Is my Klarus G20 a Chinese clone ??
31 posts / 0 new
Craigh9916
Last seen: 3 months 3 days ago
I bought a Klarus g20 off eBay and it came all boxed up and works great and seems perfect Klarus quality apart from I noticed the side switch is different to and YouTube videos of the g20 I have seen in fact it’s the same as the switch on the g10 and g20l but not the other g20’s ? I’m thinking it’s not a genuine Klarus as I haven’t seen any others with this switch endles I’m mistaken , is there a way to tell if it’s non genuine ?
Craig h
Craigh9916
How do I add photos on here of it from my iPhone ?
Craig h
raccoon city
raccoon city's picture
Last seen: 37 min 22 sec ago
wle
wle's picture
Last seen: 15 hours 8 min ago
doubt it is fake, why would someone fake such a unique light?
also none of what i see on ebay is very cheap, so again it is probably real
just guessing
wle
Craigh9916
Ok thanks how do I upload a photo from my iPhone ?
Craig h
M4D M4X
M4D M4X's picture
Last seen: 3 hours 46 min ago
racoon city gave you the link already Wink
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
mmalive
Last seen: 3 weeks 6 days ago
wle wrote:
doubt it is fake, just guessing
China is WELL KNOWN to Bootleg EVERYTHING. I collect toys, and other things. These guys have “ guts “ to bootleg so well. Unless real collectors will not know difference.
hank
hank's picture
Last seen: 4 hours 44 min ago
Could it be the Klarus lights are all made in China, and sometimes the assembly line just overruns a little bit past the ordered quantity, using whatever odd parts are laying around to produce a batch of cheap surplus/knockoffs?
Let me google that:
Quote:
Klarus flashlights – manufacturer round-up – Best Flashlight Report
www.bestflashlightreport.com/2015/08/31/klarus-flashlights/
Aug 31, 2015 – Klarus Lighting Company is a leading manufacturer of illumination tools, including CREE LED Flashlights. They are based in Shenzhen, Guangdong, China. Though it is a relatively new brand, the designers and manufacturers it employs have been involved in the flashlight business for years….
80T
80T's picture
Last seen: 4 hours 22 min ago
I've the same question about my G20 that I've just received today and something just wasn't looking right... I just didn't knew what it was.
That being until I've noticed the different (round) side switch bezel and other small details...
Flashlight was bought from AliExpress: KLARUS G20 USB Rechargeable LED Flashlight 3000 Lumens LED Dual Switch Lantern LED Torch Flashlight Latarka Handheld Linterna
So... beware..
Side switch - round bezel, (instead of square with rounded corners) made of Aluminum (?), flush button cap instead of a convex shape, hollow cheap feel and kinda "wiggly"..
Anodizing - Looks more like paint and comes off quite easily, like... paint. Came with some small scratches from the get go. Just like it's the case with exfoliated paint on a badly prepared surface.
Tail switch - decent feel but kinda stiff and hard to press - wouldn't notice that if not looking for something, would probably just assume that it's the way it should be (idk... maybe it actually is.. Flat Stare )
Body battery compartment - about ~1.5mm of play between the battery and the body I'd say - Isn't that just a little bit excessive ? Idk..
Tail cap - so tightly fit that I wasn't able to unscrew it with all my force and the help of rubber pads and using some pliers (handles side) as leverage, squeezing as hard as I could
USB cable - looks cheap as chips as any other "5 at 1$ deals" made in China...
LED - Looks like an XHP70.2 while the original (?) should be using the older XHP70... Flat Stare (?)
Boost - lasts for 10 seconds sharp before stepping down, no matter what..
Font on head below the charging port - much bigger and plain different than the original seen everywhere on the internet sources, reviews, etc.
[EDIT]
Oh man... just realized... my G20 has 4 brightness levels AND Turbo.. So instead of Low 15LM, Mid 160LM, Hi 650LM and Turbo 3000LM, I have Low, Mid, Hi, Extra Hi (?) and Turbo Flat Stare
[/EDIT]
Ok, some pictures then.. ?
nokoff
nokoff's picture
Last seen: 1 day 48 min ago
Look up the Klarus G20L. That side switch is from the G20L, it also uses an XHP70.2. Looks like maybe an updated G20 version from Klarus
Nokoff..still Made in China 山寨主義
hank
hank's picture
Chuckle.
Blame it on the subcontractor who stocked the parts bin.
80T
80T's picture
I suppose I'll need to contact Klarus with a serial number and some other details to see what is what..
Yes,that does indeed look like the G20L switch, but still.. that's kinda shoddy. Also I don't understand the different emitter type and different modes. Not that I would complain about such upgrades if that is actually the case  but what I'm worried it's that those aren't upgrades/changes of a newer revision but just tells that it's not the real product from Klarus. Anothertthing I can't understand, is what's going on with the tail cap not being able to unscrew it no matter what. Looks like it's welded in place or glued on. So far this is my first Klarus light, but in comparison, the quality looks questionable and of a lower standard than even my Sofirn lights, which supposedly are of a budget brand..
ad78
Last seen: 2 weeks 4 days ago
hey there and my first post here. OP, looks like you have an updated G20. check out klarus website and they updated the emitter and it says XHP70.2 P2 but the picture of the light still the old one. also, from looking at your pics above. your emitter is 70.2! you have 2 dots on the corner
i ordered one from amazon yesterday and i hope ill get the same one as yours!
Annotation-2019-02-13-115824
80T
80T's picture
Hi. Does it also specifies 4 + 1 modes instead of the 3 + 1 that is on the old (?) version ? Anyways, I've got a full refund for mine from AliExpress under the suspicion of counterfeit. Also because I had to damage the thing to get the tail cap off.. which was glued with epoxy - old one isn't..(?)
hank
hank's picture
Quote:
tail cap …which was glued with epoxy
Now that is truly weird.
