[Review] 77 Outdoors D25 Headlamp (18650)
211 posts / 0 new
gchart
gchart's picture
Last seen: 27 min ago
I went out and used my D25 a couple nights ago while I applied crabgrass preventer to my nearly 1 acre. It lit up the yard nicely. And with it being mildly cool out, the temp regulation* helped keep things bright but still in check.
*Stock light does not have temp regulation… It gained that after my MCU swap
aswang
Last seen: 13 hours 16 min ago
Petr J. wrote:
Lightbringer wrote:
I just received some 17mm 60° TIRs I ordered… will try tonight to open it up and see if they fit, and if not, how “off” they might be from a simple drop-in.
What is the result? Is Optics Suitable?
Was able to fit a couple of 60deg 17mm Yajiameis in mine. Had to sand down the diameter and base of the optics until they fit. Also swapped in some neutral white XML2s. Can’t remember exact tint but probably 4C.
~30 cm from white wall. Nice and floody
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 14 hours 11 min ago
In preparation of my review of the D25 I noticed something odd about the beam profile. The spot is darker in the center, seems like a slight donuthole.
Could it be that this is the result of the overlay of two emitter beams, causing areas of erasure and amplification?
Petr J.
Petr J.'s picture
Last seen: 22 hours 13 sec ago
Thank you for your reply I also ordered the headlamp. Yesterday at Aliexpress for a great price – US $ 9.44.
https://www.aliexpress.com/item/Sanyi-D10-XM-L2-LED-Headlamp-Headlight-USB-Charging-Interface-Cycling-Head-Flashlight-6-Mode-Dimming/32954801237.html
blueb8llz
Last seen: 23 hours 22 min ago
Thanks. I ordered one as well. I wonder if it’s the exact same. Looks to be ,but the name is is d10 instead of d25
Lightbringer
Lightbringer's picture
Last seen: 1 hour 25 min ago
There are 3 of ‘em listed, the D10 (1 emitter/lens), the D25 (2 emitters/lenses), and a zoomie (unno).
JasonWW
JasonWW's picture
Last seen: 2 hours 56 min ago
Wow, this is a good thread. I wish I had found it earlier.
Someone said earlier that the D25 and D10 had the same driver.
Here is Tom E’s stock D25 driver.
Here is Flail’s stock D10 driver.
Note the dot on the chip.
The pcb layout looks the same. Maybe these are different chips and the dot has a different meaning for each chip? I really don’t know.
Click this to go to signature links.
Tom E
Tom E's picture
Last seen: 1 hour 38 min ago
Hhmm. The dot should always be pin #1. Maybe a batch of fake MCU got it reversed? Weird...
The U3 labeling is different - maybe the PCB design is different? My pic is not so good, look'n compared, shadows are hiding a couple things frown
sungar
Last seen: 1 month 1 week ago
PCB part just under MCU (between MCU and FET Q1) is different as well. It would be nice to check PCD layout on the back side, but it look like divers are a bit different. I would rather expect the same MCU on both. Used FETs and resistors are different probably due to number of leds used, but I think that schematics might be the same for both. Maybe one of those is just an newer revision.
JasonWW
JasonWW's picture
The pin on the upper right in the driver pics looks like it goes to Batt Neg on both drivers.
Tom’s D25
Flail’s D10
Different revisions
gchart
gchart's picture
Uh oh. Glad you pointed this out, Jason. Glad I haven’t sent out too many MCU’s… they’ll need to check which version of the driver they have.
Here’s mine (D25) with the MCU removed. It appears to be the same layout as Tom_E’s
Tom E
Tom E's picture
Have you guys seen how many names these things are sold under? It's crazy! Sofirn even sells them.
This one with a COB and USB charging looks interesting at under $4 shipped: https://www.aliexpress.com/item/Outdoor-camping-Portable-mini-XPE-COB-LED-Headlamp
pc_light
pc_light's picture
Last seen: 3 hours 57 min ago
FWIW, confirming that my D25 version that worked with your pre-flashed MCU was also – T02-A VER:03.
Seeking the light.
Barry0892
Barry0892's picture
Last seen: 8 hours 40 min ago
actually this headlamp is everywhere in China. 77outdoor purchased them to sell after tested by sofirn. That’s it.
Since the D25 has bad UI, I helped sofirn upgrade the model to make it a little bit different if not much better.
