NIGHTWATCH Avaritia NA40 SE: triple SST20 3000K, 4000K, 95cri, type-C rechargeable - $42.24 Code: NA40SE New photos in post #53
69 posts / 0 new
Tom E
Tom E's picture
Last seen: 15 hours 29 min ago
Easier to go with std FET+1 for me. I salvaged the 7135's at least, not certain of the original circuit. The battery fit is not good - maybe a longer 26650 button top or something. 18650's don't fit because that ring in the tail is too big. 21700's are too long for it -- really not much play in length - very tight margins. Sure hope they fixed this in the later batch/design.
Ohh - also was able to use the AUX LED in the switch - works well.
Sidney Stratton
Sidney Stratton's picture
Last seen: 1 day 8 hours ago
Thanks, tatasal. Ordered the 6500 ºK / 6000 lm variant. With coupon $6.47 discount (total $47.48 USD). Had eyed this light some months ago, the cool white may not be my favorite but will do the job outdoors. And can mod if needed.
tatasal
Last seen: 6 min 49 sec ago
Cool
Rdubya18
Last seen: 9 hours 53 min ago
Ordered Thanks Thumbs Up
contactcr
Last seen: 7 hours 16 min ago
Tom E, how does the reflector compare side by side with C8F?
Tom E
Tom E's picture
Oh boy, at work now. I don't have SST40's in a C8F, but I got a few other types. Now I'm all confused because the pics I see of the NA40SE in post #1 and on Neal's website show an OP reflector where mine (NA40) is SMO, like the C8F. So, are the pics only for the SST-20's or did they switch over to the OP altogether?
Maybe Neal has the answers? He never replied to a message I left on his website or an email, but I've had back and forth discussions with him on FB Messenger after that.
Notice the Nightwatch lights on Neal's site is in the "Others --> Other Flashlights" listing? Ouch - no respect... laughing
I'll try messenging him bout this...
contactcr
Yea not as concerned about how SST40 looks in both more so about the dimensions and fit and finish. The C8F reflector, like the Q8 seems to do pretty well with most LEDs and has a good hotspot and smooth spill.
Tom E
Tom E's picture
Some pics of the C8F 21700 w/351D 4000K's vs the NA40 w/SST-40's. The C8F as about a 44.5 mm head diameter while the NA40 is about 41 mm. The reflector cups are very slightly smaller than the C8F's. Again, mine is SMO and looks like the new NA40SE is OP, least that's what they show in the pics:
C8F on left, NA40 on right:
NA40:
C8F:
contactcr
Wow more similar than I thought. Thanks for taking the time to do this. It is strange they switched to OP when the SST-20’s have a pretty nice beam that works fine with SMO. Maybe they had a different LED in mind for this originally.
Tom E
Tom E's picture
contactcr wrote:
Wow more similar than I thought. Thanks for taking the time to do this. It is strange they switched to OP when the SST-20's have a pretty nice beam that works fine with SMO. Maybe they had a different LED in mind for this originally.
Oopsie, had the last 2 pics labeled wrong -- fixed that.
Yeah, wonder why they did went with an OP. I'm sure there's loss's for throw. Based on the D4S specs, the best thrower LED seems to be the SST-20 at 5000K or little better at 6500K. The 3000K and 4000K's drop off quite a bit, but in the same % drop as does lumens.
tatasal
Mine is incoming probably within the week.
Will be posting some shots with this baby in the family.
tatasal
26980 batts and tube (reportedly 6,000mAh and 5mohm!):
!TB2j-Zj-SXae5-V1-Bjy1zj-XXa08-VXa-2775880575!
!26980tube-1!
Kit Latura
Last seen: 1 hour 10 min ago
Sorry, but I’m out.
I’m not quite convinced with this model.
Rdubya18
What’s a 26980 ? Where is this tube ? Haven’t heard mention of either of these .
tatasal
Just added in Neal’s website: 26980 tube available, and 26980 battery(6000mah, 5mΩ ) is $8 each,
https://www.nealsgadgets.com/collections/other-flashlights/products/nigh...
Rdubya18
Yeah , I guess I missed that when I ordered .
Adhara
Last seen: 5 hours 4 min ago
I don’t think it can be ordered right now – I looked all over for adding it as an option, seems it’s only claimed as available but no way to add to order. Was ready to pull trigger, can’t be bothered to have to make a later order, so pass for now.
Rdubya18
Must have to message Neil with that request.
tatasal
I am about to remind him about this.
Edit: Stay tuned for website product page update
Edit: Site fixed, you can order the 26980 cell AND tube for the NA40SE
Adhara
yep, I’d emailed him. Got an answer back in minutes. Impressive responsiveness at the very least!
Rdubya18
Thanks , got it
tatasal
Got my grey Nightwatch NA40SE (3000k, 95cri) today: (the blueish tone is the effect of the CW Ledlenser K3 that I use to provide spot-lighting)
Spring-less tailcap, but a protrusion the size of 3mm (h) X 11mm dia. (not the same design in Tom E’s non-SE version.)
