I have a Manker MK34 with 219cs that I used for cave photography and stuff (I remove the optics for this purpose). But since using 219bs and E21As I’ve been quite unhappy with the yellowish tint of the 219c so decided its time for un upgrade. After a few email exchanges with Clemence at Virence.com I decided to try his 8xE21A setup on his VR21P4 board (3 of them with 5000K E21As).
The leds arrived a few days ago and as I come to expect, some lovely work by Clemence. I could never align these E21As properly myself. Replacing leds of the MK34 was easier than I expected. Just replaced leds+mcpcbs everything else is stock. Screw holes were exactly aligned. I used fiber glass washers as suggested by Clemence.
Smartphone pictures below
Comparison with PL47 nichia 219B
I temporarily used white paper to cover the sides of the led chambers just to test the output. Around 5500 lumens on turbo compared to around 4200 with 219cs+optics (ceilingbounce+shoebox test). Clemence suggested using thicker wires + solder wick to the leds for better regulated output but I’m happy with it as is since my target was a e21A floodlight with constant 1000-2000 lumen output and would run cooler than stock. Spacers under the mcpcbs to move the leds closer to the lens would probably be a good idea too but I don’t have anything to use at the moment.
Maybe somebody here also with suggestions on how to color the chamber sides white. Are there alternatives to paint? Maybe something matte white I can stick to the sides that won’t burn?
I was first planning on doing this mod to my amutorch at40. But since it probably would not be able to sustain 1000+ lumens I decided to go with my mk34.
It’s not strange at all.
He planned to build a photo light mule with very high output in very high CRI possible with better efficiency and less heat. Now each LED only consumes half the current (Original 12x LED vs 24x LED). This setup will give him longer regulated run time. In my opinion sw45k (R9050/R9080) is not a good photo light for its super rosy tint. 5000K E21A R9080 is much closer to sunlight.
EDIT: 219B sw45k is a super choice for photo light when lots of exposed flesh is the object.
Went back and looked at my emails with clemence and he says that they can run up to 8A per mcpcb (so maybe around 2600 lumens) using 18AWG gauge wires. But for a mule it would be better to use pure copper solder wick to connect to mcpcb since thicker wires would get hit by the light and might get heated too much.
