RE : Sofirn SP33 XHP50.2
Sofirn has entered the 26650 market with GREAT POWER. The Sofirn SP33 is ANOTHER WINNER. The flashlight is very effective and versatile for any situation where a powerful projection light beam is needed. Now lets take a detailed look of what awesomeness lies inside the package.
The Sofirn stye of box is similar to each release of their lights. Typical black matte finish dual flap construction. Flaps can be undone from either top or bottom. Back of box specifies detailed information about Sofirn company history, and products they produce for consumer. Nothing fancy. Rather INFORMATIVE and EFFECTIVE. Very easy and basic.
The entire contents are enclosed inside a plastic slide out tray which is easy to remove. The items inside include
Sofirn SP33 Flashlight
Sofirn Branded 26650 5500 mAh battery
Spare ” O ” ring x 2
Micro USB charging cable.
Micro USB Battery Charger
Instruction manual in different languages
Satisfaction Flyer
Lanyard
The build quality on this flashlight is EXCELLENT. The machining and finish is SUPERB !!! Made of Aerospace Aluminum Alloy. The hard anodized type 6061-T6, Mil-Spec HAIII protects flashlight from EXTREME environments. Dual firm brass springs on tail cap and head area greatly aids in conductivity from battery. O rings seals prevent any type of moisture entrance into flashlight. The front of flashlight head is encased by a semi aggressive stainless steel strike bezel. The strike bezel protects Anti Reflective coated lens. Stainless steel bezel can be used DEFENSIVE TOOL in case of emergency. Fend off attackers, Break windows in emergency OR use as STRIKING TOOL in ANY DANGEROUS situation. The knurling texture aids and helps for great non slip grip.
The Engineering Design features is well thought out with emphasis on safety and helps prevent flashlight damage.
Advanced Temperature Regulation better known as ATR. Helps protect light from overheating when light reaches temperature of 55 degrees Celsius (131 degrees Fahrenheit )
Automatic step down mode after 2 minutes of Turbo Mode aids and prevents overheating of light.
Both ATR and step down design features work parallel to prevent overheating and damage of flashlight.
Reverse Polarity Protection. : Prevents flashlight damage if battery is installed backwards.
High Voltage Protection.: The light can not function or be turned on if voltage is higher than 5 Volts.
Low Voltage Protection : The ” Turbo ” mode will be automatically disabled if Voltage is lower than 3.4 Volts. Automatically steps down to lower modes if Voltage is lower than 3 Volts. The flashlight completely turns off automatically if Voltage is below 2.6 Volts.
Integrated lighted power indicator operational side switch.
Green light indicates battery is 50% or more capacity
Orange light indicates battery is 20% to 50% capacity
Red light indicates battery is less than 20% capacity. Meaning time to recharge or replace battery.
Accidental Lockout out Mode.
The Sofirn SP 33 manufacturing specifications are clearly indicated with very detailed information about flashlight.
The LED light source : CREE XHP 50.2 LED with lifespan of 100,000 hours
Working Voltage: 2.8V-4.3 V.
Compatible Batteries: 1 x Sofirn Branded 26650 5500 mAh (included), 18650
Reflector: Orange Peel. For balanced dispersal of light beam
Anti Reflective tempered glass coating lens. Scratch resistant.
Demensions : Length 124mm, Diameter : 31.5mm, Head 36mm
Weight 117 grams without battery
Sofirn SP33 specifications as per ANSI/FL1 standards.
The flashlight has 5 light mode levels and Strobe
Turbo : 2500 lumens Run time : 52 minutes Candela : 11760 Beam Distance : 217 Meters
High : 1000 lumens Run time : 1 hour 17 minuttes Candela : 4841 Beam Distance : 139 Meters
Medium : 400 lumens Run time : 4 hours 55 minutes Candela : 2041 Beam Distance : 90 Meters
Low : 150 lumens Run time : 16 hours 37 minutes Candela : 697 Beam Distance : 53 Meters
Eco : 15 lumens Run timen : 111 hours Candela :120
Strobe : 2500 lumens
IPX68 Rating:: Waterproof : Water submersible to 2 meters
Impact Resistant : 1 Meter (3.28 feet)
The orange peel reflector design disperses light beam evenly with great lighting whether near or far distances. The center hot spot is evenly dispersed with VERY LITTLE light artifacts. The hot spot is not tight focused and decent sized allowing for good throw distance and flood of light beam. The tint is more on Cooler side.
Operation of light is controlled by lighted side smart switch. The user interface is pretty simple.
To turn light on/off : one click
Cycle through light outputs : press and hold to cycle from low, medium, high ……
Access Turbo Mode : From “on” or “off” position double click.
Access Eco/Moonlight Mode : Press and hold button in ” off ” position.
Access Strobe : Double click to Turbo, Double Click again.
The Sofirn SP33 is rated at IPX68. Waterproof up to 2 meters. Submerged flashlight in deep water tank . Left inside for 1 hour. Removed from water tank, unscrewed tail cap, and looked inside. Completely dry. No sign of water entrance into light. Turned on light. Cycled through all light modes easily with no problems.
The impact/drop resistance rating is 1 meter. Dropped multiple times on different sections of flashlight. Waist high drops. 2 times on stainless strike bezel, 2 times on side, 2 times on tail cap. Slammed light against concrete wall. Turned on light. Still worked.
The crush test really showed how well built the Sofirn SP33 is. The vehicle used is Toyota Sienna van. Ran over light 6 times. 2 times in drive completely running over light. 2 times in drive mode. 2 times in reverse mode. Ran over light on dirt road, paved cement, asphalt. Light still worked.
The Sofirn SP33 has EXCELLENT build quality. EXTREMELY DURABLE AND STRONG.
Sofirn’s Engineering Design, build materials, budget friendly pricing MAKE a GREAT CHOICE when looking for QUALITY flashlight!!!
I really like my SP33 and have been using it quite a lot lately. It’s a great value and a solid performer. I haven’t found a properly sized holder for it to go on my belt so it’s been riding in my jacket pocket.
A warmer tint would make it even better! Hint, hint…
In terms on holsters, I’ve got this one in the mail. I’ve read that it’s about the right size, but I can’t speak from experience (yet).
Good review ‘mm’! I am really liking my SP33’s too. :+1:
I like the UI also, simple yet effective. I’d like a ramping option too if they ever decide to do one on the SP33.
I like the tint on my samples pretty well.
Thanks teacher. I have ” fallen in deeper love ” with Sofirn brand. I own doubles of all their lights. Great build quality and budget friendly pricing make this brand a GREAT CHOICE.
Your welcome mmalive. I too am impressed with & loving all my Sofirn lights!!
Fit n’ finish on all mine are second to none. Build quality is great & I like their tint choices. Usually not to cool or not to warm… right in the range I prefer. :+1:
Very true teacher. I am more of a Cool White guy. But Neutral White would be my second choice. Sofirn does fall in between those 2 tints.
Yep, they do fall in between for the most part. I usually prefer the cool side of Neutral… nothing that adds much tint to white either way.
3A / 3D is the sweet spot for me usually. :+1:
