Command 5000 lumens cheaply.
19 posts / 0 new
264
264's picture
Did not take a picture but I saw at the local hardware store 5000 lumen flood bulbs for around $20.00-$25.00
Made by Feit.
Lightbringer
Lightbringer's picture
Last seen: 14 min 16 sec ago
Goggled around, found lots of refs to 5000K, but not 5000lm. Boo, hiss…
Streamer
Streamer's picture
Yeh, got my attention 264…where’s the beef? LOL Big Smile
bet that puppy would like the bottom of an Apollo re-entry capsule hangin out of a flood fixture.
Streamer
Streamer's picture
DavidEF
DavidEF's picture
Last seen: 6 days 17 hours ago
Thanks Streamer!
- The YKK Philosophy
Streamer
Streamer's picture
And don’t forget to check out the 29,189 lumen Cob light for only $170 at above link….WOW !!
DavidEF
DavidEF's picture
Yeah, I saw that, but unfortunately don’t have a use for it… yet! Crazy
Streamer
Streamer's picture
I did manage to find the Feit 2500 lumen screw-in E27 type flood light. Maybe 264 can link to the 5000 lumen version.
https://www.lightingsupply.com/feit-electric-br40-dm-2500-3k-led.aspx?gc...
264
264's picture
I will go to the store Tuesday and take lots of pictures. For some reason I can not find it online.
Lexel
Lexel's picture
Last seen: 1 day 21 hours ago
The thing with COB is its often not spreading the light in a 360° angle
Philips Trueforce is better in that 5000Lumens from 3x boards with many small LEDs
after a few minutes running
264
264's picture
264
264's picture
264
264's picture
dotBLF
Last seen: 1 week 6 days ago
Hard to find a superbright one good for outdoors… Maybe time to get better fixtures for outside anyways….
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 20 hours 7 min ago
Osram have a new range out of high output bulbs they look so beefy massive heat sinks.
This one is 36w LED 3200 lumens but they are huge in person like maybe 4 times the size of normal bulb.
https://www.amazon.com.au/OSRAM-LED-Value-Bulb-4058075093232/dp/B07G3C9J23/ref=sr_1_87?ie=UTF8&qid=1551168013&sr=8-87&keywords=osram+light+bulb
mattadores
mattadores's picture
I’ve seen a similar light also. The ones I’ve seen aren’t 5000 lumens but are 4000 lumen 300W LEDs for $50 CDN
Home Depot US
Home Depot CDN”:https://www.homedepot.ca/en/home/p.led-300w-med-base-yard-dl-non-dim.100...
Vegas LED Fan
Last seen: 5 days 4 hours ago
I wonder how FEIT rates the bulb shown in the previous post at 4000 lumens. It looks like the LEDs are SMD 5630 and there are four segments of 10 each. The usual rating for the SMD 5630 is 50 lumens driven at 150 mA @ 2.8-3.4V so my math indicates the output would be 2000 lumens, not 4000.
It’s nice to see corn bulbs actually beginning to show up in the US market though the price for them at Home Depot is beyond the pale. I bought a couple of large corn bulbs from Banggood a few years ago using 102 of the less efficient SMD 3528 LEDs for around $10. So bright you did not want to look directly at the bulb. Since then a lot of much more compact corn bulbs have shown up using SMD 5630 and SMD 3014 LEDs. They were all priced around $5 or less (on ebay) and not a single bulb has failed after a couple of years in use. Many of them use the SMD 3014 in arrays of 36 to 72 LEDs for an output of 10-13 lumens per LED. They are great for use in table lamps.
If you go to the official FEIT website they list a dozen different flood lights. The brightest is 1000 lumens and is available in 3000K or 5000K https://www.feit.com/product-type/led-flood-lights/.
Spartan
Last seen: 4 months 2 days ago
Umm…….there is another solution.
Y Socket splitter….dirt cheap…..I use them in a lot of fixtures because I find the 100w equivalent tend to fail faster. So I use 60 watt’ers, dirt cheap at HD.
https://www.amazon.com/Socket-Adapte-Splitter-Standard-Holder/dp/B078R35...
And my favorite…..4 bulb. Two in the garage with 60’s. 800×4=3200 lumens each.
https://www.amazon.com/JACKYLED-Splitter-Converter-Standard-Adjustable/d...
And lumi’nuts….
https://www.amazon.com/8T8-Splitter-Standard-Converter-Commercial/dp/B06...
I use dirt cheap LED bulbs. You can use floods for even MORE control lighting. 4×100w equals to 4800 lumen and bulbs up here are cheap. Plus if one burns out, who cares.
Moses came from the mountaintop carrying a tablet. The Words were....WITH GREAT LUMENS COMES GREAT REPONSIBILITY.
klrman
klrman's picture
Last seen: 1 week 2 days ago
I have the Sansi 40W 5k, 5000lm for my garden flood light and the Sansi 27W 4000lm 3000k bulb for our laundry and living room.  Color temps on both of them seem to be accurate and they are nice and bright.
I compared the  Sansi 27W 4000 lumens bulb to my 16W 1600 lumens led bulb and it is visually twice as bright easy if not more.  Technically lumens is supposed be X4 to get twice the brightness but it seems that is not always the case.  Anyway, they seem to make great bulbs.