It called D25S with 2* SST40 leds 1200LM and different UI: click to turn on/off, press and hold to change brightness levels.
Will be available soon.
Maybe it still won’t be as good as you think it should be. But it’s more usable.
It officially claims 1200LM because the heat sink ability is not that good for more current. You guys can DIY it as you wish.
WhatsApp: +8615773183209
Facebook: https://www.facebook.com/barry.lee.984991 (my account is disabled cry)
pc_light
pc_light's picture
Sounds interesting Barry0892.
When you say “press and hold to change brightness levels” are the levels the traditional increments or is it stepless/ramping style level change?
Will you be able to extend deals to BLF, many of us do not participate on FB?
Seeking the light.
gchart
gchart's picture
Does sound better, look forward to seeing it
Lightbringer
Wellp, I just used my D25 about a half-hour ago. I still kinda warmed to the UI. It’s… different… but not necessarily bad.
Still, after also having played with my Q8 at length, and GTmicro today, and given that the D25 has an e-switch, it can very very very easily have the same UI as those.
Click to turn on, click to turn off.
Click’n‘hold, or hold-when-on, to ramp up. Unclick then quickly click’n‘hold to ramp back down. Unlike the micro, memorise the last level. Doubleclick for turbo. Etc., etc., etc.
Someone here can point you at the innards for the UI most people would want.
Build the D25 with that UI, and you’ll clean up, as no one will have anything like it.
Also, if at all possible, use TIR lenses instead of reflectors. Easy to swap to go from throw to flood and anywhere in-between.
The custom pcb for the LEDs is interesting (ie, 2 LEDs on 1 board), but 2 separate pcbs that “float” on thermal goop and are held in place by the TIRs would awesome.
Barry0892
Barry0892's picture
if too many changes, why not design a new one?
aswang
That sounds nice. Hopefully sofirn can also improve it to be more waterproof. Maybe just add o-ring for the front cover like the nitecore hc60 and 65. I’m starting to like this headlamp after the emitter and optics swap but can not recommend it for outdoor wet season use because of its lack of waterproofing. I doubt it can survive continuous rain at it’s present state.
BlueSwordM
BlueSwordM's picture
Last seen: 13 min 16 sec ago
@Barry, I know this might be a bit far fatched, but why not make a 1200lm D25S SST-40s and a D25S CRI with 4000k 95CRI SST-20 LEDs?
Best of both worlds.
Barry0892
Barry0892's picture
I mean press and hold to cycle through modes: Low/Med1/Med2/High/Turbo. Big Smile
Barry0892
Barry0892's picture
because the size of emitters are different. XML2 and SST40 both are 5050, XPG2 and SST20 are 3535
gchart
gchart's picture
Your changes to this light sound good, Barry. I’ve seen listings for neutral CCT (around 5000K) versions of the SST-40 popping up at electronics suppliers. Any chance in sourcing some of these?
Barry0892
Barry0892's picture
SST40 5000K emitters to sell?
gchart
gchart's picture
I would buy some, but I meant for the D25S
A product listing for example
Tom E
Tom E's picture
Astrolux/Mateminco is using the NW SST-40's in the new FT03.
gchart
gchart's picture
Tom E wrote:
Astrolux/Mateminco is using the NW SST-40’s in the new FT03.
Ohhh… so they physically exist, not just the product listings? That’s encouraging!
Tom E
Tom E's picture
gchart wrote:
Ohhh... so they physically exist, not just the product listings? That's encouraging!
Yep, definitely. Someone who received the NW of the FT03 took a pic of the LED and matches an SST-40 exactly. Also he described the tint as NW, so should be pretty well verified. I got 2 NW's on order but probably will take a few days at least to get one. Problem is they are lower bin, so lower lumens output - sort of a bad thing because the nice feature of the SST-40's was the super lumens output.
JasonWW
JasonWW's picture
Gchart, what do you charge for an MCU with RampingIOS?
Should I take my D10 apart and verify what the driver looks like?
I’ve got two D10’s, so why not try it on one?
A quick driver question, do those big resistors (sense resistors I guess) directly reduce output between the led and ground? How do they not burn up?
Quadrupel
Quadrupel's picture
Last seen: 8 min 36 sec ago
I removed one resistor in all mine D10’s. Output dropped about 30% in all modes, but i think it’s still to high