Below is the previous tail-cap of the non-SE version (photo courtesy of Tom E):
The front of the tube has to be unscrewed to expose the type-C charging port:
——————————————————-Double O-rings at the back
Nightwatch NA40SE beside the Nightwatch NS22 Seeker:
Control shot —- NS22 (3000k, 95cri) —- NA40SE (3000k, 95cri)
Tom E
Tom E's picture
Thanks for the pics! Good to see they changed that tailcap design, though it looks like it won't work well with 18650's because of the width and flatness of the protrusion. In mine, the spring inside the battery tube was stiff and relatively short, so there wasn't much margin to fit differing size batteries - not sure how the spring looks, and how it handles battery sizes now.
I liked the matte finish, maybe anodized, finish of the SS bezel before but least they stayed with SS. The OP vs. SMO - I'm ok with that, no one else seems to use OP in reflector triples so it makes it unique. Probably better looking beam though it cuts down on throw.
Just might have to order this SE model now - great price for the quality of this light.
tatasal
Tom E wrote:
Thanks for the pics! Good to see they changed that tailcap design, though it looks like it won’t work well with 18650’s because of the width and flatness of the protrusion. In mine, the spring inside the battery tube was stiff and relatively short, so there wasn’t much margin to fit differing size batteries – not sure how the spring looks, and how it handles battery sizes now.
I liked the matte finish, maybe anodized, finish of the SS bezel before but least they stayed with SS. The OP vs. SMO – I’m ok with that, no one else seems to use OP in reflector triples so it makes it unique. Probably better looking beam though it cuts down on throw.
Just might have to order this SE model now – great price for the quality of this light.
Yes, 18650s are just too wide to make contact with the protrusion.
!IMG-20190117-211826
However, the op reflector is an excellent match to 3 x SST20s, and oh yes, great price for the quality of this light, that’s true.
Tom E
Tom E's picture
Yea, depends on the cell wrap's overlap. I guess they narrowed the protrusion, not just filled it in, because mine was pretty wide (can't measure right now). 11 mm is still twice as wide as most spring tops. Again, it all depends on the spring inside that battery tube -- anyone have a measurement or pic? It's fairly easy to remove the top USB charging assembly -- I did it a while back. I dunno - for the NA40 (non SE), I had to use magnets to get my batts to work properly but no one else seemed to complain about it. Or I just like to whine and pick bout something... smile
SKY69
Last seen: 10 hours 27 min ago
Interested
tatasal
SKY69 wrote:
Interested
All purchase information about this light can be found in the first post, check it out!
or this:
Code price: $42.24 — use code: NA40SE
Product link: Order HERE
or: https://www.nealsgadgets.com/collections/others/products/nightwatch-na40…
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 5 min 24 sec ago
Has anyone tested these 26980 batteries yet? 5mOhm sounds way too good to believe it. There are some offers on AliExpress but it would be nice to know who's the manufacturer. I don't think this one will fit into any charging bay of available chargers except for those magnetic cable-chargers like Olight UC.
Tom E
Tom E's picture
I'd like to no know more bout these as well. Someone should make the request of HKJ.
Adhara
Mine showed up yesterday. At least I think it did: the tailcap is labeled NA50, a designation that does not seem to exist under a quick G-Search.
I quite like it for the price, far more than the disaster known as the Fireflies E07.
I don’t expect perfection in execution in this price range, and it’s not there in this light: mine has a pin-head sized mark in the body anodization and the bezel has some minor scuffing (probably from shipping in Chinesium packaging), but not enough to bother me much. Certainly better finish results than my example of the aforementioned E07.
I was surprised at how much of the beam (via SST-20 4000k emitters) is put into a somewhat compact hotspot – there’s actually some usable throw there. The tint/color/color rendering of my emitter choice is fine by me (I’m not a big tint snob). I’ve not put the meters to it, but the ~2000lm turbo claim seems in the ballpark to my eyes.
Using the extension and the 26980 cell obviously increases the size of the unit, certainly to where it’s not going to go in any of my pockets (where with the 26650 cell a jean pocket or jacket pocket is usable), but giving it a nice heft. With the crenelated (somewhat sharply) bezel and this heft, a passable self-defense tool in a pinch. I left the light running on high while puffing away on a couple of cigars, head got warm but not particularly hot, so it seems handling of the thermal load is fine. I have no idea how much run time the 26980 may provide – another item I may test when/if I get around to it.
I quite like the interface. No click-click-doubleclick-pauseforblink-wait-click-click for lightning disco flicker candle shit here, just a simple click to on with memory, click to cycle low-mid-higher-highest normal modes, double-click to turbo, and hold from off to moonlight. Triple-click gets a semi-strobe mode (as in it appears it is not binary on/off, but bright/dim strobing – I may scope this to verify when/if I get motivated). Hold from on shuts the light down. When in turbo/strobe, a click returns to the regular mode in use before turbo/strobe was selected. A nice feature for flash-and-dash is this includes “off” as the last mode in use: from off, one can invoke strobe/turbo and then click once to return to off.
Overall, I got more than I was expecting and more than my money’s worth of features/functionality/quality.
