Astrolux FT03
160 posts / 0 new
scosgt
Last seen: 1 week 3 days ago
Just order the part. It is an easy fix.
And then use the bad part to learn to reflow!
Don’t forget you need thermal paste also.
JasonWW
JasonWW's picture
Last seen: 1 hour 34 min ago
Reflowing is lot harder than soldering plus we don’t know if he has the tools to reflow, probably not. Remember, he’s not an advanced modder, but a complete beginner. I was modding 2 years before I bought a hot air station and tried reflowing.
He can reuse the existing thermal paste as long as it’s not dried out and chalky.
scosgt
I have done three reflows using a soldering iron I bought on Amazon for $29.
All have been successful.
JasonWW
JasonWW's picture
When you are giving advice to people, it’s important you understand their skill level. If you look at ttylamg’s posts, it’s clear to me they are a very new beginner and don’t understand much about flashlights. I’m not even sure he/she can even solder, so I do not recommend they try something that is even more diffucult.
scosgt
JasonWW wrote:
scosgt wrote:
I have done three reflows using a soldering iron I bought on Amazon for $29. All have been successful.
True, but that’s my skill level too!
ttylamg
Last seen: 1 month 3 days ago
Yes, all very valid approaches. I am taking a lot of short cuts, while mechanically inclined, I resulted in needing a lot of help. I don’t have basic skill or practice in this hobby, so I appreciate the guard rails for sure.
The reflowing video was very informative, but not something I would try just yet. I’ll wait till I accumulate more scrap part
C8+ (osram mod) - FT03 (pending repair) - Chaselight (hack dedome) - FW3A (W aux TIR) - Sofirn C8T - Emissar D4 (W aux TIR) - Convoy S2+ - Sipik (rip) - Solarforce L2
Several laser pointers
Several pocket knifes
scosgt
That is why I suggested buying the replacement board you linked with the LED installed.
That only requires soldering two wires.
I suggest a good soldering iron, a helping hands (you can get that that at Harbor freight) and a solder tip wipe box.
Once you have the light working, you can use the same stuff to practice reflowing the LED on the board you remove, which is toast anyway.
I have had success reflowing using a soldering iron. I know that is not the preferred way.
Just keep in mind, if you remove an LED from a board and then replace it with an LED you took off another board, you don’t need flux or to add any solder to either part. In my VERY limited experience re-used parts have enough residual solder to just use heat,
YMMV!
JasonWW
JasonWW's picture
YMMV!
I always replace the solder with fresh, high quality leaded solder. I also add extra flux.
You don’t know if enough solder was used from the factory plus you might loose some due to being stuck to the old led. If you have just a tiny bit too little you may not get good contact over the center thermal pad. It is the deepest pad. This can result in poor heat transfer and the LED burning up. It’s better to have too much than too little. Plus the old solder might be lead free which is harder to work with and requires higher temperatures.
The solder in liquid form can take just 10 seconds or so to burn off the existing flux, assuming there is any left in the original solder. There is no good reason to not add extra flux. It aids in the wetting action and helps the solder to flow.
ttylamg
Speaking of soldering, I know there’s google, but do you guys have a link to a good tutorial? I am basically learning by trial and error and watching only. I fixed items in the past but I really suck at it.
JasonWW
JasonWW's picture
Check out this 3 part series from Dave at eevblog. Here is part 1.
https://youtu.be/J5Sb21qbpEQ
JasonWW
JasonWW's picture
Yokiamy
Yokiamy's picture
Last seen: 6 min 7 sec ago
Maybe you want to buy something like this, i am tempted to buy one
HEATING PLATE
HKSJOSHUA_
HKSJOSHUA_'s picture
Last seen: 1 week 9 hours ago
Anyone ever think of making a bat signal cover for the fto3 got the idea when thick clouds were hovering low over our campsite
ttylamg
Finally got the replacement, of course I had to dedome it. I forgot to test it first before I start, now after dedome it won’t light up… just my luck.
JasonWW
JasonWW's picture
Bummer. There is always risk involved in modding lights.
ttylamg
I think it’s a sign for me to explore reflowing. Now I just need to find sources of SST-40
L4M4
L4M4's picture
Last seen: 1 month 4 days ago
Is it possible to flash Anduril on this driver?
I would like to have the ramping not stop in the middle, but go right to turbo and Narsil can’t do that, bus Anduril can.
Why are there even two UI’s that are so similar?
JasonWW
JasonWW's picture
Yes
I would like to have the ramping not stop in the middle, but go right to turbo and Narsil can’t do that, but Anduril can.
Narsil can as well, you just have to change the code and reflash.
They are actually completely different. The only similarity is ramping.
Agro
Agro's picture
Last seen: 14 sec ago
Unheard
Last seen: 13 min 36 sec ago
Big Smile
ttylamg
after several stars (3 replacements), I finally got it working. However, after running it on turbo, it died instantly! And again, it seems that the led died, not the flashlight/driver part, as the button still works and can go into different modes, I even left the star there and used 2 wires to pull current from the star to another led, and that led runs just fine.
do I just have bad luck with SST-40 leds or what?
arw4
That’s a real disappointment after spending the time you have on it. It seems to me that the initial issue of voltage overload may have not only had a detrimental affect on the LED, but may also have adversely affected the FET driver – as you say, the regulated modes are seemingly driving the LED normally. Out of curiosity, what happened to the previous star replacements you made on the flashlight?
ttylamg
The big el cheapo led I got from the dollar store, can be driven on full and lower modes (didn’t play with it fully, but am sure it can be ramped full and ramped down just fine) So I am still some what skeptical about the driver being bad, but I am no flashlight expert.
The stars are just sitting in my drawer along with the ft03 parts.
buck91
buck91's picture
Last seen: 5 hours 30 min ago
Do we know what the vf of these 50.2 FT03 lights is? I received mine (in a gorgeous green ano) a short time ago and so far I’m very happy. Thinking about swapping to a high(er) CRI option than what came with it. 3v, 6v or 12v LED?
JasonWW
JasonWW's picture
Forward voltage or just voltage? It’s a 3v led. All FT03/S are 3 volt.
buck91
buck91's picture
Great. Just didn’t know which version of the XHP50.2 they used. I’ll have to start watching for a good tint/CRI 50.2 to replace it with.
Fwhomeboy
Ok, now I have the FT03 and the Fireflies E07, I think I have the best of both, flood and Throw. Is there a single cell Thrower that’s smaller than the FT03 but just as good? Thanks.
The New Guy
arw4
Have a look at this article for useful guidance.
https://1lumen.com/farthest-throw-flashlight/
Fwhomeboy
Ok, thanks
The New Guy
ttylamg
what are the compatible star and led available for this light? thinking about turning this into a colored light that looks like a laser.
