivers.
djozz
djozz's picture
Last seen: 4 hours 54 min ago
I killed a XHP50.2 with a 3A boost driver (from KD) , the XHP50.2 may be extra sensitive to whatever boost drivers do with a led.
Simon Mao
Simon Mao's picture
I test orange peel reflector for L2 before. The beam is greenish,too And I have xhp50 driver sample for single cell, Diameter is 22mm, It’s a little large. I asked host factory to design 21700 L2 version, Diameter of the head is 55mm,( Diameter of the L2 head is 64mm), The sample can be used in 21700 L2
Simon Mao
Simon Mao's picture
I will ask lens factory to produce some ar coated,,
Lexel
Lexel's picture
Last seen: 1 hour 15 min ago
for 2 S I also got a proper buck driver with NarsilM, or Toykeepers firmwares
but that one can crank out a lot more amps to the LED tested up to 8A pushing the XHP50.2 to the limit
above 5k OTF lumens
polarweis
polarweis's picture
Last seen: 1 week 1 day ago
Simon, why make the head of the 21700 L2 smaller?
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 6 days 7 hours ago
Simon, can you please confirm the pricing of your SMO reflectors? Am I correct that 2 pcs of the M1/M2 SMO reflectors cost $ 5.34 while 1 pc would cost $ 4.32, i.e. if I buy 2 instead of 1 it would only cost $ 1.02 more? It's a bit confusing as AliExpress uses the "price / piece" term. Thank you!
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 19 hours ago
It may seem strange, but this is actually regular pricing.
This is to incentivize buying in bulk so price/unit go down significantly as you buy more units.
Simon Mao
Simon Mao's picture
Lux-Perpetua wrote:
Simon, can you please confirm the pricing of your SMO reflectors? Am I correct that 2 pcs of the M1/M2 SMO reflectors cost $ 5.34 while 1 pc would cost $ 4.32, i.e. if I buy 2 instead of 1 it would only cost $ 1.02 more? It’s a bit confusing as AliExpress uses the “price / piece” term. Thank you!
yes, you understand it correctly ,This is because the cost of shipping is too high, but if you buy more, the average shipping cost per item is less, so the more you buy, the cheaper it is.
Simon Mao
Simon Mao's picture
Just to keep the coordination, of course, I can also let the manufacturer keep the head diameter unchanged,
what’s your opinion?
Lux-Perpetua
Thank you Simon! That's good to know. I'll then take at least 5 pcs of each version (M1/M2). Wink
Lux-Perpetua
Simon Mao wrote:
Just to keep the coordination, of course, I can also let the manufacturer keep the head diameter unchanged, what's your opinion?
I would appreciate it to leave the head diameter as is. Especially, in terms of differentiation to the Convoy C8+ it would make sense to keep the current reflector size or even increase it a bit. The L2 with SMO would nicely fit to the Osram KW CSLPM1.TG, a.k.a. "White Flat 2mm²", driven at 8A with 1,400 lumens. The only problem left is to find a proper 20mm buck driver for 1S and 2S operation that can supply enough current to the LED.
Concerning XHP35 operation in the L2:
There is a driver from KD (Kaidomain) that - in its latest revision - can run the XHP35 up to 1A even though it is not specified for 12V operation.
http://kaidomain.com/Flashlight-DIY-and-Tools/Circuit-Board-Driver-Board...
I have already asked BanL from Kaidomain how to overdrive this driver. So far, the XHP35 will run in a Sofirn C8S with up to 1,700 lumens but not beyond due to insufficient forward voltage.
HONDARIDER
HONDARIDER's picture
Last seen: 5 days 19 hours ago
What is the difference in the M1 vs M2 reflector? Material? One is quite a bit heavier.
Edit- figured it out. Model numbers for different lights. Duh.
Satan@103TFS
Last seen: 22 hours 29 min ago
Is it possible to get 5000 mA output ?
Lexel
Lexel's picture
with my modding driver up to 8A
Gerrit
Last seen: 1 hour 35 min ago
Sounds great Lexel Thumbs Up
