Test/review of Power Falcon 45W PS300E-ACT-10 UK
8 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 min 30 sec ago
DSC_5640
Official specifications:
  • Model: PS300E-ACT-10
  • Input: 100-240VAC
  • Output: USB-A 5V/2.1A
  • Output: USB-C: 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/2.25A
  • Power: 45 Watt max.
  • Size: 32 × 75.5 × 60mm
  • AC Plug Interchangeable (US, AU, EU, UK)
I got it from a reader
DSC_5628 DSC_5629 DSC_5630 DSC_5631
The charger arrived in a box with specifications and photos of the charger.
DSC_5632
The box contained the charger and four different mains plugs, but no instruction sheet.
DSC_5633DSC_5634
All the different plugs.
DSC_5635
DSC_5636 DSC_5637
DSC_5638
DSC_5639
Charger without any plug.
DSC_5641DSC_5642
EU plug.
DSC_5643DSC_5644DSC_5645
AU plug
DSC_5646DSC_5647
UK plug
DSC_5649DSC_5650DSC_5651
US plug
DSC_5648
Measurements
  • Normal USB is auto code with Apple 2.4A and DCP.
  • USB-C PD have 5V 3A, 9V 3A, 12V 3A, 15V 3A, 20V 2.25A.
  • USB-C also has a DCP, Apple 2.4A and QC3 coding, it is also supposed to support FCP & QC4, but I did not detect it.
  • Power consumption when idle is 0.07 watt.
  • Behind the power switch symbol is a green led (It is not a switch).
  • Default USB-C output is off.
  • Weight: 129.1g without plug, the plug is US:6.2g, AU:11.5g, EU:15.9g, UK:16.0g
  • Size: 75.3 × 60.0 × 32.0 mm without plug.
Power%20Falcon%2045W%20PS300E-ACT-10%20230V%20load%20sweep
The USB-A output can deliver about 2.3A, this is fine for a 2.1A rated output
Power%20Falcon%2045W%20PS300E-ACT-10%20120V%20load%20sweep
The current is the same at 120VAC
Power%20Falcon%2045W%20PS300E-ACT-10%20PD5V%20230V%20load%20sweep
PD can deliver about 4.2A at 5V, this is a bit much for a 3A rated output.
Power%20Falcon%2045W%20PS300E-ACT-10%20PD9V%20230V%20load%20sweep
Output is the same at 9V
Power%20Falcon%2045W%20PS300E-ACT-10%20PD12V%20230V%20load%20sweep
At 12V
Power%20Falcon%2045W%20PS300E-ACT-10%20PD15V%20230V%20load%20sweep
And at 15V
Power%20Falcon%2045W%20PS300E-ACT-10%20PD20V%20230V%20load%20sweep
At 20V the output is “only” 3.2A again well above the rated 2.25A
Power%20Falcon%2045W%20PS300E-ACT-10%20PD20V%20120V%20load%20sweep
And the same at 120VAC
Power%20Falcon%2045W%20PS300E-ACT-10%20230V%20load%20test
Here I did a one hour run at 5V 2.1A and 15V 3A, this worked fine.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp6622
M1: 44.9°C, HS1: 62.4°C
HS1 is from the heatsink.
Temp6623
M1: 65.8°C, M2: 64.3°C, M3: 56.9°C, HS1: 66.3°C
HS1 is the transformer, M1 is the snubber network and M2 is the rectifier transistor.
Temp6624
M1: 59.6°C, HS1: 65.6°C
Both M1 and HS1 is the transformer, the large area is due to the heatsink.
Temp6625
M1: 62.1°C, HS1: 65.3°C
HS1 is the circuit board due to the rectifier transistor, M1 and below is the heatsink
Temp6626
M1: 61.2°C, M2: 62.1°C, HS1: 64.0°C
10ohm
At 5V 0.5A the noise is 17mV rms and 282mVpp.
5ohm
At 5V 1A the noise is 14mV rms and 209mVpp.
2.5ohm
At 5V 2A the noise is 8mV rms and 214mVpp.
10ohmPD5V
At 5V 0.5A the noise is 25mV rms and 640mVpp.
2ohmPD5V
At 5V 2.5A the noise is 31mV rms and 516mVpp.
5ohmPD12V
At 12V 2.4A the noise is 17mV rms and 613mVpp.
10ohmPD20V
At 20V 2A the noise is 43mV rms and 428mVpp.
Tear down
DSC_5652
I cracked most of the glue by whacking at the end of the bottom with a mallet and metal rod to direct the force, then used a screwdriver to break the bottom off.
DSC_5654
Most of the top is a large heatsink, but a fuse (FS1), a inrush current limiter (RT) and a bridge rectifier (DB1) is visible in the corner where the mains leads are connected.
DSC_5655 DSC_5656
DSC_5657 DSC_5658
DSC_5662
To see below the heatsink I removed one screw, the other was not accessible and I desoldered the bridge rectifier instead.
DSC_5663
Near the missing bridge rectifier is the common mode coil (LC1). There is a safety capacitor (CY). The mains switcher transistor (Q2) is at the top and was screwed to the heatsink.
On the low volt side is a 6 pin chip (U20: Marked IAZEJ), it must be a synchronous rectifier controller and just behind the USB-C connector is a power mos (Q21: SPP8637 P-channel), probably for on/off control.
The standard USB output do not have a separate transformer, instead it has a buck converter on a small module.
DSC_5664 DSC_5665
DSC_5666 DSC_5667
DSC_5669
The buck converter module in place.
DSC_5670 DSC_5671
The buck converter module with an inductor (L1) and a switcher (U1: Marked ATQ / J01 / 560)
DSC_5672
DSC_5653
On this side is the mains switcher controller (U1) and a very long opto coupler (DZ2) for feedback. On the low volt side is a USB PD controller (U22: CY2311), the synchronous rectifier transistor (Q20) and a charge optimizer IC for standard USB output.
DSC_5659
DSC_5661DSC_5660
The long opto coupler gives a good isolation distance, but over the slot the distance is slightly low, it is supposed to be 4mm and looks more like 3.5mm, this could have been a problem, but the box has a plastic shield that goes into the slot and secures perfect isolation.
The charger passed the 2830 volt and 4242 volt test, this means it is it is fairly safe.
Conclusion
This is an interesting design with only one mains transformer, but it works well. The noise is low, the coding is fine and there is a decent amount of power on both connectors. It can charge a laptop and a phone at the same time.
I will call it a good charger.
Notes
The charger was supplied by a Mostly Melbourne for review.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 2 hours 5 min ago
Thanks for the review HKJ.
The charger looks great to power the TS100 or the TS80.
Is the seller Australian?
HKJ
HKJ's picture
Not really, the ordinary USB output do not have QC, it is only 5V.
When we get a version with USB-C PD input it will be great.
I suppose so.
True i didn’t think of that thanks! Do you think the TS100 would be able to activate the 20v mode? I am about to buy a TS100.
HKJ
HKJ's picture
No, you need a PD trigger between.
Thanks!
I have a 16v laptop power supply for now but i think i will want more power.
You could write firmware into the TS100 for the PD trigger?
HKJ
HKJ's picture
It lacks the connections and the TS80 do also. USB-C has an extra data wire for protocol (Not only power) communication.
I can always dream Big Smile
Seems like an awesome idea i can solder in limited spaces by using a USB power supply and the TS100/ TS80 no need for a massive power supply.
