Review: Trustfire T62 (Tactical, 2-3x18650, XHP70)
3 posts / 0 new
Budda
Budda's picture
Last seen: 2 months 1 day ago
I received the Trustfire T62 from Trustfire for the review.
The T62 features a XHP70 emitter that can be powered either via 2 18650 or 3 18650.
The T62 comes in this box
Inside the box: manual, 18650 extender tube (to go from 2×18650 to 3×18650), lanyard, spare o-rings.
Here’s the T62 in the 2×18650 configuration
And here with the extension for the 3×18650
Here’s the XHP70 in the OP reflector
The threads are thick and well done, but come dry out of the box.
The tailcap allows easy access to the mechanical switch, but also tailstands.
UI
The UI is simple, the light doesn’t have memory and each time you press the mechanical forward switch, the light turn on at Turbo mode, then cycle between turbo-high -low-strobe-sos, in loop.
Beamshots at 1 meter
Outdoor Beamshots
Output and runtime
All testing was done using 2×18650 2600mAh 18650 cells with PCB.
If you want to see a video beamshot
My thoughts
The light is well built and finished, although the anodisation looks more shiny than the one of other flashlights I reviewed in the past with HA III.
The output is pretty much consistent with the specs, and the regulation is fine, although I am not impressed with the thermal management: when using a fan there is only a small difference in the runtime plots.
With more than 3000 lumen available, I would like to have more levels to have better spacing between the modes.
I am not crazy about having to go through strobe and SOS each time I cycle through the modes.
I wish this light came with a clip, a sheath and in a NW version.
Thanks to: AntoLed, Won, Zampa.
All my reviews, in italian and english, here: Lumenreviews.com
MRsDNF
MRsDNF's picture
Last seen: 14 hours 37 min ago
Thanks for the review Budda. Was thr driver glued in?
djozz
djozz's picture
Last seen: 1 hour 28 min ago
Thanks!
Nice to see a new Trustfire reviewed, it is a bit a brand from the past. And they did not change: built like a tank and a crappy oldschool interface. The output they get with the XHP70 is pretty ok though.
I think that I like the Convoy L6 better.
