Debug my Mtn 17mm FET+7135 problem
9 posts / 0 new
NWoodsman
NWoodsman's picture
Last seen: 8 hours 58 min ago
I just got a 17mm in from Mountain Electronics with Bistro firmware.
It was working, however something has gone wrong. I have 6 modes which the first 3 don’t seem to change in power (like 20%,20%,20%,40%,60%,100%). No moon.
I can back into the special modes: turbo works, strobe works, but batt check is just a dim ‘on’, and bike flash works.
15 clicks to config doesn’t work.
What component is causing this? Can I salvage this?
Edited by: NWoodsman on 01/09/2019 - 00:38
MRsDNF
MRsDNF's picture
Last seen: 4 hours 30 min ago
Sounds like the 7135 chip on the driver is not working.
thisnameisvalid
thisnameisvalid's picture
Last seen: 1 hour 37 min ago
It definitely sounds like the 7135. You could try touching up the solder joints in case they’re broken, but if that doesn’t work it will need replacing.
Lexel
Lexel's picture
Last seen: 1 hour 29 min ago
this is a result of one dead AMC7135 that keeps on all the time
only way to remove all at once and replace or try and error finding the dead one
chadvone
chadvone's picture
Last seen: 14 hours 19 min ago
I think there is only one
Lexel
Lexel's picture
and they are all parallel no way to locate the dead one with measurements
chadvone
chadvone's picture
Maybe I am wrong, maybe I don’t understand what you saying.
OP has a FET+1 driver. Wouldn’t there only be 1 7135?
MRsDNF
MRsDNF's picture
Correct chadvone.
polarweis
polarweis's picture
Last seen: 3 days 14 hours ago
if had almost the same problem. I shorted mine when i put the reflector against the positive wire which had to much solder on it and was sticking out to much. Was a good learning experience tho Cash
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
