Lumintop GT4
1039 posts / 0 new
mortuus
mortuus's picture
Last seen: 1 hour 51 min ago
Lux-Perpetua cool idea they should do it, there is place for it Big Smile
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 3 weeks 2 days ago
Lux-Perpetua wrote:
How ‘bout some nice auxiliary LEDs? Would that be feasible like in the D4S or E07?
Something like the charging indicator in the Convoy BD01 would be coll too.
They use transparent centering-pieces with path through the MCPCB and shell to a LED on the driver.
You can see it here:
http://budgetlightforum.com/node/33514
Agro
Agro's picture
Last seen: 13 hours 45 sec ago
That BD01 indicator is nice!
joechina
Texas_Ace wrote:
nokoff wrote:
Maybe they can take the extra ten seconds to make sure the flat of the battery tube lines up with the button this time instead of being a lottery.
Also this reminds me visually of my old Howitzer, which I loved but didn’t have the output you’d expect in such a huge torch today.
Sadly it is not possible due to the way the machining works. It has been tried many times but it is simply not possible to make it line up without a lot of manual labor to grind each piece individually by hand pretty much.
What about having more length on the tube thread, so users can grind down a quarter or a half turn by themselves?
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 33 min ago
The battery tube can be indexed to any position you want on the GT and GT70, the anchor point on the head was the main complaint.
KB1428 “Live Life WOT
joechina
Ah thanks, now I remember.
wolfstyle
Last seen: 9 min 6 sec ago
I’m in for one.
Lothar
Lothar's picture
Last seen: 3 days 11 hours ago
AlexGT wrote:
I want one!!!
+1
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
Texas_Ace
Texas_Ace's picture
Last seen: 18 min 3 sec ago
species8472 wrote:
Can’t the flats be set to line up with the button by loosening the battery tube slightly until they line up then tightening the tailcap holding it in place? At least that what someone else recommended long ago and I have did ever since. Of course, that won’t help to line up the strap attachment point.
Yes, this is what I do with my battery tubes. Like KB said the head sling point is the one that can’t be indexed.
Texas_Ace
Texas_Ace's picture
Interesting idea, although it would be a lot more complicated then it sounds to actually do it.
Plus Narsil does not support separate LED’s, so the best it would do is be a copy of the side switch LED in function.
I can ask about it though but I am guessing it would increase the price which is already going to be a possible issue.
Tom E
Tom E's picture
Last seen: 3 hours 54 min ago
Hhhmm. Think'n if we got a spare pin on this driver, I could add support for a 2nd AUX LED(s), but may be a bit involved.
Forget how the buck driver support works - if 2 pins, then maybe can't work.
5 available I/O pins:
  • switch
  • AUX LED
  • 2S required voltage divider input
  • 1 or 2 output channels (FET+1 is 2 pins)
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 min 15 sec ago
Thank you Texas_Ace! Thumbs Up
Would there be any downsides if the GT4 came with Andúril instead of NarsilM 1.3, so the AUX-LEDs could be controlled somehow? I assume it's not only about the software but possibly also about more complicated hardware (more channels/pins to control auxiliary functions like with the ROT66 that first came with NarsilM and later on with Andúril?). I doubt that customers interest would be substantial if the AUX-LEDs were hardwired with the side switch only and only light up when it's in standby mode with no chance to deactivate it. Anyway, thanks for asking Lumintop what they think about it.
Texas_Ace
Texas_Ace's picture
It uses an FET + 1 setup, much like the Q8 driver when it comes to pinout. The actual design has been beefed up a lot though.
Texas_Ace
Texas_Ace's picture
Would there be any downsides if the GT4 came with Andúril instead of NarsilM 1.3, so the AUX-LEDs could be controlled somehow? I assume it’s not only about the software but possibly also about more complicated hardware (more channels/pins to control auxiliary functions like with the ROT66 that first came with NarsilM and later on with Andúril?). I doubt that customers interest would be substantial if the AUX-LEDs were hardwired with the side switch only and only light up when it’s in standby mode with no chance to deactivate it. Anyway, thanks for asking Lumintop what they think about it.
I have been trying to get Anduril working for a few months actually. I wanted to use it in this light at first but sadly the thermal control is not stable it seems and allows the lights to runaway to 100c+. Since that is instant burn level it rules it out as a possible firmware for a production light until that can be fixed as you can understand.
Besides a few minor things that I think TK has been working on, I really like Anduril and would like to move to it. Although it also just controls the AUX led’s the same as the switch, there is no separate control that I have seen since they use the same pin.
Another issue would be actually mounting the LED’s in those locations, that would be easier then it sounds without an expensive setup under the reflector. Thats why all the Aux LED’s I see now are either under clear TIR optics or in setups that can have them mounted to the same mcpcb as the main LED’s. This is cheap and easy. Trying to mount them at a different height is much harder.