DMS1970
Last seen: 4 hours 42 min ago
Does it still have push and hold to turn off? If not, I’d prefer the clone.
80T
80T's picture
Mine surely does. And yes I hate that as well, the UI is plain stupid as far as I I'm concerned.
ad78
Here’s mine. Freshly delivered by amazon
Look at the box as labeled 70.2 and manual says V2-2018
7-D38-EE64-3-D92-44-CF-9137-F88-EE5-B6-DF80
8-A34-AC1-B-1836-4-D93-BB75-0746-F4-DD624-A
4-BC5929-D-00-F1-4181-B864-67-D0-ACBC47-BA
80T
80T's picture
Can you open the tail cap on yours, or is it glued with the blue epoxy as well ? If so, I would rather have the original one which had unlocked threads. Greased, if anything..
ad78
Glued tailcap. Also, im reading your post about “boost” are you talking about momentary mode? Yes it will stay 12 secs thats how they designed it. But if its manually put in turbo it will stay on turbo for a long time as advertised.
80T
80T's picture
How would you put it in the "manual turbo" tho... ? Mine only has the momentary... ?
ad78
80T wrote:
How would you put it in the “manual turbo” tho… ? Mine only has the momentary… ?
Low, med, high, turbo. You have 4 steps.
RTFM….
80T
80T's picture
Yes, I do have 4 steps, then the momentary turbo which is brighter than the 4th step, so my 4th step isn't turbo..
ad78
80T wrote:
Yes, I do have 4 steps, then the momentary turbo which is brighter than the 4th step, so my 4th step isn’t turbo..
Its the effect on your eye because you keep on cycling modes.
Do this. Set the side switch to turbo the turn it off. Then you can compare them quickly by using momentary tail switch then side switch. You will notice they are both the same brightness
80T
80T's picture
What I was doing was going up to 4th level, going to the momentary turbo from there, with the cut-off (hold > off > turbo) release the button, then it would return to the 4th level without any cut-off (turbo > release > 4th lvl) So there wasn't any eye adaptation period from turbo back to 4th lvl of brightness.
ad78
[quote=80T]
What I was doing was going up to 4th level, going to the momentary turbo from there, with the cut-off (hold > off > turbo) release the button, then it would return to the 4th level without any cut-off (turbo > release > 4th lvl) So there wasn’t any eye adaptation period from turbo back to 4th lvl of brightness.</
The turbo is the 4th level! Now the step down when doing momentary for 12 sec is not high or turbo. Im assuming its like more than 650 lumens maybe a thousand lumens.
But for manually putting to 4th level/turbo it will stay 3000 in regards to the temp. Mine stays long when im outside since the weather here in CT is god damn cold freezing.
80T
80T's picture
Unless my step-down it's occurring right at the instance when I'm releasing the button after whatever period from half a second to anything under 12 seconds, we're talking about two different interfaces.
Btw...
Can you spot the difference ?
My manual front cover:        VS yours:
ad78
Anything under 12-15 sec its the turbo which is 3000lumens. Without releasing after 12-15secs it will step down to higher than 3000lumens. This is the same setup on the manual turbo selected after 3 mins or so. This is how mine reacts as im ok with it
80T
80T's picture
So you have 4 brightness levels as I understand:
Low > Medium > High > Turbo (which is the same with the momentary Turbo)
What I have is 5 brightness levels:
Low > Medium > High > Turbo and momentary Turbo (which is higher than Turbo from the main sequence)
Now, I don't have a lux meter or whatever other luminous intensity measurement tool, but the 5 brightness steps look pretty much linear to my eyes, like in, hard to confuse them, low to med, med to high, high to turbo and turbo to... let's call it "momentary Turbo Boost"..
So, charged battery, cold flashlight - Turn On with tail cap (Low) > tap (Medium) > tap (High) > tap (Turbo) - this so far is the main sequence (takes 2 seconds tops to go through the 4 levels / If kept, the Turbo would last at least 30 sec. without stepping down) - continuing on - hold 2sec. (Off / eye adapts - unreliable.. ) > keep holding another 2 sec. (momentary Turbo "Boost" - which will last about ~10 sec.) - we still have a cold flashlight and a fully charged battery t this point at about 6 seconds in tops > release button (Turbo - from the main sequence, 4th brightness level) - can see significantly lower brightness than the "Momentary Turbo Boost" (5th brightness level - not accessible in the main loop sequence) - no eye adaptation at this point, as the transition from momentary Turbo "Boost" to Turbo from the main loop sequence is instant as you're releasing the button. Should the Momentary Turbo be the same as the main loop sequence Turbo (the 4th level of brightness) provided that we've accessed it from the main sequence Turbo, releasing the button from this level back to the main sequence Turbo should not make any visible difference between the two modes at least for the first 10 seconds of use or so, after which you can expect the step down.
I don't know how t explain it more short than this, but the short story is that I do have 5 distinctive levels of brightness on this flashlight and it's nearly impossible to not discern between them. If you're saying that your unit has only 4 brightness levels, then we are talking about two different drivers, two different interfaces.
Provided that my manual also looks different that yours, that clearly specifies version 2, it's not so hard to imagine that mine might just as well be a knockoff, which I'm most inclined to believe.
ad78
If you have 5 levels looks like a electronic dysfunction or i must say yours is fake G20
May i know whos is the seller?
80T
80T's picture
As can be seen in post #9, it's AliExpress, Shop being "Ok Light Store".
