set BLF a6 to turbo only
8 posts / 0 new
fmiller4
Last seen: 6 months 1 week ago
I have a completely stock BLF a6, and would like it to only output in turbo mode, rather than having me cycle through modes.
I’ve looked at this page – http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/view/he...
While I have no trouble getting it into the configuration mode, the light doesn’t cycle through modes. It just shines at the ‘low’ setting and stays there (no blinking, no switching to the next mode).
Am I missing something? Not waiting enough?
I’m totally new to this, so if I’ve missed something obvious well… it’s not obvious to me yet ( Smile )…
OR
Since one of my uses, my primary really, is as a non-injuring self defense “go away” gadget.
Any recommendations for another – better – option at the same price point that does what I’m asking about?
THANKS!
Jerommel
Jerommel's picture
Last seen: 1 month 1 week ago
bypass (or remove) the whole driver.
2Q19
fmiller4
Thanks!
But… noob…
Can you tell me how (or where to find out how) to do that?
Jerommel
Jerommel's picture
Do you have soldering equipment?
You only have to put the minus of the LED directly to the flashlight body.
So you can solder that (usually back, sometimes white) wire to the first 3 pins of the FET.
You will then use the driver board for the plus spring only.
The driver will still be “ON”, but it uses a negligible amount of energy.
You will not have any low voltage warning or protection anymore.
But you will notice dramatic loss of output when the battery is running low.
This will happen before the battery is below 3 Volts, so it should be okay.
2Q19
Lexel
Lexel's picture
Last seen: 1 hour 7 min ago
easier put battery voltage to fet gate
wle
wle's picture
Last seen: 1 day 12 hours ago
if it has mode memory enabled, won;t it come on in turbo, if you turn it off in turbo? (using mode memory)
fmiller4
I was kind of under the impression that it WOULD turn on in the last mode used.
BUT
Whenever I turn it on it first opens in the low power mode.
After I click twice (off and on) it goes to the turbo….
wle
wle's picture
you do have the ability to configure whether or not it uses mode memory(as well as about 5 other options)
whether it works specifically on turbo, i am not sure
i have one
wle
