Hello I’m trying to find a a good flash light with good quality colours niche 219b (high cri), rampable, and dimmable, with 18650 or equivalent battery type, and zoomable if possible.
Right now I have a surefire G2, a nitecore MH2C (blue bad color of the light), light maverick m10 (better color temperature), and a Eagletac D25LC2.
I prefer these things:
single emitter and precise spot; I can use snoot as well, but the light have to be strong;
high cri (nichia 219B?) not too cool
dimmable, because when I want to shoot faces, I can adjust the light accordingly;
then
What about a Videolight?
What is your distance to your object?
VILTROX L116T
A flood light seems better for faces.
And a camera has normally problems with a hotspot?
I use my Q8 with a home made diffuser, an S2+ with triple 219’s, and a D4 with a homemade diffuser. Individually, or all together, depending on darkness. I also have a couple of TIP’s, on with a 219 but both with diffusers. You might find it easier to adapt a poor LED with the right coloured diffuser if you cannot find a 219 light to your satisfaction. You WILL want to diffuse whatever you use for a more even contrast across the scene. HTH
This is an excellent point. Diffusers are a great tool for photography so you can tailor the tint of the lighting to your needs, based on the subject being photographed.
