[♛ FreemeGB] Amutorch TC500 (upgraded) 2200lm* 21700/18650 Flashlight Group Buy - (ACTIVE)
142 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 3 hours 22 min ago
It’s pretty obvious it’s using a Luxeon V.
It’s the only other Lumileds emitter that could do this on DD without being a Luxeon MZ.
Still, I’m quite interested in the light. Please send in the code freeme.
mmalive
I am interested x 2
What are differences in tints below. Please advise.
Luminus SST40 CW
Philips Luxeon NW
XP-L HI CW
XP-L HI NW
Rusty Joe
Rusty Joe's picture
Last seen: 2 weeks 3 hours ago
If not DD, I am interested in the SST40 version.
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
d_t_a
Last seen: 17 hours 47 min ago
freeme wrote:
There are total of 4 emitter options to choose from.
  1. Luminus SST40 CW
  2. Philips Luxeon NW
  3. XP-L HI CW
  4. XP-L HI NW
Interested, can you give a description of how is the lumens and throw for each LED type?
I know XPL-Hi is throwy, and should be something like 1000-1300 lumens (basing from other flashlights using XPL-Hi)
Luminus SST40 is a mixed flood/throw LED (probably similar to XHP50.2), with around 2000-2200 lumens (basing from other flashlights with this LED).
I’m not familiar with the Philips Luxeon LED — how is the lumens and the throw compared to the XPL-Hi and SST40?
Rusty Joe
Rusty Joe's picture
d_t_a wrote:
  1. Luminus SST40 CW
  3. XP-L HI CW
  4. XP-L HI NW
Shouldn’t SST-40 be the same as XML2 die-size-wise?
www.omad.info
vik267777
Last seen: 1 week 6 days ago
Interested
d_t_a
The Amutorch Ali store indicates these specs:
https://www.aliexpress.com/store/product/Amutorch-2019-Newest-TC500-2200...LED-Flashlight-doulbe-switch-1-21700-and/3008024_32972236730.html
Quote:
Specification:
Material: T6 Aluminum alloy
Battery: Not included, powered by one 21700 li-ion battery
LED: Luminus SST40 2200lm / Philips LumiLEDs LUXEON 2200lm / CREE XP-L HI 1200lm
Light color: Cool white & Nature white
Lens: Highly transparent tempered coated glass
Switch Location & Type: Side and tail of the flashlight
Impact Resistant: 1m
Max Output: 2200Lumens
Waterproof: IPX-8 Waterproof,under water 2m
Color: Military Grey
Weight: 280g
UI Mode: Fully Press the tail switch to turn on/off the flashlight, press slightly the switch at the side of the torch to adjust the light, which are successively Low, Med, High, Turbo (double-click quickly), Strobe (quickly triple-click quickly). The strobe function can be activated by double-click quickly at any luminance level.
Features:
Material: Adopt quality T6 aviation aluminum Alloy manufactured through CNC during the whole process. the surface is processed with hardened and wear-resistant 3rd level hard oxidation. Scratch proof and wear-resistent.
Low voltage warning & Reverse polarity protection: Practical and durable with high quality constant current drive circuit! It has reverse polarity protection function and low voltage prompt function.
Super white tempered double-sided anti-reflection AR-Coating lens..
Integrated lamp head, solid aluminum, Unique encrypted radiating fins, Faster cooling performance.
Unique solid and integral heat dissipation structure at lamp head, discarding independent circuitry cabin that conducting heat through medium. Removing the heat conducting oxide layer after oxidation through CNC in order to achieve a quicker heat and energy conduction and dissipation generated by LED, thus extending the lifetime of LED and slowing down light wane!
Pure purple base plate with thermal and electrical separation process is used for LED base plate. thus extending the lifetime of LED.
The inner electric conducting PCB and the anti-chatter spring.
Cool white and Nature white are available:
Cool White: color temperature 6500K, white light, bright strengthening, maximum luminance can reach 1200 lumens!
Nature White: color temperature (4800K), strong penetrability, good color rendering property, excellent performance in rain and fog weathers. Protect eyes from feeling tired with long lightening up. Not as bright as the white color, the white light is recommended for customers who prefers it to be bright.
