I had a customer ask about a AAA cell similar to the KENTLI PH5 1.5v 3000mWh rechargeable Lithium AA PH5 battery
Can this battery use a standard 4.2v lithium charger such as LiitoKala Lii-100? I’ve never come across this type of AAA cell before. From reading it seems to output 1.5V, operate at 3.7V and charge to 4.2V.
These batteries are not rechargeable with any standard NiMH or li-ion charger. They also massively overstate their capacity. There is no reason to use these over regular NiMH except in devices that refuse to operate at 1.2V. You can read a whole lot about them here:
The KENTLI needs an exclusive charger.
They use a third pole for + (around the normal pole of 1.5V +) during charging.
The + pole in the charger is a half moon.
Well, I’ve never heard of them, so I poked around the interwebs a bit. I found an eBay listing for 8 cells plus a charger for almost $60USD on sale! HERE
I also read the tear-down review at that link that Parametrek gave. The cells internally are Li-Po, which is good, but the buck circuit is limited to a couple amps. The use case apparently, is a niche where Alkaline can’t supply a high enough constant current, and NiMH can’t supply a high enough voltage. These cells purport to supply a constant 1.5V until dead, then supposedly quick-charge using the proprietary charger. The reviewer concludes in the comments section that he has no use for the cells himself, but wishes they might become mainstream and lower in price. I think these would be good for AA-only (no Li-Ion support) flashlights and other devices where the higher voltage would be helpful. AA-powered digital cameras are mentioned in the review, as well as the marketing literature.
