EMPs, LEDs, and Lithium B...s
12 posts / 0 new
Barry Lyndon
Barry Lyndon's picture
Map shows voltages induced per meter of conductor (I think).
So how would each of these fare during an EMP event?
LED light — on or off, with or without battery installed (or would the distinctions even matter).
Li-ion — installed in a device versus standing alone, protected vs. not
LiFePo4 — same as above, distinct from Li-ion or no?
Surely a trusty old Mag-lite with alkalines and incandescents would survive just fine? Right?
Edited by: Barry Lyndon on 02/09/2019 - 00:01
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 1 min ago
LED Light: No problem at all, especially inside of an aluminium tube.
All kinds of cells: Unprotected cells will never be affected.
Protected will probably never be affected too, but they have higher standby drain, so I do not recommend them.
I would never trust alkaline not to leak. I would just buy a good 2xAA light, put in lithium primaries, and lock it mechanically if it doesn’t have a tailswitch.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
Couchmaster
Last seen: 3 hours 27 min ago
I’ve wondered about this as well. I’ve wrapped up a couple of S2’s that I’d bought when they were on sale with triple layer of heavy duty alum foil and slipped them into my faraday cage ***cough**garbage can***cough. I’m thinking that since it doesn’t take many more than 5 volts to fry a LED, they’ll all be non-operable. However, that might depend on so many things, they are in metal tubes already getting some shielding, if they were in the basement and the air burst was far away…..?
Yeah, I have no idea. Better safe than sorry, and I’ve alredy modded my maglight to run LED’s…so that idea sounded good…..but….:-)
Barry Lyndon
Are you sure man? Hundreds of volts (even at very low amperages) across those tiny little chips on an LED driver board wouldn’t fry them?
Barry Lyndon
The metal body of the flashlight would be its downfall though. It would act as an antenna and ramp up the voltage by an order of magnitude or two, with the voltage easily jumping the switch gaps and completing a circuit throughout. At least, that’s my very amateur guess.
CREEXHP70LED
CREEXHP70LED's picture
Last seen: 2 hours 40 min ago
Flashlights should be on the bottom of your list of things to worry about, if an EMP hits say Colorado 80 – 90% of all people in the USA will die in the following 12 to 18 months according to our latest briefing back in December 2018.
20,000 5G satellites and over a million 5G towers on the way covering every square inch of the earth in deadly radiation...
Igor
Igor's picture
Last seen: 10 hours 23 min ago
HDS claims their flashlights are EMP proof and were tested. I wonder how they make it EMP proof?
The darkness is afraid of us.
Flashlights are cheaper than therapy.
The_Driver
The_Driver's picture
Last seen: 4 hours 55 min ago
https://www.futurescience.com/emp/EMP-myths.html
https://en.wikipedia.org/wiki/Faraday_cage
Flashlights in general should be unaffected by EMPs because they don’t contain any long conducters. In addition to this the metal body functions as a farady cage, only the glass lens poses a risk (can be solved with a metal cover).
jon_slider
jon_slider's picture
Last seen: 1 hour 59 min ago
its general hype, similar to the claim that HDS can survive being shot.. so can other flashlights..
its a metal tube, that makes it EMP proof, and tends to resist shots..
and Henry did not say the HDS is EMP proof, he said he sees no reason why it would not be
Henry also did not say he tested an HDS for EMP, just that it passes the CE tests, like zillions of other flashlights.. more below
Hogokansatsukan also says the Fulton Flashlight is EMP proof.. also see below:
https://www.candlepowerforums.com/vb/showthread.php?455112-Why-people-pu...
RCS1300; wrote:
From a review in 2014:
“What’s more (and this is sure to stir up a few comments), HDS lights are built contained in a full Faraday cage, hence are essentially immune to EMP. From the founder/owner of HDS Systems, “They were directly tested with high frequency high voltage and were not affected.”
https://www.thefirearmblog.com/blog/2014/09/30/hds-systems-edc-tactical-...
In 2010 on CPF, post on page #895:
Nick,
[I]The electronics in our lights are contained in a Faraday cage and have passed the CE test program which includes high voltage discharge and exposure to high intensity RF. I see no reason why our lights should not easily live through an EMP blast.[/I][
Henry.
http://www.candlepowerforums.com/vb/showthread.php?289558-Ra-Clicky-%28H...
Hogokansatsukan; wrote:
No, it was tested by Henry a few years back. Look at RCS’d post. Used some type of electrical discharge Tesla-esque thingy that I neither understand nor care about.
It WAS tested and CAN survive an EMP according to Henry.
I’m not CNN. I don’t make up stuff because I want it to be true.
https://www.candlepowerforums.com/vb/showthread.php?443899-HDS-Systems-E...
Battle proven in several wars.
Used by more soldiers than any other light.
EMP proof
Waterproof.
Virtually indestructible.
Compact and light weight.
Available in several colors including olive, black, and desert tan.
Pocket clip included.
Easily attaches to MOLLE and tac vests.
Milspec rated.
USMC, US Army, US Air Force, and USCG approved.
Utilizes Military BA-30 batteries, now available at most stores.
Long run time.
Built in light output redundancy.
Bright output.
100 CRI, the highest CRI possible.
Available in warm light output (no cool white).
2 light output modes. Momentary tactical and constant on.
Made in the U.S.A.
Every light can emit red, blue, and 100 CRI white light.
Tail stands easily.
User serviceable and upgradable.
Yes, the Fulton MX991/U. Accept no imitation!
Igor
Igor's picture
Hogokansatsukan confirmed they were EMP proof and also that they were tested. It was posted very recently in the other forum.
jon_slider
Yes, all lights that pass CE are passing the same test. I quoted from the other forum in detail. Just about any metal flashlight constitutes a faraday cage. This is not unique to HDS. Its true for all flashlights that pass CE testing.. no big deal..
here are CE marks on a couple of other metal tube, faraday cage, CE tested EMP Proof, flashlights
Im not trying to be rude, it just feels like Im shouting, the emperors xp-g3 has green tint! and the answer comes back, “not in real life, thats not green, its yellow”. Then I go back to my rose colored glasses, and all is well.
disclaimer, I bought and paid for my HDS, so Im entitling myself to call bullshit when I see it.. hype is hype, thats not to say that the light sucks, it doesn’t. Just calling a spade a spade. Read all about my HDS here
teacher
teacher's picture
Last seen: 32 min 23 sec ago
This is/has been an interesting & educational discussion… Thumbs Up
But the comment posted by Hogokansatsukan , quoted below; is just priceless!!! Big Smile . Big Smile . Beer
I am laughing everytime I think about it….Wink
Hogokansatsukan seems like an outspoken guy!! Beer
bmengineer;5278118 wrote:
So wait… Are you saying it wasn’t actually tested and you made that up?
_____________
Ikiwa wewe ni nyoka uliyoripoti chapisho hili, tafadhali pata guts kutosha kuandika na kuniambia ni nini kibaya na chapisho.
______________
Nếu bạn là bông tuyết bất tận đã báo cáo bài đăng này, ít nhất hãy can đảm nhắn tin và cho tôi biết điều gì sai với nó. Wink