Lux-Perpetua
Alright, that makes sense and I totally underestimated what kind of effort it would cause to incorporate these little gadgets into the reflector housing plus wiring harness to the main LED-MCPCB. I just thought why not use this unutilized blank space on the front side for some cool add-ons. I have some more crazy ideas but they might be even more unrealistic:
  • paint the even front areas in matte black and add a raised bearing support for tritium vials
  • make those even front areas translucent (preferably frosted) and add aux LEDs in the inner housing close to the main LED MCPCB - the secondary (coloured) light would be bypassed around the reflector and become visible on the outer rim. For instance, you could have a nice red glow effect.
Okay...just wishful thinking...LOL Big Smile
Texas_Ace
Texas_Ace's picture
- This is actually quite reasonable if people this this would be worth it
- Can you elaborate? What do you mean by bearing support? Adding tritium vials instead of LED’s to the front of the reflector would actually be a lot easier then adding LED’s since we would not have to worry about all the wiring hassles. Although it would add noticeable cost since those vials are not cheap last I checked ($5 each I think x 4 = $20 their cost, figure $30-40 added to the retail cost)
make those even front areas translucent (preferably frosted) and add aux LEDs in the inner housing close to the main LED MCPCB – the secondary (coloured) light would be bypassed around the reflector and become visible on those front areas around the reflector
- While this would be cool sadly since the reflector is made out of a solid hunk of aluminum it is just not possible I am afraid.
Lux-Perpetua
Well, about transparent aluminum...I was gladly surprised they finally invented it even without Mr. Scott's intervention into the Federation's prime directive:
https://screenrant.com/star-trek-transparent-aluminum-real/
https://en.wikipedia.org/wiki/Aluminium_oxynitride
Okay...I was just teasing of course. We're talking about a budget light, not a godzillionaire's light. Silly
Lux-Perpetua
Texas_Ace wrote:
[...]add a raised bearing support for tritium vials - Can you elaborate? What do you mean by bearing support? Adding tritium vials instead of LED's to the front of the reflector would actually be a lot easier then adding LED's since we would not have to worry about all the wiring hassles. Although it would add noticeable cost since those vials are not cheap last I checked ($5 each I think x 4 = $20 their cost, figure $30-40 added to the retail cost) [...]
Sorry if I used the wrong expressions. My English today is some kind of...sealed. I thought about something like an embossed area in the flat aluminum area. Inside this recessed area there would be cavity just as the size of the tritium vial, so you could push it into this cavity to keep it there.
Alternatively, there might be the chance to add trit support in the outer rim of the body in those recessed areas of the crenelated bezel...
Tom E
Tom E's picture
Regarding the flat black treatment, always liked the look of the SupFire L1, and similar lights: https://www.aliexpress.com-Supfire-L1, though on the GT4 there isn't as much surface area to cover.
For trits, could probably use the bigger standard size ones. I wouldn't mind trit slots at all, even on the outside neat the front edge, maybe aligned vertically rather than horizontally, but again, the bigger size -- pricey of course to populate.
Texas_Ace
Texas_Ace's picture
Interesting idea, and one that would be mechanically possible.
The issue would be cost, how much are vials now days? Last I checked they were still rather pricy.
M4D M4X
M4D M4X's picture
Last seen: 22 min 2 sec ago
I like this idea!
just mill the slots  .
on the other hand I can hear a lot of people howl because those slots do not line up in a geometrical axle with the switch / leds  / cell cage / grandma's birthmarks Wink
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
nokoff
nokoff's picture
The switch needs to be lit. I don’t like twisting big lights in the dark to find it. Really any lights, but the bigger the more awkward that can get.
Nokoff..still Made in China 山寨主義
Texas_Ace
Texas_Ace's picture
Yes, the switch will be lit like the GT and GT70.
lawallac
lawallac's picture
Last seen: 2 days 56 min ago
I really hope a ww variant is made, even if a limited run. I absolutely love my GT70 with the 3000k 70.2 I understand people like the light saber effect of throwers with the cw emitters, which I agree is pretty cool. But with floody lights ww is amazing.
Theodore41
Last seen: 5 hours 56 min ago
What is ww please?
lawallac
lawallac's picture
Theodore41 wrote:
What is ww please?
Warm white, more like incandescent color.
Texas_Ace
Texas_Ace's picture
Yes, the 3000k GT70’s I built did look pretty good and worked well as well.
No idea at this point what tints they will offer though.
Modding is always an option as well, this light will be easily moddable like my past lights.
lawallac
lawallac's picture
You did those 3000k variants for who, NASA? I mean I don’t see them custom ordering Warm White because they are tint snobs. It really just works better in atmospheric conditions.
Texas_Ace
Texas_Ace's picture
Yes, I did one for NASA and a few others for some BLF members that wanted it.
Nasa wanted even warmer then 3000k because like you said, science proves that warmer works better at throw. They had me de-dome the emitter to gain throw and get it even warmer. Ended up around ~2600k-2700k IIRC.
Theodore41
lawallac wrote:
Theodore41 wrote:
What is ww please?
Thank you very much.
