Vapcell ICR18500 2000mAh (Green) 2018
Official specifications:
Model: ICR18500
Type: Flat top
Nominal voltage: 3.60V
End-of-charge voltage:4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 2000mAh (0.2C discharge)
Min capacity: 1950mAh (0.2C discharge)
Weight: Max:35g
Internal resistance: Max:50mOhm (AC 1kHz)
Standard Charge: 1000mA,CCCV 100mA cut-off
Charging Time: 3hours(standard charge)
Quick Charge Current: 1500mA
Max Continuous Discharge Current: 5A
Operating Temperature: Charging, 0°C ~ 45°C, Discharging, –20°C ~ 75°C
Storage Temperature –5°C ~ 35°C
This is one of the less used sizes, this battery is not a high current cell.
The discharge curves tracks fairly well and it can deliver the rated 5A, but definitely not 10A.
Conclusion
The battery looks good, but with the size and 5A limit its applications are limited.
Notes and links
This size battery matches 3 CR123 primary batteries in length and voltage, but is larger in diameter.
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
