It’s the Haikelite MT09R, in a blue flavor. Quite the rare light actually.
It’s the one from the Texas ACE MT09R GB. 3x XHP 70.2s, outputting 19 000 lumens of light. Modded with his own driver, and spring bypassed on the driver. Still has the 2 year component warranty from TA.
I also soldered the brass buttons to accept flat tops, and they work very well with flat top 30Qs. Another mod of mine
So, It works with flat top 18650s
Contains all accessories, having the paracord lanyard, the 1/4 inch tripod adapter, and 2 replacement O-rings.
I actually burned a hole in my backpack because of it.
The LEDs are XHP70.2 5700k 80CRI. They actually look quite good for XHP70.2s. Quite a bit of tint shift at low levels, but the higher CRI does make a nice difference outdoors when you don’t blow everything out.
Ewww I don’t like that bypass, no chance of that breaking and touching the ground as your screwing the battery tube on huh…I put the bypass in the middle of the spring, nice and short, had them break and the spring retained the bypass wire. This style in this pic is just asking for trouble.