SST40 LED only have Cool white light color now
Looks like the Philips Luxeon has similar stated lumens as the SST40 of 2200 lumens.
*“pure purple base plate” = I think it’s from Chinese-to-English translation inaccuracy and probabably means “pure copper base plate”
Agro
Agro's picture
Last seen: 3 hours 36 min ago
d_t_a wrote:
  1. Luminus SST40 CW
  3. XP-L HI CW
  4. XP-L HI NW
Not really. As already stated, SST-40 has XM-L2-like die size so it’s much throwier than XHP50.2,
Luxeon V is floodier.
prilo
prilo's picture
Last seen: 12 hours 34 min ago
I am in
LarryLumens
Last seen: 1 month 1 week ago
Interested
Give me thrower or give me pizza.
Johm
Last seen: 5 days 18 hours ago
Agro wrote:
SST-40 has XM-L2-like die size so it’s much throwier than XHP50.2, Luxeon V is floodier.
Are you sure the Luxeon V is floodier than the SST-40?
The Luxeon V has a smaller footprint (4040) .
contactcr
Last seen: 3 hours 48 min ago
The Luxeon V is similar to an XP-L HD. The die size and the dome are more important in determining flood/throw than the ‘footprint’ or package size (3535, 4040, 5050)
Agro
Agro's picture
Luxeon is flip chip and flip chips are flooders usually.
But this time that’s not the case, I was wrong and stock they offer practically the same cd/lm.
Note that SST-40 can be dedomed with great throw improvements. With Luxeon V the improvements are marginal.
Source:
http://budgetlightforum.com/node/58842
http://budgetlightforum.com/node/58900
Johm
Source:
Thanks Agro for looking into it.
So, we should expect similar basic characteristics with the sst-40 and luxeon V. (Lummens and throw)
And both leds are ‘rumored’ to have minimal tint shift.
So I’m guessing the biggest difference (apart of-course from the tint) will be Amperage draw in direct drive.
Do you know which led has a smaller Internal Resistance?
Agro
Agro's picture
Hard to tell. You may see in the Luxeon V thread that I linked to that 2 samples from different sources that Koef3 checked had very different Vf.
d_t_a
Is there a code for the pre-order already? Interested to try the Philips Luxeon V model..
justicemanvn
Last seen: 1 week 2 days ago
interested
vik267777
Ordered Philips Luxeon model
Johm
Any information about mode spacing?
Also, is anybody familiar with Amutorch drivers? What should we expect in terms of efficiency?
HONDARIDER
HONDARIDER's picture
Last seen: 5 days 8 hours ago
Ordered one yesterday and it said “only one left in stock”. Showed to have shipped this morning. Of course we all know how Banggood is with inventory.
freeme
freeme's picture
Last seen: 7 hours 59 min ago
Mine got shipped on the 9th, with expected delivery date on the 20th.
©freemex1thedeals.com
Valera D
Дайте пожалуйста код купона .
awi89
Last seen: 8 months 6 days ago
interested 1 in SST40, could you please share the coupon freeme.
Thanks
d_t_a
Interested. Haven’t gotten code yet. I’d like to try the Philips Luxeon V LED.
Satan@103TFS
Last seen: 9 hours 56 min ago
Anyone got this wonder how it perform, UI, tint and beam of Luxeon V ?
freeme
freeme's picture
I just got mine today. UI is Low-Mid-High + strobe (double click). It does not come with Turbo mode. Luxeon hotspot is larger than XHP35 HI.
BlueSwordM
Can you measure the throw?
Edit: If you can’t, can you do a beamshot comparing other lights to it, or measure the inner diameter of the reflector?
wstrachan
Last seen: 3 days 8 hours ago
anybody have this light?
Beamshot comparison with Astro MT02 or BLF GT Mini?
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
Yokiamy
Yokiamy's picture
Last seen: 2 hours 4 min ago
Interested
  BLF
freeme
freeme's picture
564m with LUXEON NW emitter.
BlueSwordM wrote:
Can you measure the throw? Edit: If you can't, can you do a beamshot comparing other lights to it, or measure the inner diameter of the reflector?
