SEEKING A COHERENT and CORRECT UNDERSTANDING of Li Ion BATTERIES for DECENT TO EXCELLENT FLASHLIGHTS
I am thinking a decent flashlight is one that is a lot brighter than your grandfather’s incandescent bulb flashlight, with LEDs instead of the filament bulbs, built tough enough to live through more than a few batttery replacement or recharge cycles. Key chain lights are not flashlights., so a small decent flashlight is going to take at least 1 RC123 or three AAA or AA cells, which is decently only if has good electronics and non-embarrasing host.
I am thinking an excellent flashlight is going to be in a rugged host and send 1000 lumens out the front.
There is a kind of good flashlight that produces less than 1000 lumens but can survive a nuclear war, like lights from Malikov or Sure Fire. I’d call those special purpose decent flashlights.
MY AGONY
My agony regarding chargers and data has been strictly on the discharge side. I understand that rapid charging of high drain Li ion cells doesn’t save much time because any gain on the rapid charge up to around 4.0-4.1 volts mostly is paid back when the current drops for the rest of the charge cycle, which will run longer after a rapid charge for the first part of the cycle. And for the little time saved, the cells pay a with a more rapid degradation than charging with lower current to begin with.
It’s the discharge that I have found kinda hard to get a handle. I want to make discharge charts like the ones I see in reviews, but I don’t know how to do that. I heard those charts come off custom rigs. I am picturing a custom discharge setup for testing cells and/or a flashlight . When it comes to the actual discharge charts, it looks like there is commercial software for making the charts. Does that mean the custom test rig has to be connected to the computer, and that is possibly accomplished through a USB connection?
I am picturing vendor of battery test systems saying, “This diagram shows how your usb ports/pins have to be setup on your electronics bench for a billion things our software will do, you have to figure . BAscially, you are going to need a circuit ut how to translate that into what you want to see for flashlight batteries that for battery discharge charts, that means you need a circuit with three connection points, plus ground. The connections would be
- Battery positive
- Battery negative
- between the battery positive and the positive side of your charger (or between battery negative and whatever the charger has connected to the battery negative.
Those inputs are going to go through a circuit that is connected to the pins of a female usb micro or usb C . Then a a usb cable goes from the usb micro or C to USB A on a computer, from there to the graphic software that graphs a billion things, battery charge cycles being on possible use of more than I ever would think of.
I don’t see anything like that offered for sale. I figure that must mean I am badly confused.
QUESTIONS TO RELIEVE MY AGONY
Regarding the crazy high current in RC and drones which can be more than 1000Amps, on a burst, I thought the best RC cells today are LiPo. Is it the LiPos that run up to 1000Amps?
Regarding flashlight current, when I see 8A draw mentioned in connection with a flashlights, is that going to be at least 4 cells in parallel to get that current? Or maybe 2S2P bucked down to 3 volts with high current? Was that one of the stupidest questions in history, because it makes no sense?
On the BLF Q8, how can you measure the current?
