Would 2x18500 be roughly length equivalent to 3x16340?
11 posts / 0 new
xevious
xevious's picture
Last seen: 6 hours 33 min ago
I have a flashlight that will take 3×16340 cells in series. Would two 18500 cells be able to serve in replacement, presuming the width (18mm) will fit?
EDIT: Sorry, I meant “16340” not “16430”… typo. Also, sorry for not providing greater context. The Lumens Factory P60 drop-in that I’m running can handle up to 14v. I have it installed in a Pila GL3. I had forgotten what cells it originally took and learned later that they were Pila 300P cells. Two of them, driving a xenon bulb.
Edited by: xevious on 01/08/2019 - 09:29
bmengineer
bmengineer's picture
Last seen: 1 hour 7 min ago
500*2=1000
340*3=1020
Follow me on Instagram @bmengineer.gear if you:
a: like pictures of flashlights and
b: aren't afraid of Facebook
polarweis
polarweis's picture
Last seen: 18 min 15 sec ago
what is the voltage going to the led?
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
Streamer
Streamer's picture
Last seen: 1 min 15 sec ago
I've never had a 16430 cell. Are you sure you didn't mean 16340?
then: 2x50 = 100mm
         3x34 = 102mm
Henk4U2
Henk4U2's picture
Last seen: 57 min 4 sec ago
Lenghtwise two 18500 cell’s would fit a good ol’ Surefire P9.
And as the 9 stands for 3 * 3V (CR123A) = 9V, it won’t be killed by the voltage of 2 * 4.2V either.
I always think long and hard before I say something really stupid.
Vegas LED Fan
Last seen: 1 week 2 days ago
Either way, it is probably not going to work because the combined voltage of two 18650 batteries is lower than either of the two types of batteries your light was designed for – see below.
CR123A is a non rechargeable 16340 lithium manganese dioxide battery with a 3V output
RCR123A is a rcchargeable lithium ion 16340 battery with a 3.7V output
I tried some 12V LED lights with three 18650 batteries in series and apparently 11.1V is close enough to light the lights for a while. Ditto for a 3 AAA bike light working off one 18560 battery. I never tried it with good Panasonic batteries but the cheap Chinese ***fire batteries would light a 100 lumen bike tail light for about 2 hours.
Barkuti
Barkuti's picture
Last seen: 2 hours 14 min ago
16340 LiFePO4 cells, problem solved. They can deliver some decent current, like these generic cells (Nicjoy branded at FastTech) and these others from Soshine. Label lies, as usual.
Cheers Party
Sofirn C8T and C8F reviews of mine
PMme for a tip Wink thanks
Firelight2
Firelight2's picture
Last seen: 4 min 13 sec ago
Note on terminology:
The first 2 digits are the width, the next two digits are the length. The “0” at the end means the cell is rolled up in a metal can as opposed to being a lipo cell in a foil envelope.
So a “16340” is approximately 16mm wide, 34mm long, and is in a metal can.
And an “18500” is approximately 18mm wide, 50mm long, and is in a metal can.
Note however that these numbers tend to be approximations. Cells manufactured by different manufacturers may vary slightly from the standard dimensions.
xevious
xevious's picture
Streamer wrote:
I’ve never had a 16430 cell. Are you sure you didn’t mean 16340?
then: 2×50 = 100mm
         3×34 = 102mm
Thanks, I did mean 16340 — corrected.
I’d forgotten that the 3rd and 2nd to last digits are the cell length in millimeters. So yeah, providing the spring has adequate compression, the 2×18500 cells would work, presuming there will be some minor length variation by manufacturer. I did not know about the foil with LiPo cells. Very interesting.
xevious
xevious's picture
Cheers Party
Thanks for the link to lygte-info.dk. Great info there! Thumbs Up
HKJ
HKJ's picture
Last seen: 2 hours 55 min ago
Firelight2 wrote:
Note on terminology: The first 2 digits are the width, the next two digits are the length. The “0” at the end means the cell is rolled up in a metal can as opposed to being a lipo cell in a foil envelope.
IEC do not agree with you on this, then say the last 3 digit is length in tents of mm. The shape and chemistry is specified with the letters before the number, like in IMR18650: LiIon, Manganese, Round, 18 mm diameter, 650 tents mm in length.
