Astrolux FT03
142 posts / 0 new
sb56637
sb56637's picture
Last seen: 3 hours 4 min ago
Astrolux FT03
http://budgetlightforum.com/node/65210
Wow, 875m of throw eh? With an SST40 does that sound like a realistic range to those of you who are more informed on throwers? If so, it appears to be far and away the best thrower for under about $70, to say nothing of the sub-30USD price range. Are there any other options for under $40 that can do 900 – 1000 meters?
Edited by: sb56637 on 01/14/2019 - 18:36
Lexel
Lexel's picture
Last seen: 20 min 38 sec ago
The specs of this light are a bit too optimistic
I would rather look for a light that utilizes white flats with a regulated driver
Nicolicous
Nicolicous's picture
Last seen: 5 hours 4 min ago
Flat black / white flat led on convoy s8+ with 5A regulate driver can reach 900m.
The light is more compact and pocketable to carry Smile
Cost add up is around $30 but you have to mod yourself Silly
Nico -.-
Riesbachtaler U...
Last seen: 6 months 1 week ago
I think the Lamp in this size is unique with the SST 40 LED.
Best Greets Ernst
EDH
P33
Last seen: 2 hours 44 min ago
They advertise it as SST-40 flashlight but also list NW as an option. As far as I remember this emiter doesn’t come in this flavour even in the specsheet.
Im very optimistic about this light but it looks like we have to wait a bit for some more information.
bluereidon
bluereidon's picture
FT03 looks very promising and just looking at the shape and form of it I think it will be great pocket thrower.
I never had a torch with SST-40 emitter how it compares to Cree XHP 35 HI?
BlueSwordM
BlueSwordM's picture
Last seen: 8 hours 9 min ago
@P33, the SST-40 does come with NW.
Just at a lower flux bin.
P33
Well, I guess I’m not so smart after all.
Is it available in hi CRI anywhere?
djozz
djozz's picture
Last seen: 3 min 19 sec ago
It seems that the NW SST40 just became available, Luminus has not even adapted the datasheet yet, pretty cool if Astrolux uses it straight away. It is 70CRI and higher CRI is not available…yet?
sb56637
sb56637's picture
Does the claim seem realistic that the FT03 could handily beat the developing Sofirn SP70 in throw? (875m vs. 700m) ?
ZozzV6
ZozzV6's picture
Last seen: 2 days 13 hours ago
My google tables line 46 is a Convoy L2 with fet driver and full spring bypass.
2226 lumens, 172400 cd and 830,4m throw. The FT03 has 4-5mm bigger head than L2 so maybe reflector is also bigger. I think lumens will be 2000-2200 and maybe throw will be over 800m I hope for 850m but not more. The SP70 has an XHP70.2 which is a huge led compared to SST40 so it will give more lumens and bigger hot spot, more spill but less throw.
sb56637
sb56637's picture
Thanks very much.
And what about compared to the BLF GT Mini?
To me the FT03 is definitely looking like the bargain thrower to beat.
ZozzV6
ZozzV6's picture
My tables containing GT mini also stock and modded and a lot of other lights with beamshots Wink . If you click on the name you can see beamshots of the flashlights and compare them by picture also.
GT mini has less throw. This FT03 is a bargain. I will buy 2 for sure. One stock to compare with the other. In the other I will try multiple leds like XP-L HI, Samsung LH251D, Luuxeon V, Luxeon V2…. etc.
JasonWW
JasonWW's picture
Last seen: 13 hours 25 min ago
Like Zozz’s says, it’s two very different lights. The SP70 is not made for distance. It’s limited to the big led and med reflector size. It will be many times brighter and have a much larger hotspot, but throw distance is limited. Although, if you were inclined to slice the dome off the 70.2, not a factory option, you would probably hit 1000 meters.
The $30 group buy price of the FT03 does seem like a bargain. The group buy price on the SP70 will also be a bargain. Big Smile
Click this to go to signature links.
HONDARIDER
HONDARIDER's picture
Last seen: 1 day 3 hours ago
Still have not got mine. Guess mine is in the second batch, taking forever seems like.
Siftah
Siftah's picture
Last seen: 1 week 5 days ago
Ordered from BG on Feb 15th and it’s just arrived today!
Looks good, but don’t have a cell with me to test it yet – had forgotten it was still on order after 2 months wait! Smile
TomNMich
Last seen: 4 months 1 week ago
Ordered mine from Mateminco on 4/13. Received it today. (16 days). Neutral White. Runs for 7 min. on turbo before step down. Gets pretty hot. No glue.Works perfect.
Siftah
Siftah's picture
Just had a quick try of it and compared it to a Thrunite Catapult V6 – much nicer tint than the Thrunite, beam doesn’t seem too much different though, just a little extra reach with not quite so tight a hotspot.
Doesn’t really look much different though, with the extra size I’d probably not pick the FT03 up before the Thrunite if I were to be carrying it in my pocket. UI’s on them both are comparable.
