which 18650's for this.
6 posts / 0 new
virencelights
virencelights's picture
Last seen: 58 min 8 sec ago
I have an ArmyTek Wizard Pro CW 1300 Lumens Modded, and have a choice of 2 batteries, – AMPSPLUS 3500 10A or Sony VTC6 3000 15A.
does it make a difference, really?.
15A too much?.
any damage to the light?.
thanks.
Virence Custom Built; ArmyTek Viking Pro E21A 6500k 9080 Quadtrix, Jetbeam AAA 9080 E21A 9080 5700k, Jetbeam AAA Nichia HCRI Red Led.
Edited by: virencelights on 02/25/2019 - 09:04
bmengineer
bmengineer's picture
Last seen: 6 hours 36 min ago
Modded how?
Find all my reviews of flashlights and more gear at www.bmengineer.com
virencelights
Clemence
6500k E21A 9080.
bmengineer wrote:
Modded how?
justanotherguy
Last seen: 7 hours 21 min ago
no answer, but battery amperage is just what it can sustain, in terms of draw, From your light..
It isn’t what it “pushes” into the light..
IIRC
So if your light draws less than 10…AMPSPLUS
10-15, VTC6
MORE than 15? probably need some more firepower Wink
Barkuti
Barkuti's picture
Last seen: 9 hours 28 min ago
A battery is an electromotive force generator. Its output voltage and energy varies with load. Energy cells like the Ampsplus 3500 10A (a rewrapped Sanyo NCR18650GA) usually deliver more energy than higher discharge units like the Murata VTC6 at or near their maximum rating (at or near the max rating of the NCR18650GA which is noticeably less for the US18650VTC6). Given a constant discharge rate the output energy is ∫ V(I,C), being V the function of the output voltage of the cell at a given discharge rate for the delivered capacity C between maximum and minimum (cut-off) voltages.
Sorry if this sounds a tad confusing. I'd like to say, though, that usually running a cell near its specified maximum current ratings is stressful and so I'd prefer and choose a higher discharge rate cell once the square of our target average discharge rate meets or surpasses the square of the cell's maximum rate. In the case of the NCR18650GA this means I'd choose a higher discharge cell for average ratios higher than 7A.
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
CREEXHP70LED
CREEXHP70LED's picture
Last seen: 6 months 3 weeks ago
The Olight HDC cells are also rewrapped Sanyo NCR18650GA cells , So you have another option. They are protected and not cheap though. I would go with the Sony VTC6 or a Samsung 30Q if it will work. I had a married set of the Olight HDC cells for an X7, but one of them is no longer good so I broke them up and have them in other lights. Also they are made in China.
