[alive: M4D deal] jetbeam RRT1 950 Lumen
121 posts / 0 new
contactcr
Last seen: 6 min 17 sec ago
I guess I dont see the appeal. Isn’t this exactly what an e-switch light does? one handed operation with dimming but without option of memory?
I got the V11R and it’s cool because it does something no other light does (dimming + mode changing while “off”). You can also “set it and forget it” if you wish.
Rusty
Rusty's picture
Last seen: 1 week 2 days ago
contactcr wrote:
so this doesn’t have a tail switch like the V11R? You have to mess with the ring every time you want to turn it on?
Despite the subsequent replies, I firmly believe there’s no answer to that, not a family friendly answer anyway Evil
moderator007
moderator007's picture
Last seen: 6 hours 9 min ago
That’s the difference between these two control ring lights. V11R has to be flipped or hand hold changed to hit the switch but remains at what ever level the control ring is set to.
RRT01 doesn’t require anything but the turn of the ring for on and off but always starts in moonlight, no memory so to speak.
xevious
xevious's picture
Last seen: 18 hours 29 min ago
Each design has its own advantages. V11R on/off is tail switch controlled, so your hand will be in a specific orientation. You then have to change it to adjust intensity (or use your other hand). But then you have on/off control with a fixed output. RRT-01 has only one control, so you’re always holding it in one orientation for on/off and intensity. If you’re used to having a sequential set of fixed brightness levels, it’s a very different feel. Some people may simply not like it.
jon_slider
jon_slider's picture
Last seen: 1 min 37 sec ago
I prefer the RRT-01, KISS!
for those who dont like KISS, there is also the HDS Rotary..
has a tailswitch, and a Rotary dial at the tail (flipping optional, I do),
its regulated, has memory, and can be programmed for fixed brightness levels too…
for people that can live without a deep carry pocket clip,
and get turned on by reading manuals about multi-clicking
"High CRI lights for sale":http://budgetlightforum.com/node/72660
RobertB
RobertB's picture
Last seen: 1 week 3 days ago
Anyone know what emitter is being used in this?
jon_slider
YES Wink
RobertB
RobertB's picture
jon_slider wrote:
YES Wink
Stupid me, I should have checked battery junction before asking. Facepalm
jon_slider
there are no stupid questions, only stupid answers.. LOL
happy to share info.. I specialize in reading technical manuals and transferring key info to people with more productive things to do with their time Smile
now, please share the motivation behind your question.. why you asked..
inquiring minds wonder.. what do you plan to use the information for?
mili111
Last seen: 2 weeks 6 days ago
Interested!
RobertB
RobertB's picture
Haha, I was being more sarcastic than anything. Who would have thought to look at Battery Junction when the info should have been in the OP? If it turns out to be an xpg3, I won’t order it. Isn’t that the old version at BJ and in the OP?
jon_slider
lol, me too brother
the info IS in the first post, but why rub it in?;-)
and fwiw, no, both BJ and the OP are showing the new version
here is a visual aide
Tom E
Tom E's picture
Last seen: 2 hours 29 min ago
I signed up. Always liked these lights since I did an early mod on the original several years back, think updating an XML to an XM-L2.
RobertB
RobertB's picture
I saw that post. The old one looks “fatter” to me, which is why I was confused
jon_slider
RobertB wrote:
I was confused
the old one is on the bottom
the new one is 1/8” larger diameter, and 26 grams heavier
Tom E
Tom E's picture
Like the tail trit slots on the new one
jon_slider
I like the tail design too!
Humanized Tail maybe = HumanCentricDesigned Tail: use as a
Candle,
Lantern,
Nightlight,
Locator
Impress your Friends! Wink
I wish I could buy the light with trits already installed!
(Im sure thats a logistical nightmare for the vendor.. lol)
moderator007
I ordered 3 of these during new year sale. https://www.fasttech.com/p/4159008
I’m just hoping they fit from the measurements I took.
Tom E
Tom E's picture
Those slots are 12 mm long? I was think'n they were for the std 1.5x6 mm size, but from the pics, they have to be longer than 6 certainly, so probably the 12 mm size you ordered.
LightObsession
Last seen: 1 month 1 week ago
jon_slider wrote:
RobertB wrote:
I was confused
The new version looks much sexier to me. Too bad it’s likely way out of my budget, even with the group by discount.
moderator007
The 2×12mm trit slots will not fit the RRT01 without modification, there a little to long. 2×10mm should fit fine.
More info here with pics. http://budgetlightforum.com/comment/1467214#comment-1467214
shirnask
shirnask's picture
Last seen: 22 min 23 sec ago
Would 2.5×10 trits fit?
moderator007
Not without grinding. Best I can tell the slots are 2.25mm in width. Seems they intended the slots to fit 2×10mm but the 2×12mm is more common at our usual oversea’s stores.
Gunga
Gunga's picture
Last seen: 28 min 58 sec ago
I’m interested.
M4D M4X
M4D M4X's picture
Last seen: 1 hour 24 min ago
Deal is alive - i mailed every email in the list
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
d_t_a
Last seen: 10 hours 52 min ago
Interested. But may depend on the price…
shirnask
shirnask's picture
Ordered, Thanks Martin
Bob_McBob
Last seen: 5 hours 34 min ago
Can you confirm the bezel isn’t glued on the new version?
toddcshoe
toddcshoe's picture
Last seen: 1 day 16 hours ago
The bezel is not glued. Came off easily. The part of the head above the ring has a touch of loctite or something on it but, it was still pretty easy to get off. I just wrapped some tape around it and used some channel locks and it twisted right off. You can swap the emitter by just removing the bezel but, you gain some extra working room if you get that part above the ring off.
"Everywhere I go, there I am"
SKV89
Last seen: 2 hours 30 min ago
Does anyone know what the standby current is on the new RRT-01? I heard the previous version drains a full 16340 cell in 2 months.