Nice light though, probably will end up living with my camping gear as I start to move it all across to USB-C.
Nicolaas
Last seen: 1 month 1 week ago
I missed this one and when I visited the Banggood web the price was back up to approx $50,— ………..bummer.
Then, couple of weeks ago it was on sale again so I purchased on with SST40 in 5700K (although a little too cold for me still acceptable).
I fired it up with one of my Keeppower IMR26650 / 6000 (the good ones, almost impossible to find now).
WOW! Nice light!
Looks great
Ano is great
Has a good feel to it
Lens is coated
Reflector is ok. Not the best, but ok.
Led is perfectly centered.
So I measured the throw with my cheap lux meter and got (on turbo, i.e. double click) 275Kcd.
Wait, what? That much? I thought they were being promoted to have 190Kcd. Lux meter ok?
Today Djoz came over to collect a light I bought for him of the German flashlight channel and he took some
measurements as well. Conclusion:
286Kcd at startup
277Kcd after 30 seconds.
I haven’t checked but perhaps the 190Kcd is highest setting at normal ramp-up?
Anyway, 277Kcd translates into 1050 meter viewrange.
Excellent performance and value!
My conclusion: unbelievable value for money, absolute winner!
Cheers,
Nico
PS: due to this unexpected high performance this will be one on the very few lights I own that will not be modded………
rikr
rikr's picture
I just got one also, great thrower for the money. I got mine for $32 shipped
 New Collection / Old Collection
Nicolaas
Update and small correction: Djozz used a lux meter that exaggerates CW a little more than we thought.
Throw ater 30 seconds = 266Kcd.
And that is with the dome on, still thinking about dedoming it and reaching (wel over) 400Kcd.
Cheers
Nico
Siftah
Siftah's picture
Cheers
Nico
Make sure you share some beam shots if you do, please! Smile
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 57 min ago
Cheers
Nico
Cool… I have a clean de-domed 7500k SST-40 in my FT03, I got Lucky and 3 out of 4 de-domed clean… that one to this day will not give up it’s Dome? Facepalm
KB1428 “Live Life WOT
mortuus
mortuus's picture
Last seen: 7 hours 41 min ago
for 30$ it beats almost the mf02 which is super heavy. Dont think there is a competitor at this price range…
Nicolaas
Like I stated: this light is crazy value for money.
Great design
Great ano
Great UI
Great performance out of the box (266Kcd @ 30 seconds)
Fantastic price.
Con: accessories
With properly dedomed SST-40 is should go over 400Kcd, indeed beating more expensive and bigger lights.
These lights however, can keep up max performance for a much longer period of time whereas the FT03 only
reaches those throw numbers on the – ever dwindling – turbo setting.
That said: if it reaches 190Kcd at normal (highest ramping) setting, the dedomed version should reach around
285 – 300 at max ramping……….not bad at all!
Cheers,
Nico
djozz
djozz's picture
Ha Nico, I attempted to dedome the SST-40 in my FT03 last night, it went far from perfect but I posted about it here: http://budgetlightforum.com/comment/1529446#comment-1529446
Agro
Agro's picture
Last seen: 13 min 37 sec ago
I don’t understand one thing.
I compiled a number of FT03 performance measurements here.
4 people got between 199 and 206 kcd.
5 got 235-266 kcd.
There was no result in between.
Any explanation?
djozz
djozz's picture
5 got 235-266 kcd.
Any explanation?
(mine was in between, I measured 230 kcd for a 5700K SST-40 version)
Two reasons:
1) variation between cheap luxmeters. See my luxmeter tests for an idea how much variation to expect.
2) bad centering and focussing of the led, the FT03 has no provision for adequate centering, the centering piece has a too large hole which even does not fix against the led (it slides over it when too off-center). De SST-40 die is fairly big so the beam does not look distastrous with the led slightly acentric or out of focus, but you can certainly measure it.
Nicolaas
HI,
What dedoming method did YOU use?
Cheers,
Nico
Agro
Agro's picture
5 got 235-266 kcd.
Any explanation?
Two reasons:
Effect 2 should cause Gaussian distribution of measurements. Yeah, I know that 10 is a small group size but the distribution is totally different, enough to make me curious if there’s some actual reason.
Effect 1 – depends. F.e. if there was 1 very popular luxmeter model that measured this light completely off – that would be an explanation.
Yokiamy
Yokiamy's picture
Last seen: 8 hours 50 min ago
5 got 235-266 kcd.
Any explanation?
I measured 230kCd on my NW FT03 with a UNI-T UT-383S
But what Jos said is quite important, this luxmeter has an accuracy of ±5% beyond ≥100,000Lux
Calculating with 5%, 230 kCd differs from 230 * 0,05 = 11,5 kCd,
so in reality it will be something between 215 ~ 245 kCd, where 215 is more likely Smile
  BLF
